Question about HP LaserJet 3055 All-In-One Printer
ADF when you put the paper in the ADF and hit copy it puts a line in the page. but when you set the paper on the scan bed and hit copy it prints the page just fine with no lines
  • 168 Answers
There is something on the small slit glass. There should be 2 pieces of glass on the copier. One where you place your original, and the other is a small slit glass about a 1/2" width by 9" long. Check the small glass to see if there is anything like a spot of black INK or a dot of white out on there. There is something on the small piece of glass that is causing your line problem.
Hope this helps.
Good luck.
Mac
Posted on Feb 08, 2008
Error message with canon mx410 "cannot scan from adf"
I fixed this by changing the Copy Intensity from Auto to Manual
I had the same paper jam (caused by pressing Stop during a page going into the ADF), but I had pressed OK as instructed and the page was auto fed back out again. Then I couldnt copy from ADF after that.
I tried everything, and then started to retrace my steps of all the things I might have tinkered with to try and get the copying working in the first place, before the paper jam.
Then I remembered I had set the Copy Intensity from Manual to Auto (thinking Auto is always best). With hindsight, it now makes sense for it to be manual with the ADF as otherwise how would it load a page, use it to set auto density, and then reload it again for the actual copy to occur. This happens okay on the flatbed scanner as it can scan a little, work out the settings, and then scan for real.
Copy Intensity is reached on my Canon MX from the Menu button at the bottom left of the front panel. - Then press the right arrow twice to get to Color Intensity. - Hit OK. - Then right arrow from "Auto" to "Manual Adjust"- Then pick a setting or leave it as half-way between light and dark- Press OK
Now every time my ADF copying works a treat. Thats what I get for tinkering in things I didn't need to change in the first place. I was just trying to get a quick copy going from ADF to paper without saving a file up on the computer and then printing.
Aug 09, 2012 | Canon Pixma MX410 All-In-One Printer
My HP laserjet 3050 when i copy a page the paper prints black
Symptom: Black or Blank image while copying or scanning.
Part suspect rating: Scan head..70%
Scan head cable...25%
Formatter...5%
For tech guys only: Remove ADF unit from the printer, remove both side covers of adf, remove & replace scan head, check...
Replace scan head
Jul 21, 2012 | HP LaserJet 3050 All-In-One Printer
Scanner leaving black streaks
There are two possible fixes.
Download the latest firmware update by CLICKING HERE
The following is provided by courtesy of Lexmark:
Problem Vertical lines; Auto document feeder scan anomaly; ADF scanning problem; Scan issue; Scanner issue; Visible line; Streaks show on page; solid line down the page; Top to bottom line; Smudge runs down the page; Opaque line; Broken line; Bar all the way down the page Solution Overview
This article provides the self-diagnostic steps necessary to evaluate top-to-bottom streaks that appear when copying or scanning.
Important! This is seldom a scanner hardware failure.
The main reason for this anomaly is debris or marks on the scanner glass that is used for Auto document feeder (ADF) page scans.
Printed or Scanned Page Illustration
Who should consider this article?
Any user of an MFP or All-In-One printer experiencing the following symptoms:
  • -Vertical lines only when using the Autodocument Feeder (ADF).
  • -Observed with any type of scan job (e-mail, ftp, solutions, fax).
  • -However, normal expected output when the page is scanned from the scanner flatbed.
ADF scan behavior
Think of it this way:
  • -The page is pulled from the ADF.
  • -The moving page slides across an ADF-designated portion of glass.
  • -The image sensor, which is located under the glass, reads and interprets the moving page's contents.
  • -Contamination on this ADF glass is seen by the image sensor for the entire length of the page.
  • -The image processor interprets the image sensor's repeated capture of this contamination as a vertical solid line.
  • -Any ADF scan function now exhibits a vertical line.
Suggested Diagnosis and Fix
Step Action 1 Locate the portion of the glass designated for ADF scans.
HINT: The glass location differs by model. This area is often separate from the scanner flatbed. Please reference User's Guide for more information if you are having a difficult time locating this designated area.
2 Perform a visual inspection for any of the following recurring culprits:
  • -Clear adhesive tape
  • -Glue
  • -Ink pen
  • -Paper
  • -Marker
  • -White out
  • -Staples
  • -Environmental dust or dirt
HINT: Ink marks can be especially hard to see and almost translucent at first sight. However, the image sensor (CCD) registers them as a mark. 3 Use a clean, soft, moistened cloth to thoroughly clean and remove any marks or debris. 4 Inspect the underbelly or underside of the ADF for any marks or debris. 5 Perform another scan to see if cleaning the glass alleviated the issue. 6 Repeat the procedure if a vertical line still appears.
Remember! Printing and scanning from the scanner flatbed work fine.
7 This time, place an intentional mark on a blank sheet of paper and take note of its location. Now place that sheet of paper in the ADF and make a copy.
8 Evaluate the distance of the vertical line to the your mark. 9 Inspect that area of the glass for further debris or marks and clean as necessary.
Other Possibilities
If... Then... Vertical lines appear only when printing... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support. Vertical lines appear when you lay the page on the flatbed... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support. Vertical lines appear on ADF-fed printed copies, but they do not appear on scan-to-network [e-mail, FTP, folder (PC), solutions]... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support.
May 01, 2012 | Lexmark International LEX90T9005 Inkjet...
My feeder to scan puts a line down the entire document - the line doesn't appear when I scan from the deck of the printer. I've attempted to clean the rollers but the line still appears on my document?
You don't say what kind of printer you have.
So, I will generalize my answer.
The reason for the line using the ADF and no line with the flatbed is that the paper is moving when using the ADF. So, a piece of dirt, dust or whatever on the ADF glass will cause a line because the paper is moving over a mark on the glass. The copy made on the flat bed glass doesn't move, so no line.
Anyways, clean the thin piece of glass that should be to the left of the big flat bed glass. That will fix your problem
Jan 20, 2011 | HP Office Equipment & Supplies
When making copies using the ADF, vertical lines print out on the paper. Doesn't happen when paper put directly on the glass.
The ADF works by moving the paper past the scanhead, on glass works by moving scanhead past the paper.
When you are scanning with ADF, the scanhead is parked in a particular position, under the glass. Just at one extreme end. Open the unit to te point that you are able to clean the lint, debris, lollipop sticks from this area. That should be it, since works otherwise indicates a good scan head.
Nov 02, 2009 | Canon ImageClass MF5770 Laser Copier...
Can't work out how to use the multiscan? I press scan and it comes up with multiscan and I put the first piece of paper in but don't seem to get asked for any more sheets and it therefore just scans one...
Anita,
Put the pages in the "multiscan" all at once, not just one sheet at a time. The Automatic Document Feeder (ADF) will feed one sheet of your document at a time untill all of the pages are scanned...
Thanks for using FixYa!
Oct 26, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Vertical line appears in scans using the ADF, but not with copies
happened to me after i fed a page with not-too-hard whiteout on it. the feeder makes the page run through a different piece of glass and i just had to clean it.
Aug 18, 2009 | Brother MFC 7840W Printer
HP Laser Jet 2840 Printer
If it's scan and copy only and not when you send a job from the computer your solution is easy to remedy. Try going into the menu located on the printer to info menu. Scroll down to conguration page and click the check button. When the printer prints, if the line is not on the page you simply have ink or white-out on the scan glass for the ADF (auto doc feeder).
To clean the ADF glass, lift the top lid to expose the glass. There are two peices, 1 large full size and one strip peice. If your getting the line when using the auto feeder (without lifting top) pay close attention to the strip of glass. When a document is auto-fed it moves the original past the strip of glass. A dot (pen mark or white-out) will appear as a line on your final copy.
Clean well with windex or similar glass cleaner. PUT THE CLEANER ON THE RAG THEN THE RAG TO THE GLASS. Don't spray the glass as it's easy to get it into cracks where to don't want it to fall on an electronic part or board below the glass edges. While you at it, clean all the glass.
Test by making a copy of a "BLANK" sheet of paper with one small line to give you postion clues. First by putting it on the glass. Clean everywhere on the large glass that shows a mark on the page (except the one you purposely put there). The mark will help you locate where to clean. (example - 1" below and 2" over from your intentional mark) It also helps you identify top of page from bottom.
Once that is done do the same thing using the original in the ADF. Simply measure in from the edge of the page on the copy and find the corresponding spot on the small strip of glass.
IF YOU SHOULD BE GETTING THE LINE IN ALL FUNCTIONS, PRINT, COPY MANUALLY, AND COPY WITH ADF. Check the toner cartridge, most likely black for damage on the cartidge drum. The cartridge drum can be quickly viewed by flipping the shutter open (the part with the HP logo and part number printed on it). If there is a line, replace the cartridge.
Hope that helps you. If so hit it with a FIXYA!
Thanks,
Aug 30, 2008 | HP LaserJet 2840 Printer
ADF will only feed one sheet then stop
no,just try to clean the roller of the ADF at the same time the separator pad.make sure that you are using paper that is 24lb weight coz if you are using paper that is so thin if may cause also an issue that the ADF could not pick-up...if the issue is still occuring return/replaced the printer...
send feedback for further troubleshooting...
Aug 23, 2008 | HP Officejet 6310 All-In-One InkJet...
ADF Usage
Put the paper in the automatic feeder. In the software options, click on ADF (automatic document feeder) and it will scan multiple pages.
Jun 06, 2008 | HP LaserJet 3030 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
161 people viewed this question
Ben Johnson
