Question about Dell Latitude C640 Notebook
How to re-enable VGA display it was disabled accidently
The VGA display was disabled now after start-up screen I can not see my desktop - screen is BLANK GREY. How can I re-enable so I can see log on screen again after initial WinXp screen.
Thank you!
  • 3 more comments
  • DCA4lyfe Mar 05, 2008
    I am having the same problem. When I disabled the NVIDIA card because of some errors my computer started using VGA display but then i disabled it thinking it would re-enable the NVIDIA display but now the only thing i get after the XP logo is a blank screen. The blank screen appears but the computer seems to be running because i can hear the startup sounds and etc. In this case I have a Dell Dimension 8200 desktop. I already tried going into the BIOS menu to try and re-enable VGA but there is no option. Please help me out.
  • Anonymous Jun 24, 2008
    vga disable and blank screen.  help!!
  • trainguyone Jul 02, 2008
    my dell c640 latitude display screen is only showing at the center about 5in. x 4in. the display shows all of windows but need a maginfier glass to read it . help ?
  • fixzulu Jul 04, 2008
  • Anonymous Sep 07, 2008
    I cannot enable my display screen. My computer say's administrator disabled.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 171 Answers
In bios settings there is a option enable or disable onboard display card check , one more option is there press F8 key when you are restarting the system some options is come their select enable vga mode
Posted on Mar 11, 2008
  • sajjad_khoso Jul 13, 2011
    bus enable or option yes & no is not show on screen wy? plz upload screen shoot this wap plz i press f8 and select enable vga mode & enter bus later no show yes / no way
  • 178 Answers
When your computer start up o you see a Dell logo??? I can help you please respond back to me thanks
Posted on Feb 10, 2008
2 Suggested Answers
pkbytes
  • 45 Answers
SOURCE: Dell c640
By default Windows XP displays the Graphic login screen with icons and usernames at startup.
If you would like to use the more traditional Windows NT login screen you can get to that screen by pressing Ctrl Alt Del (Reboot key sequence) twice.
If you would like to change to the traditional screen at login, instead of the graphic login screen, do the following:
  1. Log in with administrator access.
  2. Click on Start, Control Panel, and select user accounts.
  3. Click on Change the Way Users Log On or Off.
  4. Click on the Box "Use the Welcome Screen" so that there is not check mark.
If you would like to switch from the traditional login screen to the more graphic screen just click on the box in step 4 above so the "Use the Welcome Screen" box is checked
Cheers-Parveen
Posted on Feb 08, 2008
Accidently disabled display screen on my laptop and also disabled the external Vga, how can I enable them now that I cannot see anything, ps...they both show in setup utility. Compaq Pressario V6000.
Normally you can switch between internal and external screen by holding the fn-key Down while hitting one of the function keys with a Screen symbol on (f7 or f8)
Sep 22, 2013 | HP Compaq Presario V6000T Notebook
EV3A GT520 video card installation makes my screen go blank. My gateway computer has an integrated chip for video, and does not even recognize the new card but its plugged in, fan working, etc.
some bios settings disables the add on video cards. to enable them go to bios setting by pressing DEL or F12 while power on your system. (u will see that a message appears "press ----- Key to enter bios settings). after entering bios setting u will see onboard VGA enable/disable. u have to disable onboard VGA in order to get the display thruogh VGA card.
Sep 21, 2011 | Nvidia GeForce GT 520 1 GB DDR3 Video Card...
My laptop monitor has vertical lines all across it, so I have an external monitor, how do i connect it to the laptop
Connect the VGA cable to the VGA port of the laptop then restart the computer.
Go to display properties and enable the second screen, then disable the notebook screen to display only on the external screen.
Nov 18, 2010 | Computers & Internet
I HAVE D845GLVA Motherboard. Its on board display
You have to enter the bios. (F2) during P.O.S.T. enter the setuo and usually it is under legacy options.
Jan 29, 2010 | Intel Desktop Board D845GLVA...
Nvidia 6200 gap graphics card not recognized under WIN XP
DId you hook up the secondaary power supply on the side a 5 pin 1/2 inch in width?
Nov 20, 2009 | AMD eMachines Desktop System w/ 17'' CRT...
My monitor is displaying sideways on a hp montior
It sounds to me like you have Hotkeys enabled and accidently pressed them.
To rotate screen view you can do the following using the keyboard arrow keys in conjunction with pressing CTRL key and ALT key at same time:
Ctrl-Alt-Up - right side up
Ctrl-Alt-Right - 90 degrees
Ctrl-Alt-Down - 180 degrees
Ctrl-Alt-Left - 270 degrees
To locate HotKeys and disable navigate here:
Start >> Control Panel >> Display >> Settings >> Advanced
Subject to your monitor/graphics card you may need to click a few mor tabs to see HotKeys.
Hope this helps. Best Regards -md
Nov 10, 2009 | HP dx2250 Monitor Personal computer AMD...
My fujitsu dont start vga
When you power up the computer press F8 key then enter in enable vga mode then go to start ->control panel ->display ->settings .
Change screen resolution to 1024*768.
Then apply and ok.
But if you are not able to see any display so you need to refix RAM memory if you are able to enter in safe mode or enable vga mode then there is only issue with graphic driver.
Let me know if you need more assistance.
Thanks.
Oct 22, 2009 | Fujitsu Siemens SCENIC P300 PC Desktop
How to re-enable VGA display it was disabled...
hold f8 and select use last known settings that worked.
Jan 22, 2009 | Dell Latitude C640 Notebook
Trying to connect Inspiron 6000 to TV
If there is no display on your TV, HDTV, or Projector, please make sure that all of your connections are set up properly and that you have enabled the display in the Catalyst Control Center. The connectors that you will be using would be Svideo for TVOUT, DVI-to-HDTV (Component video), VGA-to-HDTV (Component video) for HDTV, and DVI, VGA, or Svideo for the projector.
737-22474-1.jpg Here are the steps to properly setup and enable TV, HDTV, or Projector:
  • Turn off your PC and your TV, HDTV, or Projector.
  • Ensure that your card was installed correctly, as per the Getting Started Guide.
  • Determine if your TV, HDTV, or Projector has a S-Video (for TV), YPbPr for (HDTV), or VGA/DVI for Projector.
  • Looking at the back of your PC, locate the needed connector or the supplied adapter cable; attach one end of the cable to your graphics card and the other to your second display.
  • Turn on your second display then your PC.
If you are connecting an HDTV to your video card, please Click here for detailed instructions on how to set it up correctly.
Starting Windows with TV or Projector Display Enabled The TV screen may become scrambled during the initial Windows® logo display. This is only a temporary effect and your screen will be restored within a few seconds. During start up, your RADEON will go through a sequence of mode settings, during which your TV display will remain blank. This process takes only a few seconds and helps program the TV display.
  • To enable the second Display
  • Right-click anywhere on your desktop
  • Click Catalyst Control center
  • View
  • Advanced view
  • Display manager
  • Detect Displays
  • You should have the second display picture under “Attached displays currently disabled
  • Drag it to the box on top of it
  • Apply
  • OK
If for any reason the second display does not get detected, please do the following:
  • Open the CATALYST CONTROL CENTER
  • Go to Display options
  • Check “Force TV detection” *
  • Apply
  • OK
* Force TV: Allows you to force TV detection if the ATI driver does not automatically detect TV-out connected to the graphics accelerator.
Possible issues:
In case the users display does not natively support HDTV display timings in the EDID, you can add standard HDTV modes so that the usual HDTV resolutions (720p, 1080i, 1080p) are listed in the Display Manager resolutions. You can also create custom HDTV timings to solve any kind of over-scan options (for cases when the windows desktop appears to not fit on the HDTV screen, and the outside boarder is cut off).
For more information on connecting your second display to your Video card, including supported output device combinations, please refer to your user’s manual.
Jan 23, 2008 | Dell Inspiron 6000 Notebook
No signal to monitor
  1. Verify card is seated properly.
  2. Check bios settings. ie. disable onboard video, enable PNP OS installed, enable "assign IRQ to vga", disable shadowing and caching, enable passive release, enable delayed transaction, vga boot sequence: AGP, set graphics aperture size to 128MB, disable turbo modes.
  3. Verify power supply is at least 350 watts.
  4. Reboot into safe mode (press F8 right after the BIOS POST screen and before the windows loading screen) and use the program, Driver Cleaner Pro to remove Nvidia video driver remnants. Don't select all of the options, just the Nvidia driver and the plain ATI selection.
  5. Verify the monitor cable is securely connected to both the monitor and the computer.
  6. Verify that you have connected the cable to the vga port on the card and not the onboard vga port. (I'm not implying that you are dumb or anything like that, but sometimes even the best of us, overlooks the simple things... especially me! LOL)
  7. Verify the monitor cable is good.
  8. (Last but not least), try using another monitor to test. (Could be an incompatibility with the monitor.)
Jan 02, 2008 | ATI RADEON X1650 Graphic Card
Dell Latitude C640 Notebook Logo
2,977 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
