Question about AOC LM 720 17" Flat Panel LCD Monitor
AOC LM700 17" LCD Screen switches to black and then comes back to normal. Power light never goes green but monitor works. LED is orange when off and in sleep mode, wakes correctly on getting input. Just flicks on a black screen after a while of being on and them flicks back to normal. Several posts are similar that point to an inverter issue but they all seem to get a green light. I have removed the inverter board and will redo the solder connections as has been suggested for somewhat similar isues. If the inverter board needs replacing is it an expensive part?
  • 4 more comments
  • markbose Feb 08, 2008
    Is that probably the issue with it? The green led not being displayed throws me off a bit from that conclusion.
  • markbose Feb 11, 2008
    We I took out the inverter and retouched the solder points and it did not help. The one factor that seems different that other posts is that the power LED never goes green when active it is out and when not connected or "sleeping" it is orange. I think that ties to the isue, any other ideas?
  • markbose Feb 27, 2008
    Sorry it took a while to get back to this. The inverter is a
    • Sampo REV.0
    • L0087
    • 79AL17-Z(or 2)-N
    • AD1H37-D/0151
    Thanks
  • markbose Feb 28, 2008
    Not a pc issue its a monitor issue
  • markbose Mar 11, 2008
    Computer or resolution does not matter. Problem exist on any computer including one it worked on for over a year. Still looking for a 90% answer since at $70 for a new inverter it is a marginally worthwhile repair as 17" have becme disposable. The inverter would seem to be the fix with the exception of the orange light. I have not seen that issue on any post.
  • Anonymous Mar 31, 2014
    After the "No Signal" comes up, then the monitor goes out as into a sleep mode.
    Problem Solver:
  • 18 Answers
There is a known issue with these monitors, which cause symptoms including the display blacking out after warm-up, flickering, and a configuration error displayed on the osd. the cause is the mpu chip, which aoc now has a revised issue- although get it while you can [i've seen it on e-bay, too] because aoc is in the process of obsoleting this part. it's the small square chip WITHOUT the heat sink on it, located toward the top of the main [larger of the two] boards. fyi- the narrower board to the left [both boards have a shield over them] is the inverter board. that can and will cause a black screen if it's defective, but in most cases, the backlight won't come on at all.
Posted on Dec 07, 2008
  • david small
    david small Jan 26, 2009
    regarding the inverter board- it is available from aoc directly [although they are in the process of obsoleting this part] for forty-five dollars, plus shipping [about nine dollars, ups ground]. theire phone number is 888-662-9888. fyi- backlight and display problems [such as flickering, shutting down after warm-up, and error messages] are known to be caused by the mpu chip, which is also still available from aoc [also being obsoleted in the near future], at a cost of either 10 or 20 dollars, i forget which, and the shipping cost- but if you order both items at the same time, there's only the one shipping charge. this chip has been advertised on e-bay from 59 dollars up to like 80 dollars. - so, i would suggest ordering one from the mfg. while you still can! good luck
    Brigadier General:
  • 6,966 Answers
According to LCDParts, an inverter for an AOC LM700 would cost $69.99. Specs (with picture) are available here.
Perhaps you can do a Google for lesser priced versions.
Good luck and kind regards.
Posted on Feb 08, 2008
  • 1 more comment
  • Louie  Role
    Louie Role Feb 08, 2008
    Hi again,
    Based on your description, all points to a cold solder problem. But then again you can't verify till the unit is opened up. In some instances, it could possibly be corroded connectors of the CCF Lamps or blistered capacitors.
  • Louie  Role
    Louie Role Feb 11, 2008
    Mark,
    Copy your last post. That was the easy part. For info only, pls confirm whether the inverter was 79AL17-1-S or the 79A-L17-3-S. The reason for the query is that there are 2 versions of this monitor, either manufactured by CHI-MEI or by Hyundai.
    I am considering the not going to green but stays orange. Will let you know when you post back inverter numbers.
    Cheers.
  • Louie  Role
    Louie Role Feb 28, 2008
    A shot in the dark for the orange light: assuming everything in the monitor is connected right (including inverter), have you tried running the PC in a lower resolution (display properties)? and/or lowering the screen refresh rates? or running another monitor to the PC to verify whether it is the video/PC or really the LCD monitor?
    Had me thinking on the orange a week or 2 back.
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Jan 05, 2016 | Planar PL1700 17" Flat Panel LCD Monitor
My flatron L1710S flat screen will not come out of power saving mode. When I turn on the monitor the power button/light is green for a few seconds, the screen indicated "power saving mode", then...
I switch on my PC, ensuring that all cables, leads and power supplies are connected properly. The tower powers up no problems at all. I switch the screen on, the green led lights up, the screen is completely black. A blue box appears centrally on the screen with the text 'power saving mode'. The green led light turns amber and then the screen just goes black.
Please don't suggest going to control panel, as I can't get that far.
PLEASE PLEASE CAN ANYONE SUGGEST ANYTHING give me
Mar 08, 2011 | LG Flatron L1710S 17" LCD Monitor
My AOC screen goes black after about a few seconds after booting.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jul 26, 2010 | AOC LM729 17" LCD Monitor
AOC color monitor model 5En...during power on all led lights blinks then stops blinking without display action. all led lights on no more action observed.
actually if u repair an aoc monitor alone without getting connected to cpu once u switch on the monitor all led's will lit on ( green light ) it will remain on situation until u connect the vga connector to cpu that's the time led's will lit off and only the power led will remain in green condition.some aoc 5en once u power on power led is in green condition and if not connected to cpu it will be in orange condition.hope u get some idea but i am not sure if it will work with ur monitor. but as long as LEDs lit on i think no problem with ur monitor.
Nov 02, 2009 | AOC 5 En 15" CRT Monitor
Pl2010m orange standby light, black screen
Try booting the pc in safe mode (press f8 at startup). It may be possible that the pc is trying to send too high a resolution to the monitor...unlikely though. The symptom you describe usually indicates that the power board or the inverter board in the monitor are defective. If it does the same thing in safe mode, you have 2 options.
1. Replace the power board and inverter board (do the inverter board first.......it's the cheaper one (10-20 dollars).
2. Send the monitor back to the seller for a refund, or get a new monitor.
Sorry I couldn't give you more positive feedback. Hope this helps.
Joe
Oct 13, 2009 | Planar PL2010M 20" Flat Panel LCD Monitor
No display
Try Unplugging the monitor and plugging back in again,,,you dont have to shut the PC down to do this,,,if it starts backup,,,then good... if it doesnt,,then you need another Monitor.
An LCD monitor is better for your eyes anyway.
Jan 19, 2009 | AOC 1556NB 15"
Acer Al 1714. LED light is blinking (orange not green).Monitor black.
Well, suddenly it worked again. But I waited the whole day >.>
Aug 22, 2008 | Acer AL1714 17" LCD Monitor
Aoc lm725 display off after few seconds
I've had a very similar issue on many Dell Monitors. Mine have been under warranty and they usually send me a new monitor, but I believe the issue lies with the power supply within the monitor.
Jul 10, 2008 | AOC LM729 17" LCD Monitor
AOC LM 720 17" Flat Panel LCD Monitor Logo
875 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
