Question about Brother MFC-5440CN All-In-One InkJet Printer
How to empty fax memory.
Unable to send faxes even real time. Shows 99% full. Dials and goes thru the motions, but doesn't send.
The setting for resolution was too high. Set back to basic and fax went through--no more problems.
Posted on Feb 09, 2008
When sending a fax it connects and sits there then I get fax server then line error
It could be the recieve fax unit. either no paper, full memory or wrong class.fax machines have to be the same class in order to talk. Otherwise your send/receive pwb is bad.
Mar 24, 2018 | Sharp Office Equipment & Supplies
How to clear the memory on a brother mfc-240c-- error when faxing is out of memory
You can also try to send the fax with Real Time Transmission ON so that memory will not be full.
Sending in real time for all faxes
a Make sure you are in Fax mode . b Press Menu, 2, 2, 3. 3.Real Time TX Realtime TX:On
c Press a or b to choose Realtime TX:On or Realtime TX:Off.
Press OK.
Please click Yes if this helped
Thanks,
vikroks
Feb 05, 2011 | Brother MFC 240C All-In-One InkJet Printer
No print on copies or faxes
This is a clogged print head. This happens if the printer has been off for a long time or if the cartridge was removed and the unit left empty for any time.
Take out the cartridge and press the print part on a piece of paper. Any black lines? If not, you will need a new cartridge. Wiping the print head gently with a Q-tip moistened with PURE alcohol (99%) may restore printing.
Mar 31, 2010 | HP 1040 Plain Paper Inkjet Fax
OUR FAX SAYS 98% MEMORY FULL SOMETIMES WHEN THEY TRY TO FAX SOMETHING. HOW DO I CLEAR THE MEMORY? NATALIE
Press Menu, 2, 5, 2. The screen prompts you to choose a fax setting. Press <-- or --> to select OFF then press SET. If there are faxes in memory when you turn Fax Storage to OFF, the LCD prompts you to erase faxes in memory. If you press 1, all fax data is erased and Fax Storage is turned OFF.
You may want to enable Real Time TX so you can send fax without using memory. (Under FAX-SETUP SEND-REAL TIME TX)
You may also disable Fax Storage if you don't want to store incoming faxes in memory for remote retrieval (Under FAX- REMOTE FAX OPT-FAX STORAGE)
For effective use of the memory, you may also clear the caller IDs stored in the memory. Press MENU, 2, 0, 2 Press the arrow keys to display # then press CLEAR.
Hope this helps!
Jul 08, 2009 | Brother IntelliFAX 4100 Laser Fax
Can not send more than 99 pages as PC fax.
Like every fax machine, there is a limit to how many pages it can keep in memory before needing to be cleared. Yours is apparently only 99. If you want to send more than 99 pages at a time without clearing the memory, i'd look for another printer.
Jun 12, 2009 | Brother MFC-7820N Printer
Unable to enter faxes while the machine is either sending or rece
turn off
When you are sending a fax, the machine will scan originals into memory before
sending. Then, as soon as the phone line is free, the machine will start dialing and
sending the fax. If memory becomes full, the machine will send the document in real
time (even if REAL TIME TX is set to OFF).
Sometimes you may want to send an important document immediately, without
waiting for memory transmission. You can set REAL TIME TX to ON.
1 Place the original face down in the ADF.
2 Press Menu, 2, 2, 6.
3 To change the default setting, and then
press or to select ON (or OFF) and
then press Set. Go to Step 5—OR—For
the next fax transmission only, press or to select NEXT FAX ONLY,
and then press Set.
4 For the next fax only, press or to select ON (or OFF), and then press Set.
5 Press 1 if you want to select additional settings. The LCD returns to the SETUP SEND
menu—OR—Press 2 if you are finished choosing settings, and then go to Step 6.
6 Enter fax number and then press Fax Start.
May 23, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Can't send faxes. Dials Ok but no connection to send fax
If you are unable to send the faxes, please try decreasing the modem speed and disabling the "Error Correction Mode." To decrease the modem speed, please follow the steps given below:
1. Press the "Fax" button.
2. Press the "Options" button 15 times till it reads "Advanced Fax" on the display.
3. Press the "Select" button.
4. Then press the "Options" button 10 times till it reads "Max Send Speed."
5. Now press the "Right Arrow" button and choose "9600 bps."
6. Press the "Select" button.
To disable "Error Correction," please follow the steps given below:
1. Please press the "Fax" button.
4. Then press the "Options" button 11 times till it reads "Error Correction."
5. Now press the "Right Arrow" button and choose "NO."
May 19, 2009 | Lexmark X4270 All-in-One Multifunction...
Sharp FO 4400 full memory after power surge
Try holding down the stop and start keys while turning the power on and see if that clears the problem.
Andrew
Mar 16, 2009 | Sharp FO-4400 Fax
Canon MIXPA MP530 Memory is full
I found this in a forum and I suspect it will work, remember that you'll need to clear the internal memory chip by unplugging the printer:
I got the dreaded "memory full" problem with my mp530 this morning. Couldn't FAX because the mp530 thought its memory was full even though it showed no documents in memory. The Canon site lists this symptom with a solution of 'turn off the unit, wait 10 seconds, then turn it back on'. Well that didn't work, so after multiple tries I noticed a post on this board (not really related) that suggested turning off the unit, unplugging it and waiting 10 minutes -- and that did the trick.
Dec 12, 2007 | Office Equipment & Supplies
Brother MFC-5440CN All-In-One InkJet Printer Logo
87 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
