Question about Samsung SGH-U600
Application intaller on samsung E250
How to install application on samsung E250
  • 12 more comments
  • Anonymous Feb 25, 2008
    how i ca istall a .jad application through pc
  • Anonymous Mar 15, 2008
    haw to instal aplication in e250
  • Anonymous Mar 23, 2008
    akjfk
  • Anonymous Mar 24, 2008
    cant install java applications in Samsung E250
  • Michael Guinarez
    Michael Guinarez Mar 25, 2008
    I want to install my samsung e250 unit cellphone with APPLICATION so that i can install programs like THEMES, DICTIONARY OR BIBLE and other programs.
    So, how to install and where can i get that installer?
    Thanks..
    MICHAEL
  • Sidharth1991 Jun 30, 2008
    hi how to install themes plyers etc on my shg-E250 samsung phone
  • aayushm Oct 04, 2008
    i am not able to install applications in my samsung e250 please tell me how to install them througm my data cable
  • shielah Jan 10, 2009
  • carlet_511 Feb 19, 2009
    how to install applications in e250?
  • Anonymous Feb 23, 2009
    is it that hard to install games to e250? ugh..
  • Dipon Apr 07, 2009
    How i install application in samsung E250
  • guwapodh Apr 17, 2009
    please help me...
    when i press the i button, wap disconnected it says..
  • masheer May 16, 2009
    how can i install java applications in samsung e250 by data cable?
  • sancy May 11, 2010
    how to install games to samsung E250 mobile.
    if v download a game it goes into other files.
    so plzzzzz help me out......
انا عايز ثيمات لتليفونى samsung e250
Posted on Apr 26, 2008
Follow the following steps.
1. Download Samsung PC Suite and install (this is to ensure the computer can detect teh phone). Disconnect the phone from the computer
2. Download the following (do not install until told)
a. Softick PPP
b. Uploader.exe
3. Install Softick (ignoring the error which pops up). Chose exclusive mode from the setup, but do not run application once installation is complete
4. Connect the E250 to the computer and rightclick the Softick PPP icon in the systems tray to go to the settings.
5. Click on the bluetooth/serial tab and check the appropriate COM port.
6. On the E250, type *#52828378# (*#javatest#), go to OTA type setting and select "Serial bearer OTA"
7. Run "uploader.exe" and add the .jad files (these should be present on the computer along with the .jar files. If you have .jar, but no .jad, download program JADMAKER, which can make .jad files from .jar files)
8. Right click softick icon and click "activate PPP"
9. On the E250, type *#javatest# and go to option 3, "serial test"
10. Click 1 PPP and select USB (select BT if using BT)
11. Then select "Serial download"
At this point the first jad file should disappear from the "uploader.exe" progam.
You will have to repeat from step 8 for each jad file you want to add
Enjoy yourselves.
Posted on Jan 09, 2009
  • 20 Answers
I also have a samsung e250 and i followed these instruction and it worked...
You must download two programs the SoftickPPP which you can download in this link: (if this link is not working try google you can find many sources)
http://users.skynet.be/yozy/tutorials/downloads/SoftickPPP234-en.exe
last is the uploader.exe
http://users.skynet.be/yozy/tutorials/downloads/Uploader.exe
Download the 2 programs and install the first program configure its setting on bluetooth/serial and choose the general serial port you are using for example: \device\mdm0 then press OK
Your fone must be connected to the pc via bluetooth or usb cable.
open uploader.exe and add the jad file of the game you want to install... then activate softick, which you can see in the taskbar right click the green icon and select activate softick.
type *#52828378# on your telefone
OTA type setting
then
Serial bearer OTA
then save
activate SoftickPPP which you can see in the taskbar right click the green icon and select activate softick.
type #*5737425# on telephone
then
PPP UP
then
choose usb port (if you are connected via usb cable) or bluetooth
then
Serial Download
(sometimes the fone restarts during this procedure, just inactivate your softick while the fone restarts and activate it again...
you can see java screen when the game is being uploaded...
if you still have questions email me at maeayanami@yahoo.com
goodluck...
Posted on Aug 26, 2008
Http://wiki.answers.com/Q/How_do_you_install_games_in_samsung_E250
Posted on May 04, 2008
  • aaaaaaa12345 May 04, 2008
    Only way dude, if u dnt use wap,
    but even wid wap, size shud b < 200k,
    only lemons r dat small
  • 3 Answers
The samsung E250 Has a limited number of Midlet classes that it accepts. These are Class B, C, D, E, F, G, M, P, Q and S. Unfortunately limited J2ME applications are compilled in these classes as such you can download an application only for it to fail to even be recognized as a Java Archive File, .jar.
Posted on Feb 07, 2009
I have a samsung E250 mobile with me..i want to change the theme...i saw some samsung E250 themes in the net and i have downloaded them too..the themes are .sis files
how can i install the .sis format themes in my mobile..? please tell me the exact procedure to install including the sites where i can get the related softwares...
i thank you for ur help rendered to me..
(vivek)
Posted on Jan 20, 2010
You must download three programs, 1 softick ppp v 2.2.1
                                                     2 uploader.exe
                                                     3 JAD maker
First step is to install softick ppp and run it. click on try icon with left mouse button and click on settings. There is an menu, click on bluetooth/USB and mark all COMs. Restart softick. Pair your device with computer and allow serial barrer on your phone when request go on. Now start uploader.exe and find your application or game..For instaling into SGH250, you need files with extention "jar" and the same file with "jad" extention. If you have a game in "jar" form, start JAD maker and catch your "jar file" on the JAD maker window. It will automaticaly create the file which is neccessary for instalation.
Now you hav started softick, uploader and you have GAME in "jar"and"jad" form. Click on add in uploader menu, find your game or games. For installin via Bluetooth you must configure your e250 phone with an code. On the keyboard in your mobile phone, write *#52828378#. go to "OTA  type setting and catch serial barer for installing with bluetooth or USB. Go back, click on "Serial test" and set Bluetooth or USB. Go back.
Now write *#52828378# coda again for return to java test menu. Click on Serial test and than serial download. It must go.It can still be chance, that the mobile phone will restart beware some stap. It is no error. You must repeat this step or steps.. For other informations, you couldwrite me an e mail with object "samsung", my e-mail adress is, I havw my e 250 with a lot of applications.
furkadaniel@zoznam.sk
;D Good luck
Posted on Aug 08, 2009
How to install java games using usb data cable
1: Install\Run SoftickPPP221 from the Softick.PPP.v2.21 Folder. Ignore any errors about usbsync.dll by pressing ok.Leave the option use usb in shared mode checked.
Run when finished installing.Youll get an error message about being unable to locate usbport.dll , just click cancel.
2: Plug in your usb cable and turn phone on.
3: Right click on softickppp running in your taskbar and select settings.
In the usb tab uncheck accept ppp connection on usb and tick both use usb in exclusive mode and overide usb
Click on ok and completely exit softickppp by right clicking then exit.
4: Run softickppp and again goto settings. On the bluetooth\serial tab tick the correct com port as shown in
5: On your phone key in *#52828378# press 2 ota type setting and select serial bearer ota.
6 Run samsung java uploader and add your jad file
7 On your phone select 3 serial test , 1 ppp up , 2 usb
Your phone will now reboot. While its rebooting right cklick on softickkppp in your taskbar and choose shutdown ppp
8: When your phone has rebooted again key in *#52828378#
9: Right click softickk ppp and activate ppp
10: On your phones java test menu press 3 serial test , 1 ppp up , 2 usb , 2 serial download
Your game should install and start running.
Posted on Jan 24, 2009
How to start Application? I'm have already loaded Application.But when i open file.I don't know how to do that?
Posted on Oct 13, 2008
I have same problem
If some one knows Let me know...
Thanks
Try to get free bible on my samsung E250
Hi.
Please check the links below, start from the first link.
Free Samsung E250 Free Bible for mobiles App Download
Evangel J2ME Free Software Download for Samsung E250
Best Samsung E250 Bible Downloads
To get the bible, click on the first link, choose download, copy the file into the phone, and install application from phone by running the file.
Have a blessed day.
Ginko
Apr 28, 2011 | Computers & Internet
How to install a game in my cellphone???a samsung model SGH-e250...
you got to know that applications cannot be installed in it manually.
It should be done from your browser by going online.
That's the only way. I've heard that sum unlock code can be used to install applications using USB. But i've almost browsed the whole net, and no use :(
For info regarding Android, try this http://allaboutcomputer.co.cc/?p=9
Mar 10, 2011 | Samsung Cameras
I cant instal themes
DOWNLOAD SAMSUNG GAMES AND APPLICATIONS AND THEAMES FROM THIS TWO LINKS
1)http://in.samsungmobile.com/entertainment/featured-applications/a-store.do
2)http://www.samsungapps.com/topApps/topAppsGate.as
Dec 05, 2010 | O2 Samsung SGH-E250 Cellular Phone
How I connect my samsung SGH-E250 to my computer for taking some apps and games to my phone..plzz plzz help me
You need to install Samsung PC Studio 3 on your computer. It's a free download.
Installing PC Studio 3 for the Samsung SGH-E250
Click on the link below. On the web page for your phone locate the word 'Software' (Tip: it is beside the word manual in the lower box under the 'Downloads tab.)
Choose your computer's operating system and click on the file for your application. ((Note: A Pop-up window may appear. Scroll to the bottom of the window and click on : Accept.
When the file 'Pops Up' click, Save. Then, locate the file where you saved it and install it on your computer.
Click here to download: http://tiny.cc/fL9be
If this information was helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 02, 2010 | O2 Samsung SGH-E250 Cellular Phone
How i open *.jar game or application in sgh-e250 samsung mobile
hey its a little bit difficult dealing games on samsung phones try to install it using their software by connecting your phone and pc.and try to download games at the samsung funclub website.
Dec 26, 2009 | O2 Samsung SGH-E250 Cellular Phone
Samsung e 250 application installation
try using your wap browser to downlaod but its only beneficial if you have and unlimited data plan from your operator........or you can buy a card reader its cheap............
May 11, 2009 | O2 Samsung SGH-E250 Cellular Phone
Programs I've Used:
IVT Corporation BlueSoleil
Softick PPP - I've left all COMs ticked
1. Turn on you're Bluetooth
2. Open your Samsung Java Uploader and add your desired Java Game.
3. Open the Softick leaving all COMs checked.
4. Go to Phone Settings > USB Settings > Choose Mass Storage
5. Key in *#52828378*
6. Make sure the OTA type is in Serial Bearer OTA
7. Click Serial Test then click PPP UP
8. Choose Bluetooth
9. Open the IVT Bluetooth Program that I've mentioned above and activate Bluetooth Serial Port Service
10. Finally, click Serial Download....
Ta-dah!
NOTE: After a download, you need to do the steps all over again as they go back to the default settings...
pls vote me  thank you
Feb 13, 2009 | O2 Samsung SGH-E250 Cellular Phone
How to put games on my samsung e250 via usb cable?
want to have alot of applications on my samsung e250 and i only have usb cable.If someone could post a good turitorial on how to do it i would be gratefull,Please say everything in your solutions.Sorry for my bad english i'm Bosnian!!
Jan 03, 2009 | O2 Samsung SGH-E250 Cellular Phone
Unable install games in samsung e250
go to this page, it will help you alot. ü
http://mjsma.page.tl/E250-Games-s-Application.htm?PHPSESSID=448de2412d59cfa13aab588b31800cb6
Aug 20, 2008 | Samsung SGH-E900 Cellular Phone
SAMSUNG E250 INSTALLER
I want to install my unit with APPLICATION so that i can install programs to it like Themes, Dictionary and other programs but i do not know how. So, how to install and where i can find that installer? thanks.
THANKS TO WRITE ME IN FRENSH
Mar 25, 2008 | Samsung SGH-U600
Samsung SGH-U600 Logo
9,416 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
