Question about Motorola Mobility RAZR V3i Cellular Phone
REMOVAL OF FRONT LCD SCREEN TO REPLACE WITH NEW ONE
HOW DO IT REMOVE THE FRONT LCD SCREEN TO REPLACE IT WITH A NEW ONE
  • Olin Feb 21, 2008
    I have a new RAZR front protective cover screen (LCD operating ok) to install. Screws (4) removed, but the "cover" does not separate from the rest of the flip top of the phone. I tried prying with small knife blade. Do I just need to pry harder or is there something else holding the "cover" on?
  • 2,130 Answers
Flip open the phone and look for (4) rubber plugs at each corner of the inner LCD screen.
Using a very small flat-blade screwdriver, pry these rubber plugs out and you'll see the screws beneath them.
Remove the screw and you should then be able to take the flip part apart. Be sure to put the plugs and screws in a secure place so that you don't lose them.
Please let me know if I can be of further assistance to you.
- Jim
Posted on Feb 08, 2008
You should put better directions..no offense!
Posted on Jun 20, 2008
Hi Salomi,
Thanks a lot for the extremely helpful posting regarding replacing the LCD screen. Great job man !!!
Today I could replace the LCD screen of my MotoRazor V3i without any problem.. And the besat part is that now it is working fine..
Posted on Jun 14, 2008
    Problem Solver:
  • 3 Answers
Here is an easy to use guide to use
http://www.hackthev3.com/pdf/Taking_the_Razr_apart.pdf
Hope this helps
Posted on Feb 12, 2008
How to replace LCD screen
To replace the the LCD screen of your laptop, You need to be very careful in replacing this screen. Please kindly follow the steps below to be able to guide You in replacing the screen.
  1. Shut down the Acer laptop, unplug the AC power adapter and all extensive devices.
  2. Remove the battery pack from the battery tray that is at the bottom of the screen.
  3. Open the display panel as far as You can open it.
  4. Pry the rubber screw covers from the display panel's front cover with a small, flat-head screwdriver.
  5. The front panel is the front plastic piece covering the LCD screen.
  6. Remove the Phillips-head screws fastening the front cover to the display panel.
  7. Remove the front cover from the laptop with your fingers.
  8. Remove the Phillips-head screws from each side of the LCD screen that fasten the screen to its metal frame inside the display panel.
  9. Tilt the screen forward, then disconnect the large ribbon cable from the connector on the back side of the screen.
  10. Peel away any tape securing the cable in place. Lift the screen out of the display panel.
  11. Place the new screen inside the display panel.
  12. Reconnect the LCD ribbon cable to the back of the new screen.
  13. Align the screw holes on each side of the screen with the screw holes on the metal framing inside the display panel.
  14. Replace the LCD screen's retaining screws.
  15. Replace the display panel's front cover, and its retaining Phillips-head screws.
  16. Then replace the rubber screw covers.
  17. Replace the battery pack, then reconnect all cables and devices to the laptop.
That is how to replace the screen of your phone.
Hope this was helpful. Thank You for using FixYa!!
Jan 12, 2011 | Acer Extensa 5620 Notebook PC
Tip
How to replace the lcd of n73
first remove the back housing then the front housing after removing the front and the back housing ,remove the battery,sim card and the memory card after that remove the screw using a tool that is compatible to your screw then after you removing the screw.Now push your plastic shim into the join at the top of the phone to lift the front cover out slightly. Then run the plastic shim along both sides of the cover to unclip it at these points too... Now have the front cover removed, like below...The LCD screen is held in place by a metal frame which needs to be unclipped around its edge for removal.The LCD screen will now be loose and can be removed. It will be attached to the phone by a ribbon which attaches like a plug and socket. Simply lift it upwards to unplug it.You can now lift away the LCD and replace with new. Reverse the whole procedure for reassembly..thats all thank you
on Jul 25, 2010 | Cell Phones
Hp pavillion dv6-1030us just order my new screen how do i take the front and back bezel off looking for a video link not finding all the screws on front thanks
The procedure to replace the display is outlined in the maintenance and service guide.
Refer to the Display Assembly beginning on page 81 for the "complete" disassembly instructions.
http://h10032.www1.hp.com/ctg/Manual/c01758220.pdf
The maintenance guide gives you step by step procedures to remove the monitor and most importantly... how to remove the bezel "properly".
Jul 21, 2009 | HP Pavilion dv6-1030us Notebook
Replacing lcd screen on HP dv4-1120us laptop
No Problem, it is good that you think then act as opposed to the other way around. For you LCD, I would go to Ebay, type in "HP dv4-1120us LCD", and see what i could come up with. For your removal Instructions, i can help you there. I can walk you through it. ----------------------------------------------------------REMOVE THE BATTERY-------------------------------------------------------- You wil want to identify some parts first. Look at your laptop, and you will see it is comprised of 2 components, a lid and a base. Looking at the lid, you will see that there is a small plastic frame around the LCD. On this frame there is Generally a few rubber bits, although you will need to look closely to see them. Take a philips flathead screwdriver and remove them. Underneath you will see some small screws, carefully remove them. Then slowly prise this frame off, known as a bezel. Then the rest is easy. Put your hand in front of the LCD, and gently tip the laptop. The LCD will fall into your hand. If it doesn't try to get it out with the screwdriver. Then, carefully holding the screen, remove any connectors that hold the screen to the board. Memorize what cable goes where. Put this LCD down. Get a new one from ebay, and carefully remove it from the packaging. Then hold it like you did with the first, connect the cables where they go, push it into place, place the bezel aka the frame back on, and screw it in. If the rubber is no longer sticky, regular glue such as crazy glue, or gorrilla glue will work. Place the rubber bits back on the screen and your good to go.
Please note that incorrect or loose cable placement could cause undesired effects. If a cable needs force to go in, check that this is the right cable, you may damage the port and cable. If lines or flickering occurs, check the connecter of the screen. Pull them out, blow on them, put them back in, if the flickering resumes, i would call the manufacterer from ebay, for a warranty refund.
Good Luck
Jun 18, 2009 | HP Pavilion DV4-1120US Laptop
I want 15.4" WXGA Acer Crystalbrite LCD (8ms/220-nit) monitor.
my acer crystalbrite lcd 8ms 15.4 is no longer in my laptop and i need a software so i could download a new one
May 26, 2009 | Acer Aspire 5315 Notebook
How to replace the front screen.
this website has all the info on how to disassemble the U900 and put it back together you can also buy the LCD and Case from them.
http://www.formymobile.co.uk/u900disassembly.php
Apr 09, 2009 | Samsung U900 Soul Cellular Phone
My LCD screen on my Archos 404 broke i know where i can get a replace ment (newmp3technology.com) but i don't know how to fit it in to archos. can you help, thank you
1. get a LCD screen from newmp3technology.com
2. use a bit of card or credit card and slide it between the LCD screen and the front this removes the glue
3. remove four screws on the sides
4. remove the back
5. lift the battary and unplug
6. lift the hard drive
7. remove the two screws in the corners
8. now you can remove the front
9. lift the LCD screen so you can see the cables
10. slide the cable out of its housing
11. to put the new screen in follow numbers 10 to 3
when removing the glue or the front of the archos do not touch the LCD screen as now its not fixed it will brake
Jul 19, 2008 | Archos 404 Digital Media Player
Hp pavilion dv 1000 screen replacment
Dear lotaman, I have searched the world to find an exact guide for your monitor but it is impossible. Neveretheless I have found the following guides and they should be more than enough to complete the task in hand anytime.
TIP: The ZV5000 looks and is very similar to the HP DV1000 screen so I would start from there. All guides are very nicely explained.
Please remember to remove the battery before you do any work with the laptop.
Regards
Removal Step by Step HP ZV 5000 LCD Screen
http://www.instructables.com/id/SJFP10QF49G0AOR/
Removal Step by Step Compaq V2000 LCD Screen
http://www.screentekinc.com/lcd-removal-instructions_en,compaq.shtml
Removal Step by Step Compaq DELL LCD Screen
http://www.laptoprepair101.com/laptop/2007/02/03/repair-notebook-lcd-screen/
Mar 25, 2008 | HP Pavilion dv1000 Notebook
Need to replace a cracked screen
WD-57731 & WD-65731 Front Disassembly
57” & 65” Models Screen Frame
Removal
1) Pull off the Speaker Grill.
2) Remove all the screws (b) from the
upper rear cover (except one at an
upper corner to support the frame).
3) Remove 10 screws (a) from the
front of the screen frame.
4) Remove the remaining ***** (b)
(supporting the frame). Carefully
pull the Screen Frame from the TV
and disconnect the ES and LE
connectors.
57” & 65” Models Screens Removal from Frame
1) From the rear of the Screen Frame remove 20 screws (a) from the top and bottom rails
2) Remove 6 screws (b) from each side rail.
3) Carefully lift the Screen assembly from the Frame.
MODEL: WD-52631 / WD-57731 / WD-65731
Screen Replacement
CAUTION: Wear gloves when handling the Lenticular Screen and Fresnel Lens.
This prevents cuts and finger prints. Do not place Fresnel Lens in the sun.
This may cause fire and heat related injuries.
Lenticular Screen and Fresnel Lens Replacement
1) Apply LENS-TAPE along the rear top edge of the Lenticular Screen.
2) Place the Fresnel Lens on top of the Lenticular Screen, and apply pressure along the top edge.
3) Place the screens in the screen frame and reinstall the cushions, top, bottom and side rails.
NOTE: The Lenticular Screen label must face the front and the Fresnel Lens label face the rear.
4) Reverse the Screen Removal Procedure and insert the screens in the Bezel.
Lenticular Screen and Fresnel Lens Removal
1) Remove the top, bottom and side HOLDER-SCREEN rails and their cushions from the Screen Frame.
2) Lift the screens as a single unit from the frame.
2. Separate the Lenticular Screen and Fresnel Lens.
Note: When separating the Lenticular Screen from the Fresnel Lens, use caution
while prying the Screen and Lens apart. Use a slot type ***** driver, and
remove the pressure sensitive double sided tape.
Mar 11, 2008 | Mitsubishi WD-65731 65" HDTV
My lcd is broken on my sidekick !!!!!!!!!!!!!!!!!
Either buy the entire screen portion off Ebay which would only require you to remove the swivel portion and screen or just the LCD (which would be cheaper but a bit more work to replace, albeit simple). With a small screwdriver, remove the LCD from the phone by unscrewing the back of the screen and replacing LCD. You may still need to remove the entire screen from the base and as the swivel portion is on a coil, be mindful that it doesn't swivel after removal. I usually leave one of the screws in place to keep the screen from swiveling, otherwise, if it uncoils just wind the swivel portion to a moderate tightness and then reattach it to the unit after replacing the LCD.
Dec 03, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Motorola Mobility RAZR V3i Cellular Phone Logo
560 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
