Question about Kenmore 43142 Front Load Washer
Kenmore He2 shoots out water from the detergent compartment
I have a Kenmore He2 washer that of course is 2 weeks over warranty. When I turn it on the water comes shooting out of the detergent compartment. I checked the hose from the detergent area to the drum and it feels clean. I cleaned out the drain down the bottom of the machine and found a sock and some other things but when I ran the machine again in rinse and spin the water started shooting out again. I felt all hoses and they fell unclogged. Any other ideas?
  • 2 more comments
  • John Raitt Mar 01, 2008
    We used our machine this morning and found the same problem. While the dispenser was filling after a short time the water started pouring out of the front of the dispenser. We've taken the top of the machine off and assume that the hose is clogged that dispenses the water into the machine. Any solutions?
  • asante-nnuro Mar 15, 2009
    As soon as I turn on the machine, water rushes out of the detergent compartment and my machine is only 2 months old and it is a hoover washer dryer 8kg.
  • Anonymous Apr 16, 2009
    I love you guys. Thought I was having a huge flood - fixed it in two minutes. Next time I see you, I'll buy you a beer!
  • Anonymous May 15, 2009
    Same problem. I pulled the rubber ring back from the metal tub about an inch in the area below the detergent compartment. You will need to shine a flashlight up in that direction to see the 1" to 1.5" hole where the water fills the tub. I found a sock packed in this hole not allowing the water to fill the tub, which caused the water to run out of the detergent cpmpartment. It is a tight fit to get your finders all the way to the opening between the rubber ring and the metal tub. I took some needle nosed pliers and grabbed the sock and pulled it out. Problem solved for now.
Remove the ring infronf of the drum, then pull the rubber bit out a littile bit and then pass your fingers round the back towards where the detergent compartment is. Try and see if you can feel a solid object there and remove it, it is a build up of excess detergeng solidifying and blocking the water way to the machine
Posted on Mar 31, 2009
The detegregent compartment slides out - check to see there is not a backup of detergent clogging the whole. If so clear it out and problem solved.
Posted on Oct 29, 2008
After searching the internet we discovered that if you slide your fingers in between the metal drum and rubber seal under the soap dispenser area you may find the problem. We had a sock blocking the water inlet. Problem solved! This machine is going to give us a lot of headaches but thanks to the internet we may be able to continue to save money fixing it ourselves.
FYI, I find if you leave the door open a crack after each wash... you avoid the mold smell as well!
Posted on Mar 01, 2008
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
My Kenmore HE2 Pluse Front Load Washer is leaking water out of the Detergant compartment like it is overflowing.
sounds like the hose from the soap dispenser to the tub is blocked. might need the repairman for this one. anything you might try sticking in there to clean or clear it may damage it. also watch what kind of detergent and amount you are using. can cause problems.
Jun 01, 2011 | Kenmore HE2 Plus Front Load Washer
Water comming out of the detergent tray and not going into washer
TAKE OUT DRAWER ,,,CLEAN ALL COMPARTMENTS.. BE OK THEN ...CLEAN ALL HOLES ECT ITS JUST DRIED UP SOAP ALSO CLEAN INSIDE WERE DRAW GOES IN ...
Feb 27, 2011 | Kenmore HE2 Plus Front Load Washer
It is blinking F21 and wont work I have cleaned the drain hose and water is going through the hose there are no clogs
Some times this happens if you are not using he2 detergent. This is sepical detergent for front loaders.
May 02, 2010 | Kenmore HE2 Plus Front Load Washer
I have the kenmore HE2 front loader. when you turn it on now water comes pouring out of the detergent filling compartment and flooded the house... any ideas
there is a water inlet on the right side of the detergent filling cup to flush out the dry detergent. take out the fill and it is midway back on the right(little rubber hose) once you locate that take the top panel off and follow the hose, should lead to a silinoid. this is most likely sticking open, or the line is broken and dumping water into the washer cavity instead of in the detergent cup. hope that gets you started in the right direction.
Jan 17, 2010 | Kenmore 43142 Front Load Washer
Maytag Neptune wash machine. Clogged detergent compartment
This may not help much but here is the Maytag Neptune installation and service manual.
You may be able to better troubleshoot your problem with this.
It's a PDF document that may take a couple of minutes to load.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/dc59d905140253e18525729c005765f4/$FILE/Maytag_Neptune_Washer.pdf
Sep 28, 2009 | Kenmore 43142 Front Load Washer
When we start our washer water runs out the detergent tray
I had the same problem about a week ago and found a sock had made it into the drainage area (between the drum and the rubber liner inside the door).  Just peel back the liner near the inside edge and inspect the area with a flashlight to see if anything is there.
Mar 17, 2009 | Kenmore HE2 Plus Front Load Washer
F20 error on Kenmore HE2 front load for no reason
under top cover does it have flow meter? ck connection and resistence with ohmmeter, ck pressure sw.
Mar 14, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE2 110.4751
for the F10 code ? Unplug the washer open chech the funny noise / belt are worn out / slap to the brackets and other near obstacles . Replace belt broken.
Detergent leaking /ovewr flow clean w/ fish nylon # 150 just 40 cm /insert in the hole put water to soften the hard detergent forward and backward to clean detergent hose.
Nov 15, 2007 | Kenmore 43142 Front Load Washer
Kenmore 43142 Front Load Washer Logo
140 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
