Question about HP Photosmart C6180 All-In-One InkJet Printer
Paper won't load
I have a HP C6180/ Vista 32bit/
The paper will not load. It sounds like it is trying but it won't catch up the paper and I get a message to load paper face down in the Main Tray. Still it won't load the paper. I have had this problem in the past with printing checks with Quicken but I just put the setting on draft and it works fine.
It started when I got a fax yesterday and it was trying to print it off. It never would load the paper and now it won't load paper to print anything else either
I would appeciate your help.
  • 2 more comments
  • Sallysmith Feb 08, 2008
    I did what you said. I used canned air to blow it out. Didn't see anything come out.
    Still it will not load the paper.
  • Anonymous Feb 21, 2008
    How do you take the paper tray out?
    Michele~
  • Anonymous Mar 20, 2008
    The paper will not load. error note: Load paper face down in Main tray. computer error printer out of paper.
  • Anonymous May 22, 2009
    Keeps telling me to load paper face down. No matter which paper I'm using. I've blown everything out with an air can. But I can't figure out how the tray comes out.
I have a C5180, which has an access panel on the back. I removed that and started the print job. I could see the photo paper tray slide into place and the rollers try to load a sheet of paper. It was pretty obvious that the problem wasn't with the photo paper, but rather the 8.5x11 paper below. A sheet of regular paper was partially loaded on the rollers and it was preventing the photo paper from loading. So, fixing it was simply a matter of reloading the 8.5x11 paper.
Posted on Jan 25, 2010
    President:
  • 4,402 Answers
First this to do is turn it off unplug, take paper tray out and remove paper and clean the tray, take the printer and put it on it's side (the side where the paper tray goes and see if you get any paper dust to come out. other wise blow air into that area you will see a roller on top need to clean that.
Posted on Feb 08, 2008
  • Cary Farah
    Cary Farah Feb 08, 2008
    did you check the roller on top and clean it?
I had a very similar problem and what had happened with mine is that there is a very small narrow brush that I think is there to clean the paper right before the print goes down and as I looked closely at the printing module (I don't know what else to call it, it's the part with the cartriges that moves back and forth to print) that brush (it has a sticky backside and attaches somewhere underneath) was out of place.  I think it was precluding the module from detecting the paper was there (I noticed a laser scan each time I would push the "ok" button on top).  I pulled that brush thing out and it started working right away.  I wasn't sure what the proper position of the brush is so I just threw it away.  It's printing fine now.
Posted on Oct 07, 2008
4/23/09 I just did what the 2 solutions above recommended and my HP C7280 all-in-one is printing perfectly now.  I took off the lid, the back (where paper jams are removed), basically anything I could remove, and spray blasted the insides, shook it lighltly on it's side, and that did it.  Thank you very much!  Gayle
Posted on Apr 23, 2009
Paper is in paper tray, however copier says "load paper in tray
The paper is not loaded correctly, push it in there all the way to the back. Also put in a reasonable amount of paper, not to little or too much. Good luck!
Aug 27, 2012 | HP Photosmart C6180 All-In-One InkJet...
Hp c6180 won't print from 4x6 photo paper tray
If you put regular paper in the tray as it is asking does the printer use the regular paper to print the picture? If so, be sure the 4x6 photo paper tray (with photo paper) is pushed all the way in, and when you select print there should be an option (probably hidden in a submenu) to select the photo tray as the paper source. If you are printing from Adobe Acrobat, I have not found a reliable way to get the c6180 to use the photo paper tray. I hope this helps.
Jul 15, 2012 | HP Photosmart C6180 All-In-One InkJet...
I have a HP Photosmart C6180 All-In-One and the paper is jamming ever time I try to print or receive a fax.
Check the specifications of the paper size and weight. It should be a supported paper size. Clen the rollers of the paper.
Dec 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP C6180 stopped loading paper
its due to the fact that paper you have loaded is being crashed inside the printer if you once again rotate the paper feeder stick and try it will work
Sep 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
Paper won't feed
No guarantee on this just an idea. Can you put a piece of sticky tape(the matt one not hi gloss) just across the feed in edge. Or some other thin tape that would have a "grip" to it? Good Luck!
Apr 30, 2009 | HP Photosmart C6180 All-In-One InkJet...
Paper catching
the paper sensor could be bad, try manually selecting the paper type, plain paper etc...
Mar 19, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Vista Pavilion and Quickbooks 2008
install a new fresh windows vista and then install your printers c6180 printer driver
Jan 28, 2009 | Computers & Internet
Paper jammed in printer - need to remove paper tray
1 This works from HP help link in error message:
Turn off the HP All-in-One.
2 Press in the tab on the rear door to release the door. Remove the door by pulling it away from the HP All-in-One. icon_caution_color.gif Caution Trying to clear a paper jam from the front of the HP All-in-One can damage the print mechanism. Always access and clear paper jams through the rear door.
Jul 28, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
1,744 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
