Question about Microtek ScanMaker 5950 Flatbed Scanner
Scanmaker 5950 If I am scanning multiple pages and the first page does not scan correctly is there a way to cut that page out and ONLY re-scan that page... but still be able to save it with the rest of the good pages??
I need Scanmaker 5950
Posted on Jun 11, 2008
How do i scan multiple pages and sav it to my documents. It seems like i am only able to scan and save one page at a time
Hi
If you have a Top feeder on the scanner, you can scan mutiple pages. Change the setting of the scanned file to pdf file (not JPEG) by going to the scanner icon and change the type of file you want to scan. Scan it as PDF FILE and then it will scan multiple pages. Regards
Jun 16, 2011 | Computers & Internet
Scanner is not reading multiple pages...
Check your scanning software settings. If you are getting only one file output, then you must have chosen 'multipage' option.
S. Mohan
Jun 12, 2009 | Canon DR-2580C Path-Through Scanner
How to fix / clear unwanted color bands during scan
Try place a couple of pieces of white paper behind what you are scanning. Worked for me
Apr 25, 2009 | Microtek ScanMaker 5950 Flatbed Scanner
Microtek scanner freezes when scanning large documents.
Try scanning using Scanwizard instead of using directly in Photoshop. If it freezes again, it might be some problem with your system since there's no indication of hardware conflict. Additional info like Microtek scanner model name and current Windows version. Normally, Adobe wont have any problem regardless the scanner model, as long the appropriate driver installed.
Mar 27, 2009 | Microtek ScanMaker 5950 Flatbed Scanner
Can only scan simplex or duplex
The scanner can scan in either simplex or duplex mode only. If blank page is scanned, then it will appear BLANK, else someone would say, my scanner is not scanning properly! Remove balnk pages using software or sort on file size and delete the small sized files. Take care to ensure they are really blank.
S. Mohan, India
Nov 20, 2008 | Fujitsu fi-5110C ScanMaker Scanner
was there ever a solution for this issue. all of a sudden, i am receiving it too after scanning for several years. please email me at arpanganiban@yahoo.com
Apr 14, 2008 | Microtek ScanMaker 5950 Flatbed Scanner
Microtek Scanner installation issue
If running XP SP2, then try clicking Start > right click My Computer > properties > Hardware tab > Device Manager button > expand Imaging devices > right click on your Microtek ScanMaker > uninstall > Re boot > and let XP pick up the device and let the found hardware wizard configure it.
I have seen plenty of hardware that when following the devices manufacturer's instructions for install, such problems as you're having occur and XP SP2 usually will cure it, though you may still need the device manufacturer's CD (for the driver) in your optical drive.
This link: http://support.microtek.com/downloads/bymodelname.phtml?viewtype=2&srch_in=ScanMaker+5950&frmsearch.x=10&frmsearch.y=11&frmsearch=Search&frm_rqst=2&axn=1 will allow you to select between the 5950 and 5950 Pro then on the next page you will be able to download the latest XP driver for your Scanmaker among drivers for other Operating Systems also.
I hope this helps, and Good luck.
Mar 21, 2008 | Microtek ScanMaker 5950 Flatbed Scanner
Colorful lines down the scanned pages...
This could be due to excessive usage which the scanner can not tolerate and as a result the movement of the scanning mechanism losses precision. So avoid continous scanning.
Feb 08, 2008 | Microtek ScanMaker 5950 Flatbed Scanner
Scanning...
What do you mean scan? Is it from the printer to the computer? Or just plain copy? When you want to scan to the computer, you need a software that can scan multiple pages. HP's document feeder can copy and fax multiple pages, so if the software supports multiple pages scanning, then I'm sure it can.
Jan 04, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Solid black image with flatbed or adf
This particular scanner may not run to NTFS instructions.
Check Windows Help in my computer- for program Compatability
and try to reset the software to run as Windows 98 - it may work.
Dec 07, 2007 | Microtek ScanMaker 5950 Flatbed Scanner
Microtek ScanMaker 5950 Flatbed Scanner Logo
141 people viewed this question
Top Microtek Office Equipment & Supplies Experts
Alun Cox
Tony
Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
