Question about Philips HTS3400/37B System
No Disc I have a Philips HTS3400 and now everytime I try to play a DVD it reads "No Disc". What can I do?
  • 8 more comments
  • ienstien Feb 29, 2008
    Exact same problem described by michaelg22. Same make and model philips home theater reports "No Disc". It works okay if I disconnect and reconnect power but again not always - maybe around 30% of time. Owned it for about 1.5 yrs.
  • Keith P Mar 09, 2008
    MY SYSTEM WILL NOT RECOGNIZE ANY DVD OR MOVIE DISK. I PUT THE DISK IN UNPLUGGED THE UNIT PLUGGED IT RIGHT BACK IN WITH THE DISK IN IT THEN TURNED THE UNIT BACK ON RIGHT AWAY AND IT RECOGNIZED THE DISK. APPEARS THAT PHILIPS HAS A PROBLEM WITH THIS UNIT AFTER A YEAR AND HALF THAT IS HOW LONG I HAVE OWNED MY UNIT AND I AM NOT THE ONLY ONE. HOW CAN THIS BE FIXED
  • loudambiance Mar 17, 2008
    I am having the same problem. I have possibly determined why. When I insert a dvd they do not always spin up, however if I unplug the system, when I plug it back in it spins up a little bit. This could be why unplugging and replugging it works occasionally.
  • masgerr Mar 19, 2008
    New repair really that goes with out saying! Yes I have the same problem it seems the drive motor that turns the disc when it feels like it I took it apart and watch it. So if the disc doesn't turn it reads no disc found.I'm just guessing.
  • Anonymous Mar 27, 2008
    Same Phillips HTS3400. Same problem where it shows up and says: "NO DISC" My disk never spins, so it never recognizes the disk.
    If I get really interested, I'll pull the thing apart and put a scope on the leads to the motor to see if it's the motor, or the drive circuitry.
    My ultimate solution is to scratch "Phillips" from my future list of electronic purchases along with RCA. (I have a nice 52 inch paperweight in the garage)
  • butters73 Apr 04, 2008
    I have exactly the same problem. I have had it about 1 and a half years. The strange thing is that sometimes it will work and sometimes it will not I have unplugged it as well and that works SOMETIMES.
  • bwarcher82 Aug 28, 2008
    Same problem. I took it apart and looked at all the connection, bought a DVD cleaner and manually spun it, and tightened every connection but it still won't work.
  • jlyonsp Dec 15, 2008
    No Disc, yep, same problem, this thing seems to be a pile of ****. I will try the power-down thing a see if it works. We should all write to Phillips and demand a remedy... The web is full of people complaining about this unit. maybe they'll take care of us
  • dougles Dec 31, 2008
    Mine will spin slowly, searching for the disk info. It does not seem to be alligned properly to do this.
  • Anonymous Jan 04, 2009
    Same problem. Had system for about 1 year and "No Disc" also sound will max out, turn system off and will be ok for a few min. then sound goes to max. Looking for replacement parts..not having much luck. Solution... bought a JVC HTS works great..
  • 8,596 Answers
Run a dvd cleaner through system, and try again. If that fails, unplug the HTS from the wall outlet for 10-15 seconds, and replug it. If that fails, it will need to be repaired.
-Tha Mp3 Doctor
Posted on Feb 18, 2008
The dvd player reads the cds but when dvd is inserted it says no disc after few seconds of load
the laser is weak. need to replace. you could also try opening unit and clean lens with alcohol.
Mar 23, 2011 | Philips HTS3400/37B System
No Disc Error in Philps FWD17 with DVD and MP3-CD playback system
The problem with the system Philips FWD17 shows NO DISC for certain CDs which wont play. With regard to DVDs it doesnt recognise them at all. The disc spins and then stops showing NO DISC
I have replaced the lens with the same type and model SF-HD65. It still doesnt detect DVDs
Please advise.
Regards,
Gerry
E-Mail gerardf1960@gmail.com
Feb 22, 2010 | Philips HTS3400/37 System
Philips hts3400 will not play dvd
first clean the laser lens if this donçt solve the problem change the motor disc spindle because are on bad conditions
Jan 09, 2010 | Philips HTS3400/37B System
Our Philips HTS3400 DVD player is not working. When inserting a disc, it displays "No Disc". Any suggestions?
seems to be an issue with this model, i cant play any discs, the sound is only coming from the left rear speaker and the sub, the system shuts off every half hour due to overheating...needless to say the system sucks...didnt last long...im very tech savvy and still couldnt figure out why all of this was happening.
im looking at samsung now...everything else i have is samsung and love it.
Dec 31, 2009 | Philips HTS3400/37B System
Does not read dvd
Your problem is that you bought a Phillips instead of a Sony.  Quality vs. Quantity my friend.
Anyways, your DVD player is set up to play region 1 and the disc you inserting is probably some other region.  Look on the back of the DVD case and it will say what region you can play the disc on.  Also, clean off all the smudge marks on the disc with some glass cleaner and this disc won't play if you got a lot of scratches on the thing.
If the above didn't help, then your fuc..d, cause your laser pickup is dirty or defective.  Run a DVD laser cleaning kit through it, which is available at all the big box stores.  See if that helps out any.  If not, then your truly fuc..d and you need to call the manufacturer if this thing is still under the 1 year warranty.  If your under 30 days, then just take it back to the store and exchange the thing out.
Oct 26, 2009 | Philips HTS3400/37 System
Philips HTS3400 door won't open and shut. Says NO DISC
open up the unit and replace the broken drive belt for the dvd tray. us an O ring that you can get at any auto parts store. i replaced mine and it works fine now.
Oct 06, 2009 | Philips HTS3400/37B System
What recordable dvds will play in philips HTS3400??
it might be the programs your using to burn your dvds try using windows dvd maker if you have the operating system vista or convert x to dvd if you have xp that should work
May 30, 2009 | Philips HTS3400/37B System
DVD home theater system
Disc is either to scratched or may have a hairline crack on disc. If this happens to all of your disc's, then you have a laser read problem. This can be caused by high humidity as well as dust and debri. Try blowing the unit out with canned air.
Mar 02, 2008 | Computers & Internet
Reads NO DISC Philips HTS3400 Home system
-Tha Mp3 Doctor
Jan 27, 2008 | Philips HTS3400/37B System
Philips HTS3400/37B
If you have a screwdriver q tip and rubbing alcohol you can fix it. Take the screws out remove the cover and locate the laser. It looks like a small lens. Dip the q tip into the rubbing alcohol just get it damp not dripping. Clean the lens with the Q tip and then put it back together.
Oct 07, 2007 | Philips HTS3400/37B System
Philips HTS3400/37B System Logo
413 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
