Question about Sony Grand WEGA KF60XBR800 60" Rear Projection Television
60xbr800 I received your e-mail and I have attempted to follow the instructions. I am not clear what button to push to make changes. I tried a few times and found that the number 3 button will change from low numbers to higher but I don't know what to push to change from say 11 to 10, 9, 8, 7 etc. Then at the end where the Option-E 11 P CTL SHT1 portion of the procedure is, I don't know how to enter number or how to tab from one location to another. The section before the Option-E O lamp, when at D-GM TG 1 POS CTL. I can scroll up using the #3 button but if I need to scroll back down I am not sure what to push. Please let me know what you think. Thank you for your help. RR
  • dblrhr Feb 08, 2008
    I am not sure if your received my e-mail address for the solution on
    ghosting on the sony60xbr. It is rr@suddenlinkmail.com
    President:
  • 4,402 Answers
Do you have an email address?
Posted on Feb 08, 2008
  • Cary Farah
    Cary Farah Feb 11, 2008
    email sent back with fix please mark soulution as Fixya!
I have listened to all my messages but my handset still blinks and says new voice mail. How do I access those voice mails?
Do it from the Base Unit rather than the handset.
Still doing it?
Remove plug from base unit overnight and the batteries from the handset to reset it.
Nov 29, 2016 | Lands Phones
I can not sign into my gmail account please help me
You could try this:
If you're receiving an error message that says, 'In order to log in to Gmail, your browser must be set to allow JavaScript to set cookies,' we suggest the following:
  1. Open Internet Explorer, and click Tools along the top of your browser window.
  2. Select Internet Options... and click the Security tab at the top of the dialog box.
  3. Click Trusted sites, and then click Sites...
  4. Enter the following sites in the Add this Web site to the zone field:
    • https://www.google.com
    • https://mail.google.com
    • http://b.mail.google.com
  5. Click OK to save your changes.
Next, please clear your browser's cache. To clear your cache, visit the Internet Explorer Help Center for instructions.Close all open browser windows, restart Internet Explorer, and sign in to Gmail. If you're unable to sign in, we suggest removing all of your trusted sites in IE, then signing in again.
If you still can't sign in, try signing in securely by changing the URL to https://mail.google.com
May 01, 2014 | Google Gmail
I have already sign in for my gmail acct but I'm not able to get in
If you still can't sign in, try signing in securely by changing the URL tohttps://mail.google.com.
Aug 20, 2013 | Computers & Internet
Today i went to turn on my receiver and the standby light is on, but wheni push the power button nothing happens.
Try to unplug the AC cable from the wall for a couple of minutes, in order to clear any trouble program. Then plug in AC cable again, with power button off, and press power on in receiver. Do not attempt to use remote for a while. Hope this will help. Flavio/Brazil
Sep 18, 2010 | Audio Players & Recorders
I have a Brother intellifax 5750e fax machine. It gave us a "change drum soon" message. I changed the drum but the message has persisted for several days. There were instructions with the drum that...
There should be either a [Clear] button or an [Options] button on the machine key panel.
Open the front hatch and press the appropriate button. Follow instructions on the LCD display.
Oct 27, 2017 | Brother IntelliFAX 5750e Laser Fax
I inadvertently attempted to send a greeting card using an incomplete email address. Subsequently every attempt to email a card resulted in an error message that the card with the incomplete address was...
I have not tracked down what taman 2005 said. I would try "recalling" the message.
  1. Locate the Sent Items folder.
  2. Open the message that you want to recall or replace.
  3. Click Actions on the ribbon or menu, and then click Recall This Message.
  4. Enable the Delete unread copies of this message option to recall the message.
Check your inbox. Did you received a mail subsystem error message? If so, I would encourage you to delete both the message by which you attempted to send the card, delete it from the sent box of your mail account after you try the procedure above. And delete from your inbox any mail failure message related that refers to the term mail subsystem." Reboot. If this does not fix the problem, consider using an alternative email address to send the card.
Jul 16, 2017 | Hallmark Card Studio 2009 Deluxe Full...
Programming my DishNet remote for my Sony AV System
Hi, the manual for the vip622 (the model I have... not sure what you have) says to use the following codes for Sony Tuners / Amplifiers.
639 645 650 687 728 729 730
(located in the Appendix)
See Chapter 10 here:
http://www.dishnetwork.com/support/documents/receivers/vip622/default.aspx
for instructions on how to program the AUX setting on your remote and how to set your remote to adjust the receiver volume while controlling the Dish receiver.
Mar 28, 2009 | Sony STR-DE597 Receiver
Craftsman garage door remotes
push once the red button on the back, and then push the transmitter button u want to program u should hear 2 clicks inside the unit.. and if u dont.. hold down ur transimitter button .. the led in the back of ur unit should be blinking... otherwise let me know
Jan 13, 2008 | Sears Craftsman LiftMaster Chamberlain...
Keyboard not responding
Solution. My wireles keyboard stopped working except for the F-Lock key, the Media key and the sleep key. It wasn't batteries, even though I tried, communication was there because the above keys were working. Remove the batteries from your keyboard and let it sit for about 10 minutes. Press the red connect button a few times and other various keys every few minutes during that time. This may be the whole "capacitor discharge" trick, but I tired that with someone elses instructions and my keyboard did not work after 2 minutes of key pressing. I think it just needed more time to clear out the secure settings. Good luck, I was about to trash this keyboard until I tried again
Nov 26, 2007 | Elite Logitech Media Keyboard(KB9675590403
Cordless Desktop EX110 Keyboard doesn't respond
Look on underside of keyboard there should be a button to push that will transmit to the receiver
1st push the button on the receiver
2nd make sure batteries are inserted in right direction into keyboard then push the botton on bottom of keyboard
that should make it work
Hope that helps friend
Nov 14, 2007 | Logitech Cordless Desktop EX110
Sony Grand WEGA KF60XBR800 60" Rear Projection Television Logo
75 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
