input protection circuit is blown , see if you can find fusible resistor and check for open circuit (should be 1kOhm) - big resistor on the right straight from the Volts input
1. make sure that all buttons can be pressed freely (not stuck) 2. make sure when measuring AC current that you press AC button and AC sigh is on LCD 3. make sure that jaws are closed completely 4. clamp meters use Hall effect and can only measure current flowing through ONE conductor (you cannot measure current around power cord (which has 2-3 or more conductors) 5. when in DC setting and you turn zero knob does value changes (it should)
Normal
0
this is how
ive changed the time before, note that you dont see the number you type
in.
Press
FEATURE**8463 – Display shows
PASSWORD: Then type in
23646(Note this number will not show on
display) The display
will show
hours. Press
CHANGE (or NEXT if you do not need to change the
hour). Enter the hour
(00 to 23). If number is less than 13, the display shows
AM. Press
CHANGE to select PM. Press
NEXT. The display shows minutes. Press
minutes). Enter the
minutes (00 to 59). Press
NEXT. The display shows year. Press
year). Enter the last
two digits of current year. Press
NEXT. The display shows month. Press
month). Enter the
month (01 to 12). Press
NEXT. The display shows day. Press
CHANGE. Enter the day
of the month (10 to 31) Press
RLS (release) to exit.
i had this problem a while ago, you have to set the time from the main phone
Press FEATURE**8463 – Display shows PASSWORD: Then type in 23646(Note this number will not show on display) The display will show
hours. Press CHANGE
(or NEXT if you do not need to change the hour). Enter the hour (00 to 23).
If number is less than 13, the display shows AM. Press CHANGE
to select PM. Press NEXT.
The display shows minutes. Press CHANGE
(or NEXT if you do not need to change the minutes). Enter the minutes (00 to
59). Press NEXT.
The display shows year. Press CHANGE
(or NEXT if you do not need to change the year). Enter the last two digits
of current year. Press NEXT.
The display shows month. Press CHANGE
(or NEXT if you do not need to change the month). Enter the month (01 to 12). Press NEXT.
The display shows day. Press CHANGE. Enter the day of the month
(10 to 31) Press
