DVD player works fine for a few minits, and then starts to scan and picture is pixelated
  • subgenre Feb 20, 2008
    Dubbing from HDD to DVD, picture on DVD is pixelated even though fine on hard drive. Plays without pixelation on another DVD player, but when played on the JVC is pixelated.
  • 979 Answers
Optical probem most likely..This situation is usually caused by a lack of information from the optical p/u assembly. Could be as simple as dirt, or it's time for a new drive..accordiaman
Posted on Feb 08, 2008
I have a Samsung DVD-v5650 which has always worked great. A couple of days ago, it suddenly stopped playing dvd's. We purchased a new dvd and it will start to play, then it will get choppy and show...
That sounds like a classic case of DVD laser and spindle motor failure (traverse unit). The squares you mention are pixels, the picture pixelates and breaks up, then freezes (caused by voltage changes in the laser and the motor speed). Being as this is not a DVD recorder, it is probably not economical to repair. You can try carefully cleaning the laser assembly (tips on how to do this may be found elsewhere on FixYa or similar forums) and/or spindle hub. If that does not solve the issue, sadly, you would be reduced to just the VCR part (or you could purchase a new player since the cost of such would be cheaper than repairs to this - assuming parts were available).
Not the best news, but you can try the simple in-home cleaning of the unit first before taking any further action.
May 19, 2011 | Samsung DVD-V5650
My memorex combo dvd & vhs player is not working right. can you help me? the vhs player works fine, but the dvd player display's a split screen on the tv with a large yellow box with the word PSCAN....
PSCAN is a short form for Progressive Scan - a line scanning format used for High Definition TV. Standard TVs use Interlaced scanning. On your DVD/VHS player, the VHS is an analogue signal recorded in interlaced mode so is fine for a standard TV. The DVD is a digital signal and cazn be processed for progressive scan output in order to produce a better picture on a High definition TV (or a TV capable of handling progressive scan). If you cannot to your TV via the HD outputs then you should be able to set the DVD player to output interlaced instead of progressive scan.
Mar 05, 2011 | Memorex MVD4540 DVD Player/VCR
DVD plays with green stripe and pixelation
try turning off / on progressive scan. You could also change the Scanlines in the settings / display menu until u find one that clears up the issue.
Its more than likely a settings issue.
Mar 02, 2010 | Philips Magnavox DVD/VCR Dual Player
DVR making bad DVDs
Three suggestions:
1) take it apart and clean the laser and the spindle 'hub' that the DVD rests on
OR
2) get a 'cleaner' disk that will 'whisk' any dust from the laser diode.
OR as a final suggestion
3) replace the DVD recorder with another. Plain old EIDE parallel interface units fit fine.
This is a very friendly machine in that it will accept PC compatible hard disks and DVDR drives.
tom
Feb 04, 2009 | Polaroid DRM-2001G DVD Recorder/HDD...
DVD Player Stuck In Progressive Scan Mode
A simple solution that works with electronic items many times, so give it a try. Turn Off your player, un-plug the electrical supply, wait about 2 minutes then re-connect the electricity and turn on the player. Many times this will force the machine to reset itself. This technique can be used for ALL electroinc devices.
Jan 16, 2008 | Zenith XBV243 DVD Player/VCR
Split screen from DVD player, cable is fine no problem
The progressive scan can work only throug progressive scan CTV.. while some of the newest DVD player today has a progrissive... now you must turn OFF the progressive scanof your DVD on the set-up menu to see the real screen display.
Jan 07, 2008 | Televison & Video
Pixelated picture
jensen is not such a great brand for indash. if you have the receipt or warranty you might want to return it and get yourself a new one. I know this because when i bought my phase linear i didnt want to eject the cd and the guy told me that they come very defective sometimes
Dec 07, 2007 | Car Audio & Video
BAD PICTURE QUALITY
jagged pictures indicates pixel incorrect
get the screen menu up and adjust the pixel settings
Dec 27, 2017 | Samsung DVD-HD960 DVD Player
DVD/VCR combo player won't work
I had a similar problem and corrected it with a solution found on another site. Try hitting the I/P button on the remote which controls whether "Interlaced" or "Progressive Scan" is used to display the image on the TV. Mine worked when "Interlaced" was used. but no picture was displayed when "Progressive Scan" was used. The I/P button toggles between the two settings.
Dec 19, 2006 | Apex Digital ADV3800 DVD Player/VCR
Televison & Video Logo
143 people viewed this question
Top Televison & Video Experts
Electro Med Services...
