From the sounds of things, you are talking about a front loading dryer. The agitators in the dryer can get coins stuck inside them. Remove the top and rotate the drum to reveal the screws which hold the agitators to the drum. Remove the screws and the agitators, empty the coins or other debris and reinstall.
The loud squeal sounds like the pad under the open side of the drum is worn out. There may also be a dry main bearing in the rear of the dryer. Lubricate the bearing and reinstall the drum. The squeal should disappear.
If this is not a dryer or a front loading washer, none of these suggestions will apply, Sorry
