Yamaha RX-V757 Receiver Logo
Posted on Jan 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Yamaha RX-V757: Tuner not working
Yamaha RX-V757:
When trying to listen to the Tuner I get the following message:
CHECK ANTENNA.
I did and it hasn't changed. Connected OK. No sound.
John
Level 2:
  • Expert 510 Answers
  • Posted on Jan 12, 2010
John
Expert
Level 2:
Answers
510
Questions
Helped
193609
Points
885
Is it set for XM / Sirius? If so, you need their special antennae unit; or are you talking AM & FM?
Yamaha rx v757 av receiver
tape out to line in on eq, line out from eq to tape in on receiver, use tape monitor switch to make eq work
1helpful
No sound from tuner with station tuned
Check you have the plugs in the correct ports, there are manuals at
Yamaha Manual Library
My Yamaha RX-V757 Receiver wont turn on at all, everthing has gone blank??? Help
There are internal fuses in this unit.
Check these fuses first.
If you find a fuse that measures open, and the glass isn't black or black/silver then simply replacing the fuse may do the trick.
Make sure you get an EXACT match for the fuses, some are slo-blow because of the power on surge it has to allow.
I am trying to turn on my sirius radio (it has been working for 1 year) and all of a sudden it says 'check sr tuner'. Everything seems to be plugged in right yet it still won't turn on. Any ideas?
Page 62: If "CHECK SR TUNER" or "ANTENNA ERROR" appears in
the front panel display, the connection of the SiriusConnect
tuner or antenna is incorrect. In such cases, check the
connection of the SiriusConnect tuner and the antenna (see
page 115).
• If "NOT SUPPORTED" appears in the front panel display, this
unit does not support the connected SiriusConnect tuner.
Or the SR Tuner is fluky. Refer to its manual and start over with IT as the product, not the Yamaha.
Can a yamaha ipod dock connect to an rx-v757 receiver?
You can connect him true the auxiliary inputs with an adaptor cable 3.5mm to rca
My Yamaha HTR-6050 shuts off at random times and says "Check SP Cable"
i think it means speaker cable?
http://www.fixya.com/search/p514076-yamaha_rx_v2700_7_1_channels_receiver/check_sp_cable
Yamaha RX-V757 No Left Channel Output - Video Sources Only
First - make sure it is not a defective cable by reversing the leads/colors on the inputs if problem then goes to the right channel then you know it is a bad cable/RCA, etc., connector. I would try that first.
Thanks,
dthomas
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
