Question about Kenwood KDC-3027A CD Player
No CD I can't seem to find the cd function, all I get is tuner or standby when pushing the scource button ?
  • Andymule1 Feb 08, 2008
    Just went and tried a re-set still to no avail. When I push scource I get tuner and standby, also I'm not sure if it's lighting up correctly. The tuner works perfectly and it is storing the pre-sets, it's as if it can't see the cd as it wont let me put one in ?
    There is no cd in the unit as it wont let me put one in and cd never appears when the scource button is pushed, does the cd part have a seperate power supply to the tuner ?
    Brigadier General:
  • 6,966 Answers
The normal source selections for this model when the SRC button is pressed are: TUNER, CD and STANDBY.
If there is no CD inside the tray, or if it is dirty, unreadable, inverted or damaged, then the CD source option will not display at all.
If the there is a known good CD placed properly inside the tray and the CD source will still not show as a source selection, you may need to RESET the unit. The reset button is near mid bottom. This will also erase all settings, memory and tuner presets.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Feb 08, 2008
  • Louie  Role
    Louie Role Feb 08, 2008
    Hi again,
    I am assuming then that there is a known good CD inside the unit and yet no selectable CD as SRC (source).
    Then the issue may be with the CD reader internally. The only easy check (and hopefully repair) is to use a CD cleaner readily available from most computer shops. This looks like any other CD except it has a small brush like protrusion that is intended to clean the laser reader eye/lens.
    If still a no go, am afraid that the unit needs to be pulled out and opened for diagnosis of the CD mechanism and circuitry. This would require that you be familiar with electronics and components, possibly the use of a DVM and a soldering iron. Should you not be comfortable doing a DIY, perhaps your best bet would be to seek the services of a qualified professional.
  • Louie  Role
    The CD power circuitry is integral to the whole unit, one power for all. A couple of possibilities:
    a) there is already a CD stuck inside, you would need a tweezer or something to pull it out other than disassembly;
    b) CD loading mechanism/motor defective, stuck, blocked, it would need to be rebuild;
    c) your 2nd post "...not sure if it's lighting up correctly..." indicates possibility of internal problem perhaps in the power distribution, voltage regulator. Back to the last paragraph of my second post.
Rotel 950 stuck on tuner function
Replace the unit or have it repaired, you have no other options.
Apr 08, 2017 | Car Audio & Video
Hcd-eh15
The laser pickup assembly has a short causing the unit to shut down, The whole assembly would need to be replaced in order to resolve, not worth the cost to repair, cheaper to replace.
Apr 25, 2012 | Sony Audio Players & Recorders
My Emerson stereo MS9903TTC won't turn on. It was working fine last night and this morning when I push the power button nothing happens. I tried selecting different modes, (cd, tape, phono, tuner) but no...
I had the same problem the power button is pushed in. You did not mention if your unit came with a remote control if it did use that to turn your stero on and off. you will not be albe to use any of the buttons on the stereo if the controls are listed on the remote IE; Cd player, radio tape or tuner. try this please. hope this helps
Feb 10, 2010 | Emerson Audio Players & Recorders
Aux problem
You have to go into the standby menu and turn aux on. Go to standby, push menu button and scroll down to aux and turn on
Aug 05, 2009 | Kenwood KDC-MP235 CD Player
Cant get the clock to set
most you hold down the time button and push up or down. try something similiar, hold down a button and push an up button? just play with it but don't reset it andcause more problems
Jun 01, 2009 | Pioneer DEH-245 CD Changer
Driving along and radio stopped working, the word "ocer" came across face of radio. Now, radio and cd player both will not work. Help!
I pushed the reset button and "standby" mode appeared. I proceeded to hit the source button and switched to tuner and cd player with no problems.
Jul 02, 2008 | Kenwood Car Audio & Video
Wont turn on
No, most units will at least work basic functions without a remote. What is the make / model? I would take it back as soon as you can.
Jan 19, 2008 | Audio Players & Recorders
Kenwood KDC-3027A CD Player Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
