Question about Xerox Phaser 2135N Laser Printer
Problem with phaser
When i print a normal print the white background turns into a grey shade but the rest of the print is fine ie if i were to print an a5 picture on an a4 the picture will be fine but the rest of the page will be ashy grey
    President:
  • 2,072 Answers
Phaser 2135 Printer: Resolving dirty looking background or gray haze
Description: Tiny speckles of toner scattered all over the page, even in areas of the page that should be blank.
  1. Make sure the media being used is supported by the Phaser 2135 printer.
  2. Inspect imaging drums for any signs of leakage or excess toner that could be falling onto the print as it travels though the printer. Any leaking imaging drums should be replaced.
  3. Verify environmental conditions. See article Dealing with humidity, humidifiers. If the environmental conditions are not within the specified range, the printer should be moved before trying to troubleshoot the cause to the background toner.
  4. Determine if any of the imaging drums were exposed to light for an extended period of time (more than 10 minutes). If so, then Replace the imaging drum. (Xerox is not responsible for any imaging drums that have been damaged by over exposure to light.)
Additional Recommendations:
Background toner may increase, if printing occurs at temperatures towards the higher end of the specified operating temperature range. For this reason, it is recommended that the printer be moved to another area if at all possible.
In addition, very smooth media types such as glossy; allow toner to more easily scatter about the page prior to becoming fused. Try using a less smooth media if at all possible.
Posted on Feb 11, 2008
My screen has shades mark just below centre I think it may be dust ?
Contact any service technician to clean it. You should disassemble it to clean it; and it is a skilled work.
Feb 17, 2015 | Televison & Video
Xerox 4150 my paper is a light shade of grey, what can it be thank you
Giacomos,
Is the paper a shade of grey with no image? or is there an image with a grey background?
If there is a image with a grey background you should try a new toner module. If that doesn't resolve the issue, clean the xerographic drum, make 10 blank copies, if the cleaning doesn't resolve the issue than install a new xerographic module.
Hope this help.
Apr 05, 2011 | Xerox WorkCentre 4150 Black and White...
My sahara Flatbed Scanner works fine except that I cannot find how to print without a "grey:" background. What should I do to print with a clear white background? Eric Schafer. Cape Town RSA.
you will find if you reduce the dpi the scanner is scanning the pictures or documents in, that you will not get a grey background , as you describe, what it is printing is actually the paper itself, if you have it set for say 1200 dpi then reduce it to 600 dpi or even 300 dpi and you will see the difference when you print it
or only select the exact area you want to scan in the document, click preview then move the scan area selection box to exactly fit the picture you want to scan
Mar 27, 2011 | Office Equipment & Supplies
My Xerox 8400 is printing the wrong colors. Where it's red, it's printing a brown shade and where it should be grey, it's printing green. My logo is grey and red and it's printing all grey, but not the...
Try printing a light stripes test page (Troubleshooting, print quality problems, troubleshooting print quality page).
If you do not appear to have many missing jets but the colours are all just wrong it may be that the ink has gone stale. Run a couple of head cleans and you should see the colours start to improve. If it is getting better, all you can do is keep running head cleans until you have replenished all the ink in the printhead well.
This problem is common in situations where a lot of black and white printing is done, with very little colour.
Alternatively, it could be that your wiper/cleaning blade is not cleaning the head properly and is smearing the different coloured inks across the head, or possibly that your printhead is leaking colours but I think the first solution should solve your problem.
Hope this helps.
Dec 09, 2010 | Xerox Phaser 8400 Laser Printer
Dark Background on the paper
replace the drum unit (toner) your drum is weak causing dark background
Nov 21, 2009 | HP LaserJet 4 plus Printer
Paper turns gray
it is written in the Manual:
If the amount of background toner shading becomes unacceptable, the procedures described below may help to clear the condition:
* Increase the density setting. This will decrease the amount of background shading.
* Change the paper to a lighter basis weight.
* Check the printer's environment' very dry (ow humidity) conditions can increase the amount of background shading.
*Replace the toner cartridge.
*Replace the transfer roller
i hope it can help.
Regards,
sabeteh
Mar 28, 2009 | HP LaserJet 4 plus Printer
A Very light Grey shade/Ghost like residue on glossy paper but not reg paper
I have looked and this problem confused me to no end.
I started searching through engineering notes from Xerox and found this line which I am copying and pasting.
This is not my opinion I can send you the entire report if you wish.
But sadly here is the answer.
Although supported, glossy paper will exhibit background toner and is a limitation of the printer technology.
Apr 12, 2008 | Xerox Phaser 7300DN Laser Printer
Getting grey background on documents when copying
If you are getting a grey back ground, this means you have the wrong setting- the scanner is seeing a 'photo' image. look at your controls for TEXT or LINE
Apr 17, 2007 | Epson Stylus RX425 Multifunction...
Xerox Phaser 2135N Laser Printer Logo
641 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
