Question about Averatec 3200 Notebook
Dont start first i turned on it work for 2 second and then turned off , i change the battery it works for 20 mintes and stoped i find the fuse in the power cored is blown up and until now it doesnot start
  • 2 more comments
  • rtmart Sep 28, 2008
    When you push the power switch on over and over again quickly you can hear the fan on the CPU spin up. The computer does not start. Every so ofter the computer will start and boot to windows and then unexpectantly it shuts off instantly. The power jack is loose but I can make a connection eventually, the battery symbol blinks. In windows the battery shows charged, 93%. Is there a power chip or regulator that when connected charges the battery and supplies power to the computer? If this was intermittent could it short the power feeding the motherboard and cause the computer to shutdown instantly?
  • miquelmc Sep 30, 2008
    I have the same problem. However, I am certain the reason the computer power's down is due to a broken DC Jack. Unfortunately, I've had this problem with both of my Averatec 3200 computers!~ Does anyone know how to fix this or who can fix this?
  • guru_n Oct 01, 2008
    yeah i gt the same problem,it boots and you might start any application,bt in the middle of it,,,off goes the light...this **** sucks....
  • Evan Mayo
    Evan Mayo May 11, 2010
    1: What fuse in the power cord?
    2: sounds like a weak or broken DC Jack.
    3: sounds like bad or dry heatsink compound.
    Answer these questions, as I could not understand what you are saying.
    When you started the laptop, it would stay on for 2 minutes?
    YES or NO
    When you run the laptop from battery, it will last for 20 minutes?
    YES or NO
    Where is the fuse in the power cord??
    Scholar:
  • 94 Answers
Did you ever find the solution?
Posted on Apr 01, 2008
2003 Impala starts, runs 2 seconds, stalls
in theft mode.. the fix..... try to start when eng. dies leave key on for 10 min turn off then on but dont try to start do thes 3 times on the 3rd time veh should start and run.
Jan 02, 2013 | 2003 Chevrolet Impala
97 sun fire.try too start it with key it will not do anything.if I jump the silanoid motor will rotate but not start.and for some reson the power windows stoped working.fuses are good some one has cut out...
The starter fuse is a 50 amp fuse in the engine fuse junction box, as for the ignition it is fused by a 20 amp fuse that gives power to the crank and cam sensor,restore the ignition in the proper way,the reason being you dont have spark.
Apr 13, 2012 | 1997 Pontiac Sunfire
Trouble codes
look first all the wire and spark good and add fuel cleaner injection . and start andrun the engine for 15 mint and after this turn off and Disconnect the battery for 20 mint , and after this start run your engine again . and if your wire and spark old , It is better you change them , let me know ,
Nov 16, 2011 | Cars & Trucks
Hello excactly on christmas day my sansa e250 stoped responding, it turns on but it does not move on to the home page of the player, the screen stays at the sandisk screen, then it fades for about 2...
Try to do a reset, follow these instructions if this does not work. Reseat the battery.
Resetting your player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
Resetting a Sansa View, Fuze, or Clip player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Dec 25, 2010 | SanDisk Sansa e250 MP3 Player
The car wont start, the brake pedal is locked like the anti-theft is active, the anti theft light is flashing when the keys are in the ignition. when i try to turn it on it doesnt turn over, just makes...
TRY REPROGRAM KEY .PUT KEY IN IGNITION SWITCH TURN IGNITION SWITCH ON POSITION 20 SECONDS DONT START ENGINE WAIT 20 SECONDS TURN OFF SWITCH THEN TURN SWITCH BACK ON 20 SECONDS WATCH THE THEFT SECURITY LIGHT BLINKING.WHEN THEFT STOP BLINKING VECHICLE WILL CRANK.IF LIGHT STILL BLINKING.TRY FEW MORE TIMES KEY IN SWITCH ON POSITION FOR 20 SECONDS.MAKE SURE YOU HAVE THE CORRECT CAR KEYS IN SWITCH IF NOT WRONG SET OF CAR KEYS WILL SET OFF THEFT SECURITY SYSTEM.IF KEY RESETTING TRICK DONT WORK.CHECK BATTERY POWER MAKE SURE YOUR BATTERY HAS 12.5 VOLTS AND CHECK SECURITY THEFT FUSE.IF ALL LOOKS GOOD YOUR SECURITY HAS TO BE CHECKED OUT AT THE DEALERSHIP.
Oct 08, 2010 | 2006 Ford Fusion
Changed a bad battery in my 2005z71. with new battery in @ start up the AC only blows hot air. was working just before battery change. Fuse check out fine. What do I need to look for?
Start the truck,and turn ac on,cold setting and all,let it run for 20 seconds,and turn ac off,then wait 5 seconds turn truck off,,wait 5 seconds,and then start truck,wait about 5 seconds,and turn ac on,see if this helps.
Jul 20, 2010 | 2005 Chevrolet Silverado
MY DODGE RAM HAS A FACTORY INSTALLED REMOTE START BUT THE REMOTE STOPED WORKING I CHANGED THE BATTERY BUT STILL DOES NOT WORK ANY DEAS WHY
Oreilly Automotive stores have a little device the picks up a signal from a remote. Maybe your local parts store will have one. This will verify that your key F.O.B. is working. After that....fuses or possibly a frequency switch in the key FOB got bumped when you changed batteries. Otherwise, catastrophic failure....sorry.
May 09, 2010 | 2007 Dodge Ram 2500 Mega Cab Laramie
Radio/side view mirror switch does not work but fuse for it (#7) is fine. According to owners manuel, fuse #7 is also for instrument cluster ligts which work. Any Ideas?
start looking at the wiring harness in the door frame it sounds like it is broken
failing thet did it get wet recently ?
water inside of switches will film the contacts and all of a suden they dont work
or might it have been pop
the wife spilled diet coke on a keyboard once
took about 40 seconds 1/2 te keys stoped working.
diet coke plus switches epecialy in newer cars doesnt work well unless you dont want em to work ever again
Apr 16, 2009 | 2004 Mazda Tribute
Turn signals dont work but still hear the clicking noise
Change the bulbs, my hubby had this problem in a 2002 focus, changed the bulbs and started working again
Mar 28, 2009 | 1994 Honda Civic Del Sol
Averatec 3200 Notebook Logo
62 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
General Systems...
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
