Question about Sharp 65DR650 65" Rear Projection Television
65 inch Sharp DLP TV
I was watching it and it went out. It has come on a few more times. What can I do, is it expensive if I have it fixed? or am I better off buying another tv?
  • MMosley Nov 25, 2008
    my TV wouldnt turn on last night and then started smelling like an electrical fire. Is it worth having someone come out and look at it?
The same thing happenned with our shar dlp 65" and I just found the lamp on ebay for under $100
Posted on Aug 10, 2008
  • 87 Answers
You likely just have a bad lamp. It is possible the light engine itself is causing the problem but the easiest way to determine which one is giving the problem is to replace the lamp. If the problem still persists the light engine is likely bad. The light engine is about $1000 plus installation. The lamp is $349.
Posted on Feb 08, 2008
Black bar on dlp do I fix this?
Sounds like a connection problem between board and DLP chip. The BGA connection which connects the DLP chip to the board, or the flex connector may be bad, causing the row and column section to not activate the micro-mirrors on the DLP chip. Not an easy fix. Regards.
Nov 23, 2015 | Mitsubishi WD65737 65" DLP TV
I have the Mitsubishi WD-65738 65-Inch 3D DLP HDTV I was watching it and it made a pop sound, then the screen went black what can I do.....
Tv "LAMP" LED light indication on the tv frame word light up or blinking LED light.Check the tv projection Lamp first.The tv projection Lamp might litterly broken into glasses sharts itself.The tv projection lamp still intact,still should be change too though.After the tv projection lamp has been change the tv should work now.If still have problems the board that call the Balast board probally dead too.Becauuse this Ballast board only jobs are to help to ignite and keep tv projetion lamp light up and to work only.
Sep 01, 2011 | Mitsubishi WD65737 65" DLP TV
My 65 inch flat screen Toshiba tv has tiny white spots all over the screen. Can I change anything to save the tv? Any help is appreciated.
This is an easy fix, just change the DLP chip.
I bought one on Friday and it got here yesterday, I followed the video instruction on Utube. I spent maybe 1 hr, because I kept going back and forth from the tv to my PC to watch the video.
The chip is soooo easy to replace, and only cost about 150 bucks at
Apr 19, 2011 | Toshiba 65HDX82 65" Rear Projection...
I have a 65 inch DLP and when i turn it on i get no picture and just the sound of static comming out of the front tv speaker, no actual audio from the cable box. When looking near the bulb box i see the...
When was the last time u change the projection lamp?If u watches tv at lest 4 or 5 hours a day and the projection lamp has not been change the last 1 1/2 or 2 years.This problems happen alot,when the projection lamp life is over.Change the projection lamp.
Sep 03, 2010 | Mitsubishi WD-65731 65" HDTV
U hear grinding noises,squiling noise,before colors fades in&out,turn to Black&White picture,than died?Yes,than ur DLP tv have a colors wheel,it defective,require replacing.The colors wheel is spinning off of it motor axis.The tv tech,should be hire for changing the tv colors wheel.
Jul 24, 2010 | Sharp 65DR650 65" Rear Projection...
We have a Mitsubishi 65 inch dlp hd 1080p and we had a bad storm but we do have a surge protector on the tv. When we went to watch the tv after the storm it turned on fine but the dish had to reboot. After...
Something died in there - perhaps a capacitor or a solid state device just blowing and cracking into pieces. happens. Open up the set and see if you can spot it around the power supply area.
Aug 30, 2017 | Mitsubishi WD-62525 62" Rear Projection...
Air flow blocked...turning off in a few seconds message
"air flow blocked" means its getting too hot. or it thinks it is. it is quit common on these set that the thermal sensor has malfunction replaceing this sensor is your solution. since this is service bulliteen item at service centers of mitsubidshi products this may be an item covered under warrenty. so i would first check with you local service shop too see before
Jun 04, 2009 | Mitsubishi WD-65731 65" HDTV
Sharp 65DR650 65" Rear Projection Television Logo
625 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
