TOSHIBA 50" Upgradable PJTV (50HDX82)
"I have a 5 year old Toshiba HD Projection TV. It will not "power on".....the "technician"(I use that term very losely)states that typically an error message is displayed to pinpoint problems - but in this case - there is no message and the set is not receiving power. He checked fuses then called to say that the necessary "part" was no longer available by Toshiba.As such - the TV can not be repaired ??? Any ideas.
Thank you,
Al Strickland
bulldogs@carolina.rr.com
Thanks"
    President:
  • 4,402 Answers
Did you get any blinking lights?
hard to say what wrong, did he say what part he cant get or part number? since he can or wont fix it he should be able to give you the part numbers and description.
Posted on Feb 08, 2008
Toshiba pjtv picture not clear .. scan module is
if the tv is shifted from one place to another then this problem comes look out for operating manual it given in manual how to reset it
May 28, 2010 | Televison & Video
We replaced the red and blue convengence units on our Toshiba 50HX70 four years ago, the blue is out again is this worth repairing again? The TV is now nine years old
Yes,the tv still good.I rather spend 300-400 dollars.Than 1100-1200 for a new one.The average tv replacement about 15 years.Using 6-7 hours a day.
Feb 24, 2010 | Toshiba 50H72 50" Rear Projection...
My toshiba TP50H15 color tv comes on then off and the light blink
The flashing power light on those Toshibas is usually caused by capacitors on the power board having failed solder connections. I have fixed them before by removing the power board and resoldering the capacitors. If you have experience with soldering and electronics it is an easy repair. Most shops will recommend replacing the entire board since their labor to repair it would probably cost more. Toshiba put out a service bulletin on this issue which a good technician should be aware of. (If memory serves the capacitors are C109 and C110.  Since your TV still turns on you probably haven't blown fuse F860 which often blows when these capacitors act up.)
If you would like further help with this please post a comment back here.
Dec 05, 2009 | Toshiba TP50H50 50" Rear Projection...
Toshiba HD made a popping sound and went out.
Check the lamp to see if it popped. Try replacing it. Also check the web for class action law suit for these sets, Toshiba has an extended warranty for lamps for certain units.
Feb 18, 2009 | Toshiba 43H70 43" Rear Projection...
Toshiba Rear Projection TV Problem
common problems on toshiba are the stk ic and it is not ease to replace them you will need a technician
Sep 15, 2008 | Toshiba TZ50V51 50" Rear Projection...
Toshiba TP50H95 TV Won't turn on - Pete
You will need to trouble shoot the start up and shutdown circuits. Often this is a minor component failing causing the set to not power up or go into protective shutdown. Do you have the service manual for this TV?
Mar 01, 2008 | Toshiba TP50H95 50" Rear Projection...
Toshiba projection tv 50 inch
Something is preventing the power supply from operating:
Possible causes in order of likelihood:
1) Convergence amps failed overloading the supply (See if you can disconnect them)
2) High Voltage circuit has died. (Right on schedule since your TV is 10 years old)
3) One of the CRTs has shorted
4) The power supply itself has died (Is there a lot of dust covering it?)
See if you can isolate the failure by working down the list.
Hope Ya Fix it!
Jan 07, 2008 | Toshiba 50H72 50" Rear Projection...
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
