Question about Motorola Mobility RAZR V3
Instructions for replacing Motorola V3 mini USB charger port.
  • 1 more comment
  • Ko Ko Feb 08, 2008
    Hi Jim
    It is surface mount. You are right. It is so small my smallest tip will not work.
    Hi Otacon,
    Thanks for the link. I still need the instructions for removing and reinstalling the mini port. Any ideas?
    Ko Ko
  • Anonymous Feb 11, 2008
    I bent one of the prongs in the usb charger for my v3. Now I need to replace it to charge the phone. What do you suggest?
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Do you have the replacement part?
    Many of these parts are surface mount components and can not be easily soldered with a standard soldering iron.
    Replacement of surface mount parts require heating the component and lifting it up from the printed circuit board. The same process is required to install a new part. The leads are very small and can not be soldered with a standard iron.
    Some of these parts have leads on the bottom of the part making it impossible to even gain access with a standard iron.
    If you have the new part, is it a surface mount part or leaded part?
    - Jim
  • 2,130 Answers
Here's some pages you might want to look at.
http://www.engadget.com/2006/03/07/how-to-make-a-surface-mount-soldering-iron/
http://www.daycounter.com/Articles/Solder-Surface-Mount-Parts.phtml
http://www.rcgroups.com/forums/showthread.php?t=643699
I have seen people use a paint stripper heat gun or heat shrink gun to desolder/solder SMT parts too.
- Jim
Posted on Feb 08, 2008
    President:
  • 1,944 Answers
Here is a guide that might assist you accomplish the task.
http://www.celtnet.org.uk/mobile-phone/disassemble-motorola-v3-2.html
Good luck.
For v3 razr charger can you use it with htc touch pro 2? it fits mini usb. Are voltages and amps similar?
USB Voltage is always 5V. That is standard. As far as your charger for your V3, different motorola chargers have different ampere or mA, but I wouldn't worry about it, you cannot overpower the Touch, it just may charge slower if the charger for the V3 is a weak one.
Other than that though, if it fits USB, you should definitely be fine.
Dec 02, 2009 | Motorola Mobility RAZR V3
LIKE EVERYONE ELSE HERE, I CAN'T TRANSFER MY PIC'S UNTO MY COMPUTER EITHER. DO I NEED TO GO TO A DOWNLOAD SITE?
Check out this link below to download a PDF manual, software, and more for your phone. Just copy and paste into your browser.
http://www.motorola.com/support/v/index.jsp?vgnextoid=df7e6d0d0a23e110VgnVCM1000008406b00aRCRD&vgnextchannel=25aae66506e9d110VgnVCM1000008406b00aRCRD
From your manual page 2:
Mini-USB Port Insert stereo headset, battery charger, & other phone accessories.
You can transfer files using your Bluetooth option on page 26 of your manual. I use a USB linking cable but you need to look a the software downloads on the link above. The USB cable connects into the same port your battery charger goes into.
Hope this helps, let me know if I can do anything else for you.
JimmyC
Oct 15, 2009 | Motorola Mobility RAZR V3
Motorola v3 car charger
check your cigarette lighter, it may have a blown fuse , check to make sure its not the problem.
Oct 14, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Will no longer charge the batteryh
You have a charging port problem. the part is here http://www.sourcingmap.com/mini-usb-charging-port-charger-connector-for-motorola-razr-p-24817.html ig you need a diagram ill see if i have time to load 1 up. or take it to 1 of these phone guys on craigslist. they wull fix while you wait got like $20.00 if not ill fix it. Merry Xmas
Oct 08, 2008 | Motorola Mobility RAZR V3
Car charger without overcharge protection - fear of overcharging Mororola Razr V3
you should purchase a mobile v3 car charger for the phone and do not use the other one you have
Sep 28, 2008 | Motorola Mobility RAZR V3
Motorola RAZR V3
Install Motorola Phone tools first,it contains all drivers for all Motorola phones,plug the cable and charge
Sep 16, 2008 | Motorola Mobility RAZR V3
Razr v3 series says "unauthorized charger"
have you notice abnormalities aside from that? if not, it's a hardware failure, either your mini usb, or the transdock or capacitors ..solutions hardware repair..
Apr 15, 2008 | Motorola Mobility RAZR V3
Phone to computer or printer transfer
The easiest solution for you is to get a mini usb cable,,it has a standard usb plug to go to computer on one end,and a mini usb plug on the phone end,,,same as the plug on your phone charger,,then you can transfer files easy.
Oct 07, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
149 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
