Question about Brother HL 1440 Laser Printer
Brother HL 1440 Printer Density Adjustment
My Brother HL 1440 is printing too light. How do I darken the print? Toner and Ink are new enough, factory original, etc. My question more precisely is: Is there a way to adjust print quality from lighter to darker with this printer? If so, how do you do it?
Thanks,
HT
  • Hank T Feb 08, 2008
    I have combed the manual for directions about how to adjust printer density, and I cannot find them anywhere. Your answer was no help whatsoever. So I will ask again:
    How do I physically adjust my Brother HL 1440 printer so that it will print darker?
    Thanks again,,
    Hank T.
  • Anonymous Mar 15, 2014
    print unable ED on Brother HL 3075CW printer
This site becomes worthless when people post marketing instead of answers. "it's in the manual" click here to buy or "just call our pay for service" are NOT solutions. Odds are these places do not even have or know the answer. This is *****, stop allowing these scammers to post that garbage. Answer the questions or do not post.
Posted on Feb 16, 2018
  • 108 Answers
Go to Printer and Faxes and select the properties button, then select the maximum dpi in the Advanced tab. You will get the best quality Print
Posted on Feb 08, 2008
    Master:
    Sergeant:
  • 462 Answers
For sure u can increase the darkness and there are settings to increase but u need to browse through the menu to locate the darkness increasing options. The mannual should definitely help.
Thanks
Brother hl 1440 printing light
Toner empty or due to moisture toner is not distributed or OPC is gone bad
Aug 23, 2012 | Brother HL 1440 Laser Printer
Changed the drum & ink cartridge in HL-1440-ink bleeds on edge
This problem is often caused by spilled toner. Open the printer, carefully remove the cartridge, and give it a few bursts of compressed air. Often running several pages or type through will also fix this. If it persists, replace the toner cartridge.
Hope this initial info/idea helps. Let me know for any clarifications.
Jul 08, 2010 | Brother HL 1440 Laser Printer
The alarm light is blinking and the toner was changed 3 days ago. Minimal printing since then
Forgive me for asking this, but roughly speaking about 80 to 95% of problems involving ink or toner are resolved by the following:
Are you using a factory new ink cartridge supplied by the manufacturer of the printer?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
Dec 14, 2009 | Brother HL 1440 Laser Printer
Printing is too light
it may be your toner ink is low try to give print in best mode if you success then good otherwise change the toner.
Nov 21, 2009 | Brother HL 1440 Laser Printer
My HL 1440 Laser printer does not print The
If your printer have no paper jam inside and paper tray has paper in it, then you need to replace toner cartridge.
Oct 06, 2009 | Brother HL 1440 Laser Printer
How do I change the toner density on the push button display when it is locked with an * We have low or a feint print out of the fine print on the print settings print out test sheets. I have cleaned all...
A new laser could help, but you should make sure the toner save is turned off, it makes toner last longer by making light prints. Toner save is set in printer properties in the control panel
Sep 10, 2009 | Brother HL-5240 Laser Printer
My HL 1440 is printing very light. The toner cartridge is pretty new. Is there something I can do to get it to printer darker?
Go into start- Printers and faxes and right click on the printer, then go to properties.
Depending on the printer (it varies greatly) there should be a tab at the top for printing quality or something similar. You can adjust the ink level there.
Jul 30, 2009 | Brother HL 1440 Laser Printer
Printer won't print
According to the operation manual: If alarm light and data light blink every 5 seconds- TONER LOW (purchase more toner and have it ready when the 'toner empty' is indicated). If alarm light and data light stay lit- TONER EMPTY (replace toner cartrige with new one).
Apr 21, 2008 | Brother HL 1440 Laser Printer
Brother HL-1440
(blinking every 5 seconds) Toner Low Indicates that the toner cartridge is nearly empty. Purchase a new toner and have it ready for when Toner Empty is indicated. (solid) Toner Empty Replace the toner cartridge with a new one. User's Manual is available at the following location: http://www.brother-usa.com/Data/Documentation/Printer/User/UM_HL1440_1450_1470N.pdf Hope this helps.
Aug 22, 2007 | Brother HL 1440 Laser Printer
Brother HL 1440 Laser Printer Logo
2,491 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
