Apple iPhone Smartphone
Problem for Apple iPhone Smartphone
Apple ipod itouch connection to wireless internet
By snohomish on Feb 08, 2008
I am trying to connect to my wi-fi. However I have WAP-PSK security, how can I set Itouch to same and access my internet.
Same Problem
May 12, 2009
-   the internet is connected but i can't acess to youtube or safari or ani of the stuff da wrks wid internet
-   sandeep_sidh
May 11, 2009
-   I dont know the password to unlock the internet connection?-   Guest
Apr 24, 2009
-   I don't know my password & it says connect to the internet. i don't know the password those.-   Briiii
Apr 12, 2009
-   i canttttttttt-   Guest
Apr 02, 2009
-   cant connect although i have in the past
-   Guest
Best Solution
posted on Jul 24, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
you can also try: http://www.ipodrefresh.com
Solution #2
posted on Jun 15, 2008
Helpful)
AgentKeech
Rank: Wiz
Rating: 83%, 57 votes
It's since the touch doesn't officially support WPA PSK and only supports WPA2. What will work is WEP and although it is less secure very few people will bother cracking your network. If you continue to have problems with your secured connection try putting the hex key instead of the passphrase (you set hello as your password the hex would something like 0X34Hg65) it is usually displayed just beneath the password you set.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #3
posted on Dec 22, 2008
Helpful)
rwarren_2001
Rank: Apprentice
Rating: 90%, 5 votes
This is not a solution to snobomish's problem, but I did solve mine as far as not being able to get on the internet with the iTouch, even though it was seeing my network and joining it. I'm using a Netgear Router WGR614. The easy solution to my problem was in LAN IP Setup on the router. I did not have "Use Router as DHCP Server" turned on or enabled, so it wasn't giving out an address to my iTouch for it to use. I turned it on and bang I'm on the Internet no problem.
Also, in order to be able to get to my Yahoo email, I had to go into WAN Setup on the router and change the MTU value to be 1492 instead of the default 1500. That may only be a problem for BellSouth DSL users.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #4
posted on Aug 07, 2009
Somewhat Helpful)
jemaal
Rank: Master
Rating: 77%, 47 votes
FIND YOUR SOLUTION FROM APLLE.
HERE IS YOUR SOLUTION
www.apple.com/iphone/prob237ji32/solution
Was this helpful?
Yes
No
Solution #5
posted on Aug 06, 2008
Somewhat Helpful)
Arbeiter
Rank: Apprentice
Rating: 75%, 2 votes
it really not that hard to crack WEP protection and it can be done real quickly (ie within 5 ) so it is not wise at all to "downgrade" to WEP security. spend the extra $ for a WPA2 router which is nearly impossible to crack
Was this helpful?
Yes
No
Solution #6
Somewhat Helpful)
andycc1236
Rank: Apprentice
Rating: 75%, 1 votes
unfortunately you have to take off the firewall to connect to home pc in some instances
Was this helpful?
Yes
No
Solution #7
posted on Nov 15, 2009
Not Rated)
tony8888112
Rank: Apprentice
Rating: 0%, 0 votes
Using WEP, DHCP enabled on router, the hex key entered on the Itouch as the password works (though it's long). I've haven't tried entering the pass-phrase used to generate the key in the Itouch
Was this helpful?
Yes
No
Solution #8
Not Rated)
enopog
Rank: Master
Rating: 76%, 21 votes
Hi Friends,
Problem with AppleiPhone? Most of the iPhone problem is Unlocking problem.
If you want to unlock youriPhone now you mustClick Here.
If you have any other problem with your iPhone you can try the site byClick Here. May the site can help you.
Was this helpful?
Yes
No
Popular Solutions for Apple iPhone Smartphone
Questions and Unsolved Problems for Apple iPhone Smartphone
Do you recommend Apple iPhone Smartphone?
Answer
Answer
can i use noteworthy synch to sync iphone to outlook express 6 winxp
Answer
my iphone not sending pict to the email
Answer
My ipod touch sceen will not unlock/slide. While resetting it for 10 sec. with the powerbutton and... (More)
47 Other Users Have The Same Problem - Continued
Comment by soccerrocker, posted on Mar 21, 2009
i can see the black dots covering the password but i cant find the password. ps the sercurity is WEP. PLZ HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!
Comment by Guest, posted on Feb 17, 2009
i cant get my itouch 8 gb to connect to my WRT54GS linksys router, i tried everything but i cant plzzzzz help!!!!!
Comment by Guest, posted on Feb 16, 2009
i cant get it to go on wi fi or any internet
Comment by jamokmok, posted on Feb 07, 2009
i am trying to connect to my wi-fi however i have psk security, how can i set I TOUCH to same ang access my internet
Comment by Guest, posted on Feb 02, 2009
my itouch 16 gb is not connected to the wi fi i dont no why it is not automatically connecting and i wolud like to resolve this problem
Comment by Guest, posted on Feb 01, 2009
no internet on the itouch at all
Comment by Guest, posted on Jan 17, 2009
i cannot connect my i-pod touch to an orange livebox
Comment by Guest, posted on Jan 10, 2009
black
Comment by AMarine2, posted on Jan 09, 2009
My Itouch will connect to the router and im able to ping my ipods IP.....I have done everything i can think of I unsecured my wireless and still same problem it sees the network but i am unable to access the internet.......its already set a DHCP im allowing all filtering i have upgraded my firmware and the thing still wont allow me to get onto the internet SOMEONE PLEASE HELP ME! I was able to connect on another wi fi my router is a Linksys BEFW11S4 V4 and i am using XP
Comment by cw4drama, posted on Jan 04, 2009
i dont have wifi connection at my house but have internet connection....nd the wifi connection i get on my itouch it says it needs a password...nd i dont know what the password is....
Comment by Guest, posted on Jan 03, 2009
can not connect to home wireless
works at other open wifi
Comment by gpah92, posted on Dec 27, 2008
I have connected to the router but it then says cant find a server when i try to go on safari and youtube etc.
Comment by GELD781, posted on Dec 27, 2008
I CANNOT CONNECT TO MY WANADOO LIVEBOX. I THINK IT IS SOMETHING TO DO WITH THE WPA -PERSONAL CONNECTION.
Comment by rwarren_2001, posted on Dec 21, 2008
I just bought an iTouch. It finds my wireless Netgear router just find and the SSID of my network. It "joins" the network, and shows that it is connected, but it will not browse the Internet. I even turned off all security but that didn't help. Any ideas? I bought this mainly for the internet capability. Please help.
Comment by grwrn, posted on Nov 19, 2008
I am having the same difficulty connecting to my wireless router by Netgear as well. Even when I know the security code. Even called Netgear upport and did not resolve issue.
Comment by ck91kal, posted on Nov 16, 2008
I have a Netgear wireless router. My itouch finds the router, but says my password is in correct. I know for sure my password is correct. What do you think the problem is?
Comment by Guest, posted on Oct 10, 2008
Just bought hours ago and sane problem. The only way the internet works is if I turn off my security code.
Comment by ralsop9814, posted on Aug 16, 2008
I have an ITOUCH and I am unable to connect to my home wireless network. I have WPA_Personal security with TKIP encryption.
Comment by Guest, posted on Jul 26, 2008
i have same problem
Comment by ezaban, posted on Jul 21, 2008
hi, how could i repair my internet connection in my ipod?, when i log to myspace i couldn`t log in? my cookies is enable?
Comment by JilyG01, posted on Jul 21, 2008
Me too. It worked great for the first 2 days then went downhill......This sucks. I have reset my wireless modem, made sure everything is set proerly, even reset the whole thing but nothing has worked. I also questioned whether or not the case was blocking the signal...but even without a case, no WIFI. Even at Starbucks and Panera where my computer reads signal strength excellent, my itouch isnt finding a thing...
Comment by samhorr, posted on Jul 15, 2008
same problem worked perfectly until 2.0 upgrade
Comment by lilnigetman9, posted on Jul 14, 2008
I am connected to my wireless modem but my iTouch says that I cant connect to the server. I have tried using the other wireless settings but they wont work either.
Comment by Guest, posted on Jul 09, 2008
can't connect to wifi
Comment by olenka0709, posted on Jun 25, 2008
i have the same problem, i have wpa-psk wireless network security and it doesnt work on my itouch
Comment by Guest, posted on Jun 25, 2008
i have the same problem and it pisses me off
Comment by Guest, posted on Jun 21, 2008
I read solution 3. I am using WEP and a key code (not passphrase) but still I cannot connect my itouch.
Comment by Guest, posted on Jun 15, 2008
same here
Comment by guest613, posted on Jun 07, 2008
ITouch picks up router signal but when password is entered
message comes back "Unable to join the Network
Comment by spencieca, posted on Jun 05, 2008
I have the same problem with the iTouch...grrrrr
Comment by Guest, posted on May 30, 2008
i have got the same freaken problem!!! :(
Comment by khanvict, posted on May 23, 2008
my wifi willl connect to my wireless, but when i try to go in safari or youtube it says cannot find server. i have tried reseting the network settings and all.
Comment by bentceo, posted on May 23, 2008
Itouch will not connect to mt home wireless network even though it appears in the listing
Comment by Harshasks, posted on May 20, 2008
Same problem
Comment by Crash-hard, posted on May 18, 2008
iTouch is accessing via my wireless network. It shows that it is connected to the server and my router shows it connected.
Comment by Guest, posted on May 15, 2008
Itouch sees my router but "Server cannot be found" message
Comment by llamachop, posted on Apr 11, 2008
itouch finds my router, good signal, but I get a "cannot find server" message and can't connect. What do I need to check. I turned the WEP off to simplify. Didn't make a difference.
Comment by Guest, posted on Apr 09, 2008
When i touch receives a signal from the router a message comes up unable to join the network
Comment by Guest, posted on Mar 31, 2008
My itouch just says cannot connect to the server, I have full bars, and it finds the router, worked in the apple store  Mike
Comment by Guest, posted on Mar 29, 2008
message comes back "Unable to join the Network "
Comment by Grrrrrrrr, posted on Feb 28, 2008
My i-touch shows the wireless networks, but when I enter my password it never works...
Comment by Guest, posted on Feb 21, 2008
i touch not connecting to my wirelsess internet
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PDAs Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
