Question about Canon DR-5010C Path-Through Scanner
Scanned image on left is cropped by a good quarter of an inch.
Just used this scanner during last tax season, so it should not be having a problem! Love it, but this is a new issue. How to get the image scanned far enough to the right so the left side shows? The plastic guides do not seem to be the problem. Thanks!
  • 490 Answers
To get the image on the right side, Select 11" wide and the length you want. Keep the paper guides at the far ends. Insert the paper at the extreme right side and the image will appear on the right side. The left side would appear dark and You may need software to clean. If you dont have Raster Editing software, best way is to stick your image onto a white paper and scan the whole paper. Ensure that the ends are trim. ( I am assuming it is faceup scanning)
S. Mohan
Posted on Mar 05, 2008
Can I use my scanner to scan documents into Powerpoint Presentations? How do I do it?
You can scan the document as an image, and insert the image into the presentation.
BMP is preferred over a JPEG (image quality).
You might have to use a graphics program to crop and / or rotate the scanned image before use.
Free software - check the list here: http://mashable.com/2007/10/27/graphics-toolbox/
Jun 11, 2011 | HP Officejet Pro L7590 All-in-One InkJet...
Document is scanning upside down
Easiest way to confront this problem is to rotate the material being scanned.
If you find the image of the item is being inverted then simply rotate the material being scanned by 180 degrees.
Additionally most scanning software will have a ROTATE function where you can rotate the image of the scanned material, usually in 90 degree increments which can be useful for editing purposes. You may find this function under Edit or Image in your scanning software.
Good luck! William
Mar 02, 2011 | Canon DR-2050C Path-Through Scanner
How to enlarge scanned photo.
Set your scanner to scan at 600dpi.  That will give you a 8x12 image at 300dpi (print quality- your image never needs to be more than 300dpi).
Then use your favourite image editor to crop the image to 8x10.  If you don't have a favourite image editor, XNView (free) will do it:
http://www.xnview.com/
-Open the image in XNView
-Right click on the image, select "Set Selection Ratio --> 5:4"
-With your left mouse button, drag a square on the image...this will automatically scale so it chops the unwanted 2" off
-When the square is selecting the bit you want to keep, select "Edit --> Crop"
-Then we need to change the image from 600dpi to 300 dpi:
-Select "Image --> Resize"
-Uncheck the "Resample" and "Keep print size"
-"Keep ratio" should be checked
-Change the 600 in the "Units" box to 300; the setting unit should be "Pixels per Inch"
-Print
Mar 11, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Preview results in random croppings, rotations, and added pics
Hi I'm having a similar problem and haven't managed to fix it. Have you solved it? Thanks Martin
Mar 07, 2010 | Epson Perfection 4990 Flatbed Scanner
We have a Canon Scanner Canoscan N124OU. We have
hey try to crop it, once the scan image is been previewed the sides of the scanned image can be resize, try to resize it by using your mouse.
Oct 25, 2009 | Canon CanoScan N1240U Flatbed Scanner
CanoScan LiDE 20 started stretching image at the beginning of the scan, continuing just fine afterwards. Bottom part of the image (in my case a letter-size page) will not fit, about 1/4 of an inch would be...
Hi pallada,
This might be a case where we address the symptoms rather than the problem.
Instead of positioning the paper to be copied at the normal position, drop it down to the 2" mark. Then on the preview screen, adjust the area to be scanned down accordingly.
This should allow a full letter size scan with no loss, truncation or stretch.
Best regards,
Mike
Jul 18, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
Digital Photo Converter
al introducir una foto en la bandeja, en la pantalla se ven muchas
lineas, como si la foto estuviera en movimiento.
Tengo un convertidor digital Vupoint.
gracias, marilú
Apr 30, 2009 | Office Equipment & Supplies
CANON 2080c scanner not scanning bottom quarter inch of page
Check your scan settings. If you have chosen A4 and the paper is slightly bigger, this can happen. It is also possible when the scanner does not pick up the paper in the first attempt because it is worn out. In such an event, you may find a blank on the top of the image. Clean the rollers with a damp cloth. Dont use solvents.
S. Mohan, Chennai, India
Jan 15, 2009 | Canon DR 2080C Path-Through Scanner
Kodak i260 Scanner
This is practically impossible. This can happen only when the file is over written! Check your software settings. May be you have selected 'multipage' option. Try scanning one page and two pages (same sheet). If the file size is different, then it means two files are scanned.
Reload your Driver and check your scanning software. I am assuming you are usning winXP/Win 2000.
S. Mohan
Jul 30, 2008 | Kodak I260 Captiva IA-Express Path-Through...
Scanning Problem
Scanned image is unsatisfactorily cropped
You can turn auto-cropping off or adjust how the image is cropped.
To turn auto-cropping off:
From your desktop, double-click the Lexmark X6100 Series
All-In-One Center
icon.
The All-In-One Main Page appears.
2 Click See More Scan Settings.
3 Click Display Advanced Scan Settings.
4 Select the Scan tab.
5 Click Select area to be scanned, and then select a size from the
drop-down menu.
6 Click OK.
To adjust how the image is cropped:
All-In-One Center
icon.
4 Click the Scan tab.
5 Select Auto-crop the scanned item.
6 Slide the Tolerance bar to the left to crop less or to the right to crop
more.
7 Click OK.
Dec 06, 2007 | Lexmark X6170 All-In-One InkJet Printer
Canon DR-5010C Path-Through Scanner Logo
158 people viewed this question
old marine
old marine
