Question about HP DeskJet 812c InkJet Printer
Colored text printing
Deskjet 812c is used for text only with Black cart & dead Color cart inn place. Printer will not print anything that is not black or gray. Manual has been of no help. what to do?
Thanks,
  • Anonymous Mar 26, 2014
    can i install a black cart. in place of color
  • 168 Answers
The printer assumes that the color cartridge is good, and is trying to print with the dead color cartridge.
See if there is a setting for your printer under the control panel, printer, and go to printer properties.
See if you can select to print BLACK only.
I know they have this option for some Canon Printers, but not sure with the HP Printer Drivers.
Worst case senerio, Highlight all of the text, and change the color to BLACK before printing. You can always just pick up a cheap refilled cartridge at Staples since it wont be used a lot, the quality isnt going to make much difference.
Good luck.
Hope this helps.
Mac
Posted on Feb 08, 2008
I have HP Deskjet D2466 Printer and when i want to print with color cartridge, the black color would be printed as blue color... My black cartridge was exhausted so i only can printed with color...
when the color cartridge has to make black, it uses all three colors. printing blue indicates that the color cart. is getting low on red and yellow. get a new black cart. and a new color, 'cause it' s coming due.
Let me know
May 18, 2010 | Office Equipment & Supplies
I hooked up my HP Deskjet 812C seems like there is no power?
HTML clipboardHi,
It may sound silly but have you had your printer unused for a while?
If so the inks C6615A [No. 15] black and C1823A color ink cartridge may have clogged up?
The empty weights are 65g and 90g anything over that...
1g = 1ml of unused ink
If you still have ink you can unclog them with a HTML clipboard Magic Inkjet Flush Kit which is great if you ever need to UNCLOG an HP Canon Epson or any other inkjet printer.
You can read more here:
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
Tinteiros (Ebay)
Oct 29, 2009 | HP DeskJet 812c InkJet Printer
Printer only prints in black and pink
The problem may be from either the settings for the printer or the Inkjet print cartridge for the printer. I will advise that you firstly check the settings of the printer from your computer, then probably change the color cartridge of the printer. Then print a tested page to see whether the problem still occur. Thanks
Sep 24, 2009 | HP DeskJet 812c InkJet Printer
Printer is only printing pinks. Just changed ink
Try cleaning the print head. Do this under the tools for the 812c (do not physically clean). You may have to run the clean utility as much as 5 times.
Aug 17, 2009 | HP DeskJet 812c InkJet Printer
HP 812C will not print yellow but everything else is A-OK Repeated cleanings have NO effect. Cleaned contacts on printer where it connects to cartridge, no effect. HP 23 cartridge only has about 10 pages...
HTML clipboardHi,
It you haven´t used your printer for a while It sounds like the yellow has clogged up in the print head.
Although you have ink you need to print something regularly about every 10 days to keep the tiny jets open
otherwise it´s like trying to pass a camel through the eye of a needle.
So the inks may have clogged up?
The empty weights are 65g C6615A [No. 15] black and
90g C1823A color ink cartridge
anything over that... 1g = 1ml of unused ink.
So if you still have ink you can easily unclog it with a HTML clipboard Magic Inkjet Flush Kit (find it on Ebay)
Or you can read more here:
Good Luck!
Tinteiros (Ebay)
Aug 02, 2009 | HP DeskJet 812c InkJet Printer
My printer wont print in color & its a new color ink cartridge
have the printer preferences been changed accidentally to print in greyscale? Is the cartridge installed correctly? Now and again if the cartridges are opened and not installed straight away the ink dries up in the nossel and clogs the printer head, easily rectified with some cleaning solution. Cartridges also go out of date. hope this helped
daveywhite
Nov 11, 2008 | HP DeskJet 812c InkJet Printer
Cartridge/Printer problem - very weird (HP PSC 1315)
quiet easy you have to change you print selection to all or everyday printing that way it will print both color and black all together instead of not this and that
Mar 23, 2008 | HP PSC 1315 All-In-One InkJet Printer
Never print in color
yes there is:
what you need to keep the printhead alive and to print only b/w is
some destill water, some glycerin alc. (drugstore) and some printhead cleaning solution and ORIGINAL -empty!- brother c/y/m carts:
Drill a 2mm hole into the brand name on top of the carts (e. g. <<O>> of brother).
Mix 7ml destill water with 3ml glycerin alc. and 1ml of print head cleaning solution (shake well before filling into a syringe and then to the open cart).
Do print in Greyscale mode (see printer settings) and with normal paper only, because otherwise the printing will be bad!
Machine will print b/w only and you can be sure that the ph will keep alive!
Feb 29, 2008 | Brother MFC 210C All-In-One InkJet Printer
Nothing comes out when I print
Epson 777 will not print. No paper jam. Power light flashing; red error light on steady. Paper does not feed; if paper supply is placed deeper in feed, entire paper supply (about 12 sheets) feeds thru as one sheet normally would , without printing.
Feb 27, 2008 | Epson Stylus Color 777i InkJet Printer
Printer prints in color but has gaps
Have you tried a new colour cartridge? This is a classic sign that the cartridge may be low on ink. When printing text, assuming you are printing black, it is likely that the black cart is doing most of the work so the gaps are insignificant. You could try printing text in several different colours. If the colour cartridge is low, you'll find that some colours may be ok but others may have gaps.
Best to try a new cart if you have one.
Dec 11, 2007 | HP Deskjet D2360 InkJet Printer
HP DeskJet 812c InkJet Printer Logo
115 people viewed this question
Ben Johnson
