Question about Fuji FinePix S3100 Digital Camera
Fuji S3100 Broken Battery Latch
Is there any way to replace the battery cap on my S3100 camera.  The tabs that lock it in the closed position have broken and the only way I can get the camera to power up is to tape the cap in the normal closed position.
There are two potential solutions that I know of, but only if the broken tabs are on the door and not the camera body. Double check which tabs are damaged.
The first involves getting a new door somewhere (good luck with that... Fuji doesn't seem to sell the parts to civilian consumers... you might try getting the part from an old non-functional one on ebay or something). The trick to removing the battery door is to push the door's hinge pin (with the door open) towards the back (LCD side) of the camera from the opposite (front) side. There is very little clearance. I have successfully used a paint can opener to do this on a S3100. You can brace the back side of the opener against the lip of the camera body and push the pin out. Once it is as far out as possible, use needle nose plier or tweezers to grip the now exposed end of the pin and pull it all the way out. Then put the new door in place and re-insert the pin... there may be a little resistance.
The other was recommended to me by a camera repair man, but I have not tried. I would probably have let him do the work, as it seems a little risky, but possible. It basically involves getting a small washer that will fit under the two latching tabs near one another on the body. After figuring out the correct position for the washer to be attached to the door that it will just slide under the tabs and secure the door, you must use a small countersunk screw through the central hole in the washer to attach it to the door. You might have to remove the rim of the door in that area with an exacto knife or something similar so the washer will fit well. Like I said, I would have probably let him do the work, but it sounds like it would work.
Another idea that just occurred to me is a little more work intensive but would probably work would be to sink a (coarse thread) screw through the door all the way into the plastic of the body (maybe 2 or 3 in different places), which could simply be unscrewed any time you wanted to change the batteries with relatively little trouble.
Good luck! =)
Posted on Feb 12, 2008
Where is the fuse located in a Fuji s3100 camera?
Sorry, did did not put in any fuse in this camera. When it does not start up, check the battery, if it still holds some charge and the contacts, both on the battery and in the camera. All contacts should be clean and shiny. Only clean with a dry cloth or cotton swabs. NO SHARP tools.
Jan 30, 2015 | Fuji FinePix S3100 Digital Camera
Powershot sx20 battery cap lock got broken now the cap will no longer close
Use electrical tape for holding the door or you need to visit service center for replacing the complete door.
Aug 07, 2012 | Canon PowerShot SX20 IS Digital Camera
Fuji finepix e510 won't turn on
If your Fuji e510 battery system is like the Finepix S3000 or the S3100 take a look at the following postings: Finepix S3100 (Camera power does not come on...) by banobo of Feb 07,2008 and check out solutions #2 & #4, (Mine is #4), Also see posting by "tomawamba for Fuji S3000" and my slightly differently worded solution.(Only one posted). May be best to get camera working before connecting with anything else. Good luck, be patient.
Jan 18, 2009 | Fuji FinePix E510 Digital Camera
Fujifilm S3100 won't power on
I'm not familiar w/ the S3100 but do you see any corrosion in the battery terminals? These camers don't usually just quit working. If the terminals are clean, what battery are you using? How many mA or milliAmpere rating? These are usually indicated on the rechargable battery's sides. There are some new battery in the market. The eveready silver colored battery. I forgot the name. It is one notch above the regular alkaline battery. Let me know if this helps.
Jul 20, 2008 | Fuji FinePix S3100 Digital Camera
Fuji S3100
I think problem is under the lid where batteries go a residue forms. like the same stuff that forms near your car battery terminals. ??
May 10, 2008 | Fuji FinePix S3100 Digital Camera
Fuji FinePix S3100 won't turn on
there is a option in the menu that turns the camera off after 2min. and then after that it is hard to get started.I took out the rechargable batteries and installed new duracell batteries,and it started and then I went to the menu and disabled the powersaver option.
Apr 16, 2008 | Fuji FinePix S3100 Digital Camera
Broken Battery Door
I would think a call to Fuji would be in order: 800-755-3854
They should be able to sell you a new battery cover
Mar 28, 2008 | Fuji FinePix F40fd Digital Camera
Fuji F650 won't turn on
Check the underside of the battery door. There should be an "L" shaped tab which presses on the shut-off switch. These are often broken off when closing the compartment. If it's broken off, you can defeat the switch by stuffing a piece of paper in it, and then closing the door (with battery installed). If the tab's not broken, you're probably in need of the service department.
Jan 22, 2008 | Fuji FinePix F650 Digital Camera
Fuji FinePix A400
Take the batteries out and clean the contacts
Those at the bottom of the battery compartment you can clean with the eraser at the end of a pencil
do the same with the lid.
Make sure the batteries are fresh/charged
When you close and lock the compartment lid squeeze it shut then turn on- it may be a contact problem.
If this fails then it will be a repair shop job
Dec 07, 2007 | Fuji FinePix S3100 Digital Camera
Fuji FinePix S3100 Digital Camera Logo
162 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
