Question about Frigidaire FEF366 Electric Kitchen Range
Glass top stove
A friend set (used) a cast iron skillet on the burner. now there are black marks on the burner. is there any way to remove these marks?
    Genius:
  • 1,073 Answers
You can try a flat blade rasor blade, cerama brite smooth top cleaner and some elbow grease
Posted on Apr 13, 2008
We have a Thermador glass ceramic cook stove Model CET. Can we use a copper infused ceramic skillet? Thanks
I have a glass ceramic top on my Jenn Air and I use one of those new skillets on it all the time, so, yes. It does seem to heat up a little slower than my cast iron skillets, but I've encountered no problems.
Jan 19, 2018 | Thermador Kitchen Ranges
Can I use a cast iron pan on glass cooktop range
Yes you can, magnetic induction stoves are working with anything metalic.
Mar 17, 2015 | Kitchen Ranges
Can I use Cast Iron Pots and Skillets on my new Frigidaire Gallery Stove Top?
Hello friend, thanks for your post!
It is not recommended to use any cast iron pots or skillets on a Frigidaire smooth top. In your manual it provides the best type of cookware material and cast iron is a poor heat conductor. Due to the weight of the cast iron it can cause scratches or damage the cooktop. I hope this information has been helpful. -Matt
Oct 09, 2014 | Kitchen Ranges
How should I store my cast iron skillet?
Ensuring that a Cast Iron Skillet stay "Rust Free" is to keep it "Seasoned". Wash with little soap and hot running water. Then pat dry... then onto the stove top it goes for 2-3 minutes for complete drying. Have a paper towel with "some, not a lot" of shortening or vegetable oil on it, ready. Once the 2-3 minutes on the stove top is complete, Keep the stove on... rub your oiled paper towel, all over the warmed up pan, then take a dry paper towel, and wipe evenly - removing excess oil. Place on the stove top once more before storing away, for about another 2 minutes.
Store with the lid and place another dry paper towel inside the pan, while storing.
Do this, and your cast iron cookware will outlive you!
Jan 16, 2013 | Home
Can one cook with iron skillet on glass top electric stove
Cast iron is NOT recommended to be used on a glass cook top due to its weight and potential for damaging the surface. Cast iron also heats rapidly and retains heat for a long time. Its great for gas stoves, but not a good idea for a glass surface.
The best cookware to use should be lighter in weight, have even heating properties with a SMOOTH flat cooking surface on the bottom for proper heat transfer. Some cookware that IS approved for use on a glass cook top is baked enamel, stainless and copper.
NOTE: Cooper and Stainless can leave marks on the cook top, but these marks do come off with most approved cook top surface cleaners.
If in doubt, always refer to your owner's manual. It explains in detail how to select the proper cookware for your range and the limitations and/or characteristics of each. If you have any questions, please let me know. I hope this helps you.
Dec 29, 2009 | Frigidaire FEF366 Electric Kitchen Range
Spot on Jenn Air smooth cook top stove with down draft.
Use Cooktop Cleaner with a soft micro cloth. Don't use water. Buff until the mark disappears. Hint: Never clean the cooktop until it is completely cool to touch as doing so makes cleaning much harder. Never use abrasives on the glass or abrasive cast iron skillets.
Mar 26, 2009 | Jenn-Air JED8430 Electric Cooktop
How to clean the cast iron grates and stove top of a gas range
glass cleaner WITH ammonia, and a small toothbrush works well. mop up with an old washcloth, rinsing often. for pieces which have gummy residue, and which can be removed to the sink for soap and water finsing afterwards, try GooGone.
Mar 12, 2009 | Viking VGSC306-4B Gas Kitchen Range
CAN YOU USE CAST IRON SKILLETS ON RADIANT GLASS COOK TOPS?
you CAN use the skillet, but not with great results id assume, it holds too much heat, and problaby a bit too rough underneath and would probably scratch the glass top, in a family business for over 20 yrs. now and thats my recomendation, my brother also in the same feild swears his wife uses it with no issues!!!
Dec 30, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Cast iron pans
Cast iron cookware is NOT recommended due to the weight and the potential damage it can cause to the glass top surface. There's nothing better than a good old-fashioned cast iron skillet that's been broken in over a number of years of use, but they are better suited for gas ranges rather than electric. I hate it. I have several cast iron skillets that I only use on the outdoor grill, because I currently own a glass top electric range.
Aluminum bottom pans and copper bottom pans heat well, but can leave metal transfer marks on the cook top surface. If the marks are cleaned after use with an approved stove top cleaner, you shouldn't have any problem retaining the condition of the glass surface, however. Stainless Steel seems to offer good resistance to metal transfer, but takes a little longer to heat than aluminum or copper. So...you have somewhat of a trade off. Baked enamel cookware seems to be the best recommendation because it heats wells and causes the least amount of damage to your glass top surface.
IMPORTANT: Make sure the bottom of your cookware is FLAT. If your pans are warped or bowed, this can cause uneven heat transfer on the heating elements and potentially cause the cook top to crack. Most manufacturers will not replace the top if it still under warranty if it is determined that your cookware caused the problem.
A little over kill, but I hope this helps you.
Feb 14, 2008 | Maytag MER5770 Electric Kitchen Range
Smooth Top Electric Range
You didn't specify which type of smooth top - some, like the induction require special cookware. For the typical radiant type glass top nothing special is required.
Jan 03, 2008 | Kitchen Ranges
Frigidaire FEF366 Electric Kitchen Range Logo
282 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
