Question about Garmin GPSMAP 60CSx GPS Receiver
Compass dosent work
When i turn my compass on it tells me to "hold level" nomatter how i hold it
  • shawnwhitney Feb 10, 2008
    it was nothing more than a calibratinon problem....problem solved
    Novelist:
  • 113 Answers
The compass is very sensitive. Anything magnetic will intefere with its ability to calibrate. Try taking the unit outside, far away from anything metallic, and lay it down on a flat level surface, then follow the compass calibration procedure. Make sure you rotate the unit clockwise and turn it very slowly. If that doesn't work, you could have a defective sensor.
I'm not sure what you're using the compass feature for, but on mine I disable it. It draws the batteries down faster and I find that my track, or course over ground, is more reliable than the compass heading. The only real advantage to the compass is if you want to get a bearing while you are standing still.
Posted on Feb 08, 2008
Have a 1999 dodge cummins 2500 pickup and the temp/compass on roof is frozen wont change display numbers can go though the options though
If the compass is working and the thermometer is stuck (or wrong), it probably a bad sender which is located behind the bumper on the driver's side bolted to the radiator support.
If the compass is not responding, it will probably need to be recalibrated and might need to reset the VAR. You can try to recalibrate first but if you have the owner's manual handy, go ahead and do the whole thing.
In the owner's manual there is a VAR (variation) code to tell the truck which part of the planet you're in so it will be accurate. Locate that code and then do the following:
To reset the variation:
1. Ignition on.
2. Hold down both buttons (US/Metric and Comp/temp) until VAR appears. (about 5 seconds)
3. Release both buttons. VAR remains.
4. Press and release the US/metric button. VAR1 appears. Press and release the US/metric button until the correct VAR is shown.
5. Press the Comp/temp button to store the new variation.
To recalibrate:
1. Start the engine.
2. Depress both buttons until CAL appears, about 5 seconds after VAR.
4. Drive the vehicle on a level surface, away from large metal objects, through three or more complete circles in less than 48 seconds. The CAL message will disappear from the display to indicate that the compass is now calibrated.
Jan 30, 2015 | 1999 Dodge Ram 2500 4WD
2006 Expedition overhead compass reads "N" when heading "E". Wonder how to reset it so it indicates the direction accurately.
Yes. Wish I could tell you which button for sure, but to reprogram the Compass you hold one of the buttons and drive in a circle one or two times to reacquire your position.
Apr 08, 2013 | 2006 Ford Expedition XLT
IPHONE DOSENT TURN ON
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Sep 28, 2012 | Apple iPhone 3G
Screen jumping
Make sure your cables are plugged in well. You might need a new set of connector cables, and you could probably get some of these on ebay pretty cheap. If that dosent solve it(which it should) your n64 might be kicking the bucket.
May 24, 2009 | Nintendo 64 Console
Compass out of whack
You need to recalibrate the compass. The procedure is in your owners manual. Here are the basic steps.
First, you will need to verify that your compass zone is set to your current geographic location. Since I do not know where you are located, I cannot tell you the code. They are listed in the manual. (For example, So Cal is zone 5.)
Second, here is the compass calibration adjustment procedure:
Perform this adjustment in an open area free from steel structures and high voltage lines. For optimum calibration, turn off all electrical accessories (heater/air conditioning, wipers, etc.) and make sure all vehicle doors are shut.
1. Start the vehicle.
2. To enter the compass calibration mode, press and hold the button for greater than eight seconds. The display will then show CAL in the display window.
3. Drive the vehicle slowly (less than 3 mph) in circles until CAL indicator turns off. As many as 5 complete circles may be required.
4. The compass is now calibrated.
Dec 19, 2008 | 2005 Ford F-150
Compass calibration
Hello. First day I use this device, and have found this tips for compass calibration (as I understand, compass calibration depend on satellite signals - so before compass calibration it's better to get good signals from satellites):
- keep device at horizontal plane (as from message "hold level");
- turn it slow, but not too very slow.
It's better don't turn device, but get device at hands, and turn around himself with it with constant slow speed, and keep horizontal level of device - by this way I have a more accurate calibration, than turn just in hands or on the table.
I hope this will help.
Jun 23, 2008 | Garmin GPSMAP 76Cx GPS Receiver
60CS
Your electronic compass is probably turned on, and if so, either it is not calibrated or you are not holding the GPS unit level.
Try turning off the electronic compass by holding the PAGE button in for a couple seconds. With the electronic compass turned off, the GPS will instead show direction of travel using the current track, which is probably what you are expecting.
Cheers!
May 30, 2008 | Garmin GPSMAP 60CSx GPS Receiver
Garmin HCx GPS unit
The Vista HCx has an electronic compass. You don't need to be moving for it to work, but you do need to calibrate it. To calibrate the compass:
  1. Go to the Main Menu
  2. Select Setup
  3. Select Calibration
  4. You will be asked "Which Sensor Would You Like To Calibrate", select Compass
  5. You will see a page that says "To Calibrate Compass: Slowly Turn Two Full Circles In The Same Direction While Holding The Unit Level", select Enter and do this.
You need to hold the unit level for the Magnetic Compass to work correctly. The specs for a properly calibrated compass are +/- 5°
May 15, 2008 | Garmin eTrex Vista HCx Handheld GPS...
Sight n go as described on page 16
Make sure you are outside with a good bunch of satellite and it should work.
If not go to the compass page and restore defaults.
Calibrate your compass if you have one,
Mar 24, 2008 | Garmin eTrex Summit GPS Receiver
Compass wont work correctly
if your hands aren't straight when you use the compass try this to sync the hands.
1. Press and hold the middle button to enter T-Touch mode.
2. Press the centre area on the face twice to display 24hr/12hr
3. Press and hold the middle button to enter T-Touch mode untill screen says sync.The hands will face 1200.
4. Press either the upper (East) or lower (West) button to adjust the compass hands. They should both face 1200.
5. Press the middle button to get back to 'regular' compass mode. Note that your offset setting will still show in the digital area.
Oct 10, 2007 | Tissot T-Touch T33759851
Garmin GPSMAP 60CSx GPS Receiver Logo
168 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
