Question about D-Link DP 300U (DP-300U) Print Server
To install hP psc 1315 on the D-link dp-300u
I was not able to install the printer on mthe server. When I select I "have Disk" and select the drive no option comes out.
How do I install the printer for the Print server?
Thanks
Hope
  • 38 Answers
You might try to browse to that disk and see if there are any setup files (usually named setup.exe or install.exe). I've seen some drivers don't need to be installed by an installation program not by the new hardware wizard.
Posted on Feb 10, 2008
Can't find my usb Printer on my D-Link DP 300U (DP-300U) Print Server What to do anyone
ok have you tried changing the settings in the print server usually a printer must be configured on the print server before it can be used if it is on the network try telneting in to it through a web browser like you may a modem
Oct 13, 2011 | D-Link DP 300U (DP-300U) Print Server
How do I set up and configure a DP-300U Dlink printserver for the first time on a desktop computer running on Windows XP professional operating system. The printer model is Hp laserjet 1018.
here is the user manual for the DLINK
http://www.givemefile.net/manuals/printing_server/d-link/file/33217.html
also this is the link for the printer
http://h10025.www1.hp.com/ewfrf/wc/product?product=1814094&lc=en&cc=us&dlc=en&lang=en&cc=us
Mar 18, 2010 | D-Link DP-300U (DHDP300U) Print Server
Hp 1020 dp-300u
dont' worry about what the d-link site says. its because they haven't tested it. i got my dp-301u to work fine with my hp1020 on 2 different workstations with the following steps.
1. install printer locally via usb and test.
2. create a second printer as per the dlink manual creating a port. don't worry about the name as we will delete it.
3. once created go into the properties of the 2nd printer and change the port to something local - anything will do to free up the port.
4. go into the properties of the printer that was created in step 1. and change the port to that of the print server.
5. test print. should work fine.
cheers!!
Apr 13, 2009 | D-Link DP 301U (DP-301U) Print Server
I lost my driver cd of hp 1315 printer .i want to instal it
Hi ,
Please find and download the drivers from the bellow mentioned link.
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_pagetype=s-002&h_query=HP+PSC+1315+All-In-One+InkJet+&submit=Go+%BB
You would get a choice of selecting any three drivers and softwares related to your printers. All work. Please select the correct OS.
Donot forget to rate this link.
Mar 20, 2009 | HP PSC 1315 All-In-One InkJet Printer
HP LJ P1008 can be used as network printer ?
I have one of theses D-Link PD-301U. It does NOT support a printer like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1008 is NOT in the list):
LaserJet
  • 1200
  • 1500 (USB 2.0)
  • 2200
  • 2200D
  • http://support.dlink.com/faq/view.asp?prod_id=2135&question=DP-300U%20/%20DP-301P+%20/%20DP-301U%20/%20DP-311U%20/%20DP-G310%20/%20DP-G321
    Feb 10, 2009 | D-Link DP 301U (DP-301U) Print Server
    DP 300U
    DP 300U's can get be pretty uncooperative when attached to a different router. One solution is to reset the DP 300U to its factory settings. Use the PS Admin software to do this. (If you lost the PS Admin software, you should be able to download it from the internet.) If the software prompts you for a password and you do not know it, try "SYSXXXX", where XXXX is the last four digits of the MAC address located on the underside of the print server.
    After you reset the DP 300U you will need to set it up from scratch, a process which is not particularly intuitive. Refer to your "Quick Install Guide" (download it from D-link's web site if you don't have it anymore).
    Oct 17, 2008 | D-Link DP 300U (DP-300U) Print Server
    Having to reset (unplug) daily
    Check the Printer spool service. If documents are getting increase in que, restart the Printer spool services. It will definatly solve your problem.
    Oct 03, 2008 | D-Link DP 300U (DP-300U) Print Server
    Configuring a Mac Book Pro laptop with a DP 300U Print Server
    I connected my HP5MP to the DP-300U LPT1 port.
    I configured my port on the DLink Configuration tab, giving it a name "hp5"
    ...The default login is at http://192.168.0.10/ user:admin pass:(there is no pass by default)
    On my Mac, I go to System Preferences > Print & Fax
    Click the + to add a new printer
    Select the IP option
    Choose the Protocol: Line Printer Daemon - LPD
    Type in the Address: 192.168.0.10
    Type in the Queue: hp5
    Print Using: Generic PostScript Printer or better yet, 'Select a driver to use...'
    and find the driver for your HP LaserJet 5MP.
    Save it. Works like magic. ;-)
    If you change the IP address or password on the DLink, just CYA and write it all down on a sticky note then tape the note under the DLink chassis. There's no reset button on the thing, and if you're o a Mac, you won't necessarily have access to the Windows utility to jack with the DP-300U. So, write it down, kidd-o!
    Sep 07, 2008 | D-Link DP 300U (DP-300U) Print Server
    DP-300U revB and KONICA MINOLTA bizhub 163
    I have just setup DP-300U rev.B1 with my Konica Minolta Bizhub 162, the thing is that it doesn't work with USB port connected (paper out), then I tried connecting Bizhub 162 to LPT port, and it works just fine...
    Jul 17, 2008 | D-Link DP 300U (DP-300U) Print Server
    D-Link DP 300U (DP-300U) Print Server Logo
    454 people viewed this question
    Top D-Link Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
