Question about D-Link DE-528 Network Adapter
Slow internet Hi, I have connected two computers via VSDL internet connection 100Mbps. First is running on 100Mbps while second (having D-link DE-528) shows only 10Mbps. Any findings? Vasco
    Problem Solver:
  • 16 Answers
I suspect that the DE-528 (discontinued card by the way) is only a 10 mbps card. Unless you are doing some heavy duty video the card would be fine. Otherwise replace it with a 100 mbps card.
Posted on Feb 08, 2008
My down load is very slow
Hi,just check your speed from here http://www.scanmyspeed.com/ and if still your speed continues to be slow contact your provider.
Mar 08, 2011 | D-Link DSL-2640B Wireless 11/54Mbps ADSL2+...
An error occurs over at facebook and it's been 3 days that there are no images. Only the text appear. How can I solve the problem?
Dear Sorianom79:
Try to check the antenna of your internet and try to refresh your computer to connect to internet. The text you are saying is what you call the HTML because you have a slow connection of your internet. The speed should be 100mbps .
Regards,
Angel
Feb 08, 2011 | Computers & Internet
My net speed get very slow
If you are talking about about your speed while connected to the wireless, I do believe this is a 801.11b, which means it is a slower router (for wireless) and only goes up to 11Mbps. If you think you are getting even slower speed than that, log in to it, go to the wireless setting tab and find the setting for the connection speed. make sure its set to use the full 11Mbps! (sometimes is can be set to only 1-3 or 3-5Mbps).
If you are talking about the speed while connected via hard wire (eithernet cable), log in to your router and make sure that the wired speed is set to the highest value (I believe this one goes to 100Mbps full-duplex) and also make sure that the cable you are using is at least a CAT5 or above (CAT5. CAT5E, CAT6). A CAT3 ethernet cable will not go up to the 100mpbs! (this is printed on the wire).. also make sure that the port on your computer also goes up to 100mbps!
hope this helps!
Jan 16, 2011 | D-Link DI 514 Wireless Router (DI-514)
I connected a 100/10 switch behind the router. The link led (uplink) flickers and data transfert through switch in drastically reduced (by factor 150) Can I connect a switch behind the Dsl rputer ?
1. Connect one end of your Ethernet cable to one of Four 10/100Mbps Ethernet LAN Ports.
2. Connect the other end of the Ethernet cable into one of the ports in the switch (try not to use the uplink port if it slows-down the connection)
Thanks
Aug 31, 2010 | D-Link DSL-G604T Wireless Router
I have Toshiba Satellite A100 running Windows XP and connecting via wireless to D-Link DIR-615 router. I can get a connection and access the internet but the pages take ages to load. I also have two...
You have a slow computer. To speed up page loading you might want to add an ad blocker to your browser to speed things up since the ads take up memory resources and slow down your computer.
Aug 23, 2017 | Computers & Internet
My belkin 802-11g is 1 hour slow how do i cange
You can easily check your internet speed bychecking it online via tis website, http://www.ip-details.com/ . Ithelped me to check my PC's internet speed in it.
Jul 27, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Hi i want to add a client (Dos) with De-528 Network adapter (dual port) to server ( novel 4.11). Please help me.
hi i want to add a client (Dos) with D-link-530tx(dl10030b) Network adapter (cable rj45) to server ( novel 4.11). Please help me.
Mar 16, 2010 | D-Link DE-528 Network Adapter
Slow speed of data transfer 10 MBPS instead of 100 MBPS
the switch which ur pc is connected might have been set to 10 mbps ...if the switch is managable cisco switch try changing the port setting to 100mbps full duplex
Apr 18, 2009 | D-Link DE 824TP (DE-824TP) Networking Hub
Reset speed from 10Mbps on 100Mbps (D-Link DE-1824i)
Tony,  I was looking at the specs and found these lines :- Choices of 12 and 24 10BASE-T ports per hub
1 100BASE-TX port (for connection to 100BASE-TX hubs) Which is saying that the user/pc ports are fixed 10Mps and there is one 100Mbps uplink port to connect two hubs together.
http://www.dlink-intl.com/Products/Hubs/DE1824.htm
Apr 13, 2009 | D-Link DE 1824i (DE-1824I) Networking Hub
Slow connection w/ FiOS
You may not be interpreting the LED correctly. The Link LED goes on to indicate a physical connection (if the Link LED is out, the cable is damaged or disconnected), but the 10/100 LED only illuminates when there’s a 100Mbps connection. The LED will remain off when the connection is only 10Mbps. Here’s how to quickly determine the speed of your connection. If the 10/100LED is off, there’s a slow connection. If the LED is on, there’s a fast connection.
A fast (100Mbps) network connection requires that both ends of the connection support 100Mbps communication. So, if the 10/100 LED on your hub is dark, chances are that your PC’s network adapter (or NIC [network interface card]) is only operating in the 10Mbps mode. Check the NIC in your Device Manager Network Adapter entry and look for any 10/100 designation. An older 10Mbps NIC may need to be upgraded for 100Mbps operation. If it’s a 10/100 NIC, refer to the PC’s documentation and check the NIC settings to make sure it’s not locked in the 10Mbps mode. Set the NIC to a mixed or 10/100 mode so that it can adapt automatically to establish the best possible connection.
Mar 06, 2008 | Acer Aspire 3004WLCi Notebook
D-Link DE-528 Network Adapter Logo
137 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
