Question about Sony VAIO VGC-V617G PC Desktop
Black Screen Every time I start up my computer, you can hear everything running but the screen is black. We had a Dell tower and monitor before and everything worked fine, but my boyfriend and his brother decided to trade towers and now we have a dell monitor and a gateway tower. Ever since they switched, the screen has gone black. But it worked for his brother before they switched? When we first turned it on since the trade, it was black and in the middle of the screen it said "on power safe mode press any key". But the keyboard we originally had didnt fit into the new tower. So i went and got a new cord and now it fits. After that we turned the computer back on and now it still is black but it doesnt say anything in the middle. I tried pressing keys but it just does nothing. Can someone help?
  • Redhead77 Feb 08, 2008
    Ok I will definately try that thank you so much. And also, I just tried my computer one more time and - does it matter that when I turn on the monitor, the light on the power button only turns orange. It doesnt turn green when it is usually on. Does that mean its not turning on all the way or does that not make a difference? Thank you again.
    President:
  • 2,351 Answers
Look in the back of the Gateway where you currently have the video cable connected. If there are two connectors, (Side by Side) there than disconnect & re-connect to the other. Your display should come up. Don't be fooled. Most Pc's that have no display on their monitor is not a monitor problem but a computer problem.
Posted on Feb 08, 2008
  • Mike Peluso
    Mike Peluso Feb 10, 2008
    You have a Gateway PC & a dell monitor. Your Dell monitor's power on light comes on to green but goes to a steady amber in a short time. (Amber light means standby mode). You have no display on the monitor. Again you already know the monitor works. It did for you before the trade. If the Gateway has two VGA connectors that come out the back of the Pc. Switch between the two femal VGA connectors. One or the other should show display on the monitor. (porviding the monitor is on). Check the cable connected to the monitor. It must be securely connected. If all this fails you have only two other choices. One, the monitor went bad. Or the video card in the gateway needs reseated. Since I do not know what model the gateway is I can not suggest any other possible suggestions. Your best option is to "undo the trade".
Dell XPS 600 turns on, However does not boot. Screen is black....
Do have windows installations disc put it computers cd reader.if windows when windows start from the disc choose to repair go back in time before the accident.
Mar 30, 2013 | Computers & Internet
Only says cable disconnected on screen
May be your monitor cable has been faulty.You can check it from service center.
Mar 24, 2010 | Dell E551 15" CRT Monitor
No picture screen black
un plug the monitor cables power cord everything turn off the computer the reconnect everything power back up turn on the monitor should work then
Feb 06, 2010 | Dell E173FP 17" LCD Monitor
Dell d520 monitor goes blank while booting up(goes blank when starting windows). Everything boots up(I can hear the audio in the background)except its a black screen. I tried all safemode possibilities but...
just had this experience myself on a smasung monitor. I originally thought of power management but Samsung assure me it is a monitor sync problem and have yaken it away. Theyhave replaced the monitor. So conclusion is that your monitor is also in need of repair
Aug 19, 2009 | CMS PRODUCTS 80GB 7200RPM NB HD SATA-DELL...
Dell Computer Monitor - Black Screen
If it worked on a computer at the IT person, it is most likely a faulty graphics card in your computer. You may want to get that checked out.
Please vote if this helps.
nLinked
Computer Support Services
Jun 08, 2009 | Dell E193FP 19" LCD Monitor
Blank screen
Hi!
A simple test is to connect another working monitor, to figure out if the problem is at cable connection or at graphics card 's output, and replace properly.
good luck!
Dec 26, 2008 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Dell desktop running windows XP
You should be left-clicking when the option for safe mode comes up...
Dec 15, 2008 | Dell Inspiron 8500 Notebook
Video problem on my Dell Dimension 4600 PC, HELP ASAP.
the resolution set by default when you load your graphics driver is outside the range of your monitors capability.
try starting in safe mode then adjust your resolution to 640 by 480 then restart.
if this works, adjust upwards to 1024 by 768
then up again till the screen blanks.
when it does, dont panic, wait 20 seconds and the settings will restore - you then have the optimum settings for your monitor.
good luck
Nov 18, 2008 | Dell Dimension 4600 PC Desktop
Dell inspiron 1150 laptop black screen
Can you hear the Windows startup noises but can't hear it?
Does it work plugged into an external monitor? (Any good CRT or flat screen should work.
Be sure to plug in the screen before you turn it on.
If it doesnt output to the LCD automatically you may have to hit FN-F8 to switch to external.
If it works on external monitor you are just dealing with a screen problem of some sort - either a bad inverter or backlight in the LCD most commonly...
Let us know.
Dec 17, 2007 | Dell INSPIRON 6000 CENTRINO...
Sony VAIO VGC-V617G PC Desktop Logo
290 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
