Hi Im looking for the PROCEEDURE FOR FITTING CYLINDER HEAD TO QR20DE engine thanks.
SOURCE: Cylinder head
depends on engine code, and single cam or twin cam. check your code. D16W4 sohc stage 1. 29nm stage 2 72nm. D16Y5. stage 1 20nm. 2. 49nm. 3.67nm . 4. 67nm. there are 2 other codes for sohc engines these are the same as D16W4. DOHC engine as follows B16A2 stage 1. 29nm. 2. 83nm. hope this helps, if you are ot sure give m the exact engine code and i can verify.
SOURCE: Toyota 4Runner-head gasket fitting
codigo del juego de empacaduras del motor de la ford runner tollota 2003
SOURCE: Hi I'm looking for cylinder head torque settings for a 1992 BMW 316/318 e36
BMW cylinder torque setting all models
According to my service manual as follows.
Cyl head to engine block (torx e12 M10 bolts)
Stage 1 30nm (22 ft – lb)
Stage 2 + 90 degrees
Stage 3 + 90 degrees
Cyl head to lower timing chain cover 10nm (89in – lb)
The tightening sequence is from inside to outside crossover as normal. Loosening sequence is from outside to inside crossover. Remember to set torque wrench at low setting and work gradually up through the whole sequence until you get the desired torque.
