Audio on my old Sylvania TV
I have a good picture, but no sound. Is the audio just out, or is there a fix for it. I've tried the usual, turning it on and off, checking to be sure it isn't on MUTE, etc. The number on the back is SST4191, but your website is not accepting that.
  • 1 more comment
  • Nana18 Feb 10, 2008
    I decided to junk it and invest in a new set, and a better make and model. Thanks, though.
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    Is there a headphone jack? Are there RCA phono audio output jacks?
    If so, try a set of headphones and see if you get sound there. Try feeding the audio from the RCA jacks to another device, like a stereo.
    Let me know what you find and we'll take it from there.
    - Jim
  • Vista Electronics May 11, 2010
    Chassis # ?......Mo / yr built on back of set ?
    Genius:
  • 1,694 Answers
The audio Output IC most likely is bad AND a current limiting
resistor in the power supply....if you want part numbers, I need
previously requested info.......T.
Posted on Feb 11, 2008
  • 30 Answers
Turn the volume control rapidly then hear if there is a sound.if not replace the audio amplifier ic and tranistor
Posted on Feb 09, 2008
Need help with horizontal hold on 1971 Sylvania TV
it is better to use audio video input of your tv .syncronisation problem in the Rf stage cannot be solved easily.
May 24, 2014 | Televison & Video
Sylvania SRT2232S 32" was working
The problem is in the vertical deflection circuits which is responsible for giving a full picture. Since the set is 8 years old the money would be better spent on a new tv since more frequent break downs in other parts of the set would be more likely due to age.
Sep 15, 2011 | Sylvania SRT2232S 32" TV
My 22 lcd gives good picture but no sound.I've tried connecting an externel head phone but i don't hear any sound.
you're best bet is, depending on your TV's input/output, is to run your video components directly to TV via HDMI, component, etc., of course component requires additional sound cables, then run your sound out from TV via, best, digital optical, to reciever. You use the TV's menu to choose what you watch and, only have the one audio out. Scan your recievers menu to make sure you've got the right channel to listen to.
Jun 28, 2011 | Audio Players & Recorders
Don't have any sound
If the picture is available and no sound, the trouble could be from speaker audio power supply or Audio IC. Check all the audio components. Check the sound mute status before replacing IC
Apr 09, 2010 | Sylvania 6427TE 27" TV
What is sap and how do you turn it off
SAP is an alternate audio program usually seen in markets with different languages. The most common is for a Spanish broadcast of an English program. It is also used to provide audio descriptions of programming for the blind. There should be a menu option under Audio to turn this on and off.
Dan
Mar 03, 2010 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
My Sylvania flat screen sound keeps going off
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/ The most probable cause is with its audio output IC itself; overheats.
May 11, 2017 | Sylvania Televison & Video
Ihave a 32 inch sylvania tv that I bought from sears about 5 years ago. there are audio out rca jacks on the back of the set. I tried hooking up a surround sound system and I got no sound out of these...
Usually those terminals are always on, and the only thing that you can change about them in the menu is audio out fixed(always same level) or variable(level controlled via remote). There might also be a speakers off option in the menu,try it and in your case it might be the switch between internal and external sound. And in the last resort look at the back for a manual switch, otherwise check for faulty cables. You also might have a problem with the set.
Hope this will help. Good luck
Dec 01, 2009 | Televison & Video
Audio on Sylvania TV
You'll have to take the TV in for repair - this is not a DIY possibility unless you're a technician familiar with audio circuits.
Dec 24, 2008 | Sylvania 6427TE 27" TV
No audio on channel
The TV is not the problem. The tv don't know what chanel you are on and the sound works or it don't
Dec 22, 2008 | Sylvania 6615LG 15 in. EDTV-Ready LCD...
Have a beautiful picture but no sound
your problem is in sound section only. 1 signal line for sound coming from vif section 2 supply to audio section. 3 component fail in audio output section. 4 loose contact in audio section 5 speakr & its connecting wire.
Sep 27, 2007 | Sylvania 6427TE 27" TV
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
