Televison & Video Logo
Anonymous Posted on Jan 12, 2010
Where can I buy a aiko tv remote controler number A3410 and how much would it cost. It must be in Australia.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 12, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
122
Points
I have found out the type of remote is no longer avaible, so I do not need any help Thankyou.
Aiko dvd problem
you need the aiko manufacturers code.. gotta go to that website..
1helpful
My aiko tv model A3410 is on child lock and i have no remote. How do i get to child lock off?
Unfortunately, you can't disable the child lock (front panel lock) without a working remote for the TV. If you can find a universal remote that will match the Menu function of the TV, then press menu and find the child lock option. Then press Volume + or Volume - to toggle it to off.
I wish that I had better news for you. The manual for the A3410 is available here: http://ernie.awa.com.au/ArticleDocuments/1061/AIKO%20A3410%20Instruction%20manual.pdf.aspx . You will need Adobe Reader or a similar program to read the manual.
1helpful
2answers
Need to replace remote GL21A-C2 for Bauhn tv
Just visit the site pointed out here, and check. There are setup code list to some popular models remote controls. Check them, and find out, which remote has setup codes with your brand TV, and select that one. In most cases, Philips universal remote will have it.
1helpful
Where can I get new remote for my aiko tv
you should be able to get a remote for your model by sending a email request with what you need and the model number of your set to [email protected]
How do I get new remote for my aiko
Five digit universal remote code for Aiko TV is: 10092
Remote control is[ RCA RCR 311STN ]
2answers
I have an AIKO A3454 Remote Control, which has decided to not work. Without it we can't use the TV (Portable), as we can't even turn it on without it. I live in Armidale, NSW 2351 where would/could you...
If you have a tv repairman in the area, he should be able to test your remote for an infrared signature with a tester. The other option is check out ebay to see if a seller has one for sale.
2helpful
2answers
My aiko tv is stuck on child lock. I have no remote and dont know how to get the child lock off.
You can try turning it on and pressing all the buttons down at the same time, that sometimes will reset tv's to factory.
3helpful
2answers
AIKO TV
Hi i have a Aiko television and it for some reason it has F A C in small letters on the top left hand corner of the tv, how do i remove it i can't figure it out.
Cheers Tania
Child Lock Aiko TV
I had the same problem with an AIKO TV. The childlock was on and initially I couldn't find the remote after moving. Unfortunately the only way I got it unlocked was with the remote. So I turned the TV off with the remote. Then turned it back on and then had to go into MENU and change child lock from on to OFF. Sorry no other handy suggestions if you haven't got the remote.
REMOTE CONTROL CODES
Maybe a good idea is to go find the original replacement remote control for your television. I know that the cost of buying a new replacement is almost the same cost as the universal remote and less hassle when you receive it, because the replacement will just work! I went to every tv remote controls website to buy the replacement remote control. They have a pretty large selection so hopefully they have what you are looking for. Great site with good customer service, I would definitely recommend them. If they don't have what you are looking for, there are other sites out there like them that can help, just search on google for your tv/remote model number and you should be able to find the original.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
