TURNS OFF ON IT'S OWN
My TV turns on fine, then it gets louder and turns off by itself. How can I fix this problem?
  • nankomah Feb 08, 2008
    This is a Pioneer SD P5191-K
    President:
  • 4,402 Answers
Need make and model
Posted on Feb 08, 2008
  • Cary Farah
    Cary Farah Feb 08, 2008
    pioneer sdp404 immediate or intermittent shutdown r266 160k 1/4 w use 1/2
    w
    TELEVISION Pioneer SD-P404 intermittent shutdown pull T551 and scrap
    leads, poor connections to board
    Check the vert output ckt and solder the sweep bd completely.
    good luck
    please mark the post with a fixya!
Just bought a vizio, the tv turns on real pixelated but fixes itself in 15 seoncds
If I have trouble with a brand new TV I always take it back and am sure to get another brand entirely. Personally I've had good luck with LG, SEIKI, and Samsung.
Jan 06, 2015 | Vizio Televison & Video
TV turns off and immediately on again, by itself.
sounds like a defective str power regulator ic .......but my advice get a tech to resolder all the pins at the power suppy board area, there may be some open pins that triggers the on and off episodes
Jul 18, 2013 | Televison & Video
When you push a button on the remote, it either does nothing, or the channels start flipping all the way through from 2 to 120 and then start over. It is the same with the volume, if you hit it, it just...
If it doesnt happen when you change the channel or volume on the tv itself then i would recomend getting a new remote. You could probably get one on ebay. Most manufacture remotes will work on all of their tvs.
Nov 18, 2009 | Polaroid Televison & Video
Philips Magnavox TV turns itself off and on
I had a problem that has not been fixed that i had put glass cleaner on my tv and every time i turn it off it comes back on sooo i do not have a solution so i need more and cheap ways to fix my tv.
p.s. i am 9
May 19, 2009 | Philips Magnavox 32PS55S 32" TV
Toshiba 27af45 turns off by itself every 15 minutes..how do I fix
I think the timer setting in your TV is broken. Try fixing this.
May 07, 2009 | Toshiba 27AF45 27" TV
Volume turns down by itself
Its the buttons on the tv, they need to be replaced, or replace the whole key pad on the tv. that should fix ur problem
Mar 17, 2009 | RCA F36650 36" TV
Projection tv has really loud buzz or hum
You may not see any deterioration in the picture when the color wheel begins to go bad. The noise will get louder and eventually, it will shut down or the wheel will shatter while the motor continues to spin. If that happens, you'll have a black and white picture.
If its a Samsung DLP that is mercury vapor lamp driven, its a safe bet the color wheel is going bad.
michtech
Feb 11, 2009 | Samsung HL-R6167W 61" HDTV
Turns on and off green LED flashes until TV turns back on.
this is a symptom of a bad lamp. for some reason it won't spit out a lamp error. shaking up the lamp will sometimes fix temporarily but you will find replacing to be the answer. if your tv has a fan error, you will get 4 red blinks.
Dec 09, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Toshiba 62hm94
sounds like a connection issue between the lamp and ballast.
Nov 13, 2008 | Televison & Video
No pic
alright guys...blew a bulb....fixed that. still didint work...found out it was ballast...replaced that. tv worked for a month..all the sudden hdmi input didint work id plug in my playstation and screen would turn green and say "hdmi color has been corrupted" im thinking wtf? so a week later it works fine then just turns off in middle of watching espn... comes back on an hour later...only to turn off again...it just turns black for ten seconds then just turns off and the red and green lights blink at intervals of one second....replaced a bulb..not that, same problems.......when the tv comes on for the ten minutes before it quits working the pic and sound are great i just dnt get it...is it shorting out? color wheel bad? a fan?
May 24, 2008 | Toshiba 52HM95 52" HDTV Projection...
Televison & Video Logo
100 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
