Question about Hifonics AS6.5Ci 6.5" 2 Way 125W RMS Component Speakers System Car Speaker
Tweeter soldering snapped !
Hey i am from india . have a pair of these components ! recently my left tweeter wire snapped ! :-( ..... can this be rectified ...... if yes how ? plz help me guys
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 199 Answers
Do you mean the support wire that comes from frame of speaker to back of tweeter? More info. PIC if able pls.
Posted on Feb 12, 2008
Polk Tweeter on RT 1000i
it sounds like its the cross over
Mar 25, 2013 | Polk Audio RT1000I Speaker
To Mr. Hyde: you appear experienced with Bose 501 Series III speakers. I need to replace a burned out glass bulb fuse inside the right speaker, the fuse for the woofer I believe. I think that you said that...
Hello whit_hughes,
Just received your request for some information regarding Bose 501's......... Series III. Your looking for te manufacturers part # for the fuse which is in line with the woofer? The fuses used ON the Series III Crossovers (hard wired/soldered directly to crossover board/componants) have been Identified as BUSS #2494, 2amp, Quick-Blow Glass Tube Type Fuses. The fuse which is in-series with the woofer & the fuse which is in-series with the pair of tweeters are the same! In theory this means that the woofer is capable of twice the wattage of the tweeters due to the tweeters being wired in series with each other..... which in turn divides the power beween the two equaly. On the woofer circuit there is only the one speaker or voice coil obsorbing the power. The woofer circuit being wired in parallel with the tweeter circuit again splits the power between the two cuircuits..... so in an ideal situation the woofer sees 50% total input power while the tweeters each see 25% total input power;;;; totaling 100% total. The way Bose has fused them in the Series III's is such that each branch can obsorb a total of 2 amps before shutting down each indivigual branch. This can be adventageous..... should peak power be exceeded causing loss of full load abruptly, Amplifier Power Output Transistors usually blow..... however when only half of the full cuircuit shuts down due to peak power exeeding limits causing one fuse to open (blow) ... the actual impedance (resistance) of the speaker increases protecting the Amplifiers Output Transistors! Thats the reason for the 2 fuses. Each of them are identical. They are soldered into place.... via the wire which is attached to each end of the fuse. (Note; the fuse "kit" Bose is trying to sell you is an external in line fuse holder for each speaker {costing 1.29 each} & 2 fuses for each holder, One for now & One for Later aftr it blows {costing 1.00 each}..... costing Bose 6.58, neting Bose $13.42 Profit!!!! Keep in mind that this fuse WILL NOT FIX YOUR PROBLEM EITHER! DUE TO THE FUSE WHICH IS PRESENTLY BLOWN HAS NOT BEEN REPLACED!!!!! ) The one that has to be replaced is on the crossover... not between the Amplifier & the Speaker Enclosure. Tools required = 1 Long Big Straight Blade Screwdriver to pry off speaker grill, 1 Phyllips Screwdriver to remove screws seccuring woofer to encloser... be carefull not to damage/tear gasket, 1 pair side cutters to cut blown fuse out of crossover curcuit, 1 pair needle nose pliers to attach NEW fuse to crossover curcuit, 1 soldering Iron & a small piece of solder to re-solder fuses leads securly to crossover curcuit. ( replace gasket, woofer, screws, & speaker grill. ENJOY! Should additionaL informaton be required please let me know.... you'll have to leave me your e-mail address for pictures or drawings.... as I don't think they can be sent through this site. Hope this helps ya..... Its an EASY JOB...... you CAN DO IT! & will be glad you did when your done, they'll sound GREAT! ) GOOD LUCK!
Jun 22, 2011 | Audio Players & Recorders
Blown tweeters on pair of The Amazing Alphas
check on radio shack maybe there got something that fits your necesities
Feb 06, 2010 | Audio Players & Recorders
Left earphone has snapped off a pair off
You can try to re-solder it but make sure you use a heat-sink and flux. The problem with small earphones is that it's a wire within a wire - for visual purposes picture it like the coax cable that goes in the back of your TV. If the inner wire is missing you can't just strip the wire to get it out because you need to keep the two from touching. If you don't mind spending a small amount of money take it to your local electronics repair store and they'll reconnect it for a small fee.
Happy Holidays and good luck!
Dec 18, 2009 | Ultimate Ears super.fi 5 Pro Consumer...
What are the colors of the speaker wires in a dodge stratus 1997 coming from the wire harness of the car itself
The easiest way is to check the speakers themselves as manufacturers tend to change colors of speakers at a whim. Usualy though you will have 8 wires (4 front & 4 rear) paired in colours (white goes with white+black stripe(stripe is possative on speaker))etc.
Not knowing the cars electrics I can't be more specific.(I live in UK so don't know that much about U.S. cars)
Jun 27, 2009 | 1997 Dodge Stratus
Positive an negative wires?
With connecting tweeters, it doesn't really matter which is positive or negative. connect them and give it a try. Nothing can happen to the tweeters or car stereo.
Apr 30, 2009 | Car Audio & Video
No sound out of tweeters, highs out of woofers?
it does sound like you shorted out your crossover which can be fixed if you know what you are doing, but in the long run i would try to get another one i know that raidoshack sells some small ones and is also cheap, if your positive that you didnt short out the crossover se if it needs power, see if you can cross your woffers and tweeters on the crossover, if not is there any settings that u can change on the crossover? hope i helped :)
Apr 28, 2009 | Jl Audio VR650-CSi Car Component System
2002 Grand am gt monsoon, hook up rear aftermarket speakers
You have to test them, either should work fine (as in use either pair) if that doesn't work connect one pair at a time and listen for the difference, one pair might be for factory midrange and other for tweeter.. there are two different wiring configurations...
Jan 28, 2009 | 2002 Pontiac Grand Am
Adding new speakers to the deck
You need to know if these are Pizo tweeters or dome tweeters. If Pizo just hool them up to the white and gray wires off the kenwood. if not, then you should go to your local stereo shop and by bass blockers (small capacitors will do). this is only to "erase" the ohm load. once you have those inline of the POSITIVE wire you can hook the up to the gray and white wires. Good luck hit me back
Mar 03, 2008 | Kenwood KDC-135 CD Player
Hifonics AS5.5Ci tweeter soldering !
Because they are tweeters, and only 4 months old. take them back for warranty. Most manufacturers will give 6-12 months.
Feb 08, 2008 | Hifonics AS6.5Ci 6.5" 2 Way 125W RMS...
Hifonics AS6.5Ci 6.5" 2 Way 125W RMS Component Speakers System Car Speaker Logo
54 people viewed this question
Top Hifonics Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
