Problem installing mobo
Cant find where to plug cd/dvd rom drive since the only slots that seems right is fitted with the hard disk wire
    Problem Solver:
  • 8 Answers
Purchase a datacable having at least two connectors and use it
Posted on Feb 08, 2008
Asus M2N32-SLI Deluxe mobo will not see my Sata DVD Recorder
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope it helps
Apr 09, 2012 | Pioneer Computers & Internet
Computer is not reading the installation disk
By installation Disk do you mean the CD/DVD-ROM? If yes
Check to see if the drive's LED flashes when the system is trying to boot. If it doesn't, open the system and make sure all the cables to the CD/DVD- ROM is properly connected and to the right slots. If the cables are properly connect and the CD/DVD- ROM is still not working replace the CD/DVD-ROM.
However, if its that the system could not install a particular program, make sure the installation files are complete and try again. If its a downloaded program, verify the completeness of the file downloaded and try reinstalling the program.
Feb 13, 2012 | Peachtree Software Computers & Internet
How do i install this drive?
Unplug the power cable from your power supply and open up your computer Don't forget to wear your antistatic wrist band. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays. Before you install a CD-ROM, make sure you have the proper jumper settings. Since we are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay, while other cases come with brackets (like mine) to attach to the CD-ROM drive so that it slides into the drive bay and locks in place.
Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a "SLAVE" connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver
Hope this helps
Jul 04, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
Installing Vista on new hard drive- CD/DVD Driver not found
Are you installing from the SONY-supplied "System Restore" CD/DVD disks, or from a "generic" Vista DVD-ROM?
The SONY disks _should_ have the correct drivers for your notebook computer.
Dec 08, 2009 | Sony VAIO VGN-NR220E/S Notebook PC
After installing windows 7, the LG DVD drive doesn't work and windows says it cant install the driver
Many older ICH7 chipset drivers as well as generic derivers has been removed from the winodws Latest Built, for you it it seems the cd/dvd rom drivers are missing.
I here give the link uploaded by me, which contains the driver for CD/DVD ROM fro windows 7, Please open device manager and manually locate the CD/DVD rom and select the .inf file to install the driver
http://rapidshare.com/files/297330669/CD_ROM_Drive.rar.html
Please leave me comment, if you need further assistance
Rnj VINODKUMAR
Rename CD-ROM Drive.txt to CD-ROM Drive.rar!
@ADDeveloper
Try the Intel package(link posted before), that's an Intel mobo.
Oct 24, 2009 | Computers & Internet
Issue Installing 4th Drive Device (2 DVD Drives and 2 Harddrives)
You cannot plug an IDE ribbon in the floppy slot (port). The total IDE drives you can install is four (4). But check your jumper configuration. The DVD & DVD/CD-ROM cannot have the same jumper configuration to share the same IDE slot. One has to be MASTER (MS) and the other SLAVE (SL). Or you may put both drives on CABLE SELECT (CS).
Apr 21, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
My computer will not read any of my disk or install
when you say disk did you mean hard disk? if you do... did you recenlty install a new hard disks?... if you did... did you check the jumper-master-slave configuration when installing the new hard disk?
only one hard disk can be configured as master in each ide channel. set up to master (not single) the one on the end of the ide cable and set up to slave the one attached to the midlle of the ide cable.
check that both hard drives are properly attached to the cable and that the power cable is properly seated.
when you say disk did you mean cd rom disks or dvd disks?
does it work in other computers? if it doesnt.. you cd/dvd disks may be the problem
are you trying to read a dvd disk on a cd rom only drive... you can't read a dvd in a cd rom drive.
if you cd/dvd rom drive should read the disk you're putting in, check in device manager if your system detects the cd/dvd rom drive. if it doesn't: check the physical connections (reseat ide cable, check jumper configuration for slave and master on your cd/dvd rom drive and check that the power cable is properly seated), check also in device manager the properties of the cd/dvd rom drive and check if it says on device status if the device is working correctly. if it doesn't post the error code that it may give you or google a solution with error code.
suggestion.. be more specific when posting your questions.. that way it will be easier for a solution to be provided as your issue could be interpreted in different ways
Sep 24, 2008 | HP Computers & Internet
Got a laptop (ei systems) that i cannot properly start up, and access vital information which i just cant lose (court stuff etc). When computer turns on it say Boot device Hard Disk C / ...
try to boot your laptop from hard disk
reset your laptop & press f2 or del to go in cmos setup by press f2 or del key then afer go in boot manu select there is hard disk in a frist boot divice then save the settings by press f10
try this
may your problem will solves
Mar 23, 2008 | Computers & Internet
Cant instal as have no installaltion cd
Dont be silly - its plug and play. the only thing software disk does is install nero or other burning software with you can 'borrow' from you friend next door. Wakey waky!
Nov 08, 2007 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
Cant play DVD on CD-RW/DVD-ROM Combo Drive
Assuming you have tried different makes of cd or dvd disks, it's a classic drive failure problem where the laser can no longer burn or read dvd's, but may still be able to read cd's only. You will have to replace the drive, they are quite inexpensive, and very easy to fit.
Aug 10, 2007 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Computers & Internet Logo
348 people viewed this question
Alun Cox
David Payne
David Payne
