Question about Compaq Armada 7770DMT Notebook
Non System Disk or Disk error Replace and strike any key when ready
How do I boot into the CMOS to change the boot order and boot to CD?
  • fperez007 Feb 08, 2008
    I never see the "Press F10 to enter system setup utility". It goes straight to "Non-system disk or disk error replace and strike any key when ready". Any ideas?
  • 108 Answers
While switching on your system press F10 and the go to the Advanced setup. There you select and press Enter key on change boot order and then change the order by using Page up or page down key. Alternatively you may use Esc key while showing the compaq logo on boot, you will be able to change the Boot Order.
Posted on Feb 08, 2008
    Brigadier General:
  • 6,966 Answers
At some time during the powering up process, there will be a display at the bottom that says"at the bottom it says "Press F10 to enter system setup utility". Pls do so to enter CMOS/BIOS configuration. Look for the Boot (Order) page. Once in the page, instructions how to change or move boot priority is usually at the bottom.
Good luck and kind regards.
  • Louie  Role
    Louie Role Feb 08, 2008
    Hi again,
    Pls try pressing F10 even without the message immediately after powering up before the expected "Non-system disk or disk error replace and strike any key when ready" shows up.
    Alternately, there is a possibility that the hard drive is no longer being detected by the laptop or some of its system files have been corrupted.
    Try popping in the CD anyway, might switch to booting from CD since it couldn't from the HD.
Is there a trick to getting a Toshiba laptop L775 to boot from CD ROM when BIOS password is missing? Have tried holding down c, esc. F2, F12, you name it.
reset the cmos settings to remove the password on the bios
https://www.youtube.com/watch?v=K4NqgDoyjNc
https://www.youtube.com/watch?v=siSoOXkNSgw
a software solution
https://www.youtube.com/watch?v=9UgLL3EHVzU
Worth a try
To change the boot order remove the hard drive and when it fails in the boot order I would think the laptop will try to boot the next device in the boot order hopefully set as CD rom
it could be f8 in so,me laptops
Mar 24, 2017 | Toshiba Computers & Internet
MY LAPTOP NX6120 IS SHOWING non-system disk or disk error replace and strike any key when ready WHAT CAN WE DO
If F8 does not give you any option to repair the system, set the bios to boot from the DVD rom and insert your Windows disc choosing repair when prompted.
Feb 12, 2015 | Computers & Internet
Optiplex gx620 2 beeps on start up, displaying 123.
If windows 7 you need to burn a repair disc & run it. Go to Maintenance, creat repair disc (use one CD & mark it with Dell gx62 on top, repair disc run first on bottom)
Restart your computer and hold down escape, F1 or F2 to get into the settings in the CMOS. You must chang the boot order of your startup. In CMOS use arrows to right to Boot to change to CD ROM then HDD so your CD will go into repair before starting the HDD. Each CMOS is different but usually you can use the f5 or f6 to change the order and f10 to exit & save the setting. Restart your computer after you put the repair disc in & that should repair your start up.
I’m happy to help further over the phone at https://www.6ya.com/expert/wynn_5ba0205233ebfc15
May 13, 2014 | Dell OptiPlex GX620 PC Desktop
Non system disk or disk error' 'replace and strike any key when ready' 'Media test failure Check cable' When l performed the Boot Utility test it returned an error message 'f
Sounds like a disk issue. It kind find the OS so it's then trying to PXE boot (boot from the network). Have you changed the boot order recently? or do you have a USB key connected to your server? are you able to connect to the management interface (hp ilo, dell drac) to see if you had any raid or other hardware issues?
Jan 09, 2013 | Computers & Internet
Cannot open my laptop... Did everything from removing the battery, cleaning the fan but still screen says non system disk or disk error replace n strike any key when ready.... Help pls
Please try the following:
1. Remove the non-system disk from your boot device. For example, remove the non-system disk from the CD-ROM drive. If there is no CD or remove the floppy disk from the floppy drive.
2. Change your computer's boot sequence. To do this, you must change your computer's setup and the option that controls which device your computer uses to start from. Make sure that you select a device that has boot files (or operating system files) installed. Normally, this would be your hard drive.
Oct 19, 2012 | Computers & Internet
Shuttle xp, ntldr is missing
replace the cmos battery, reboot the computer go into bios reset date and time and change boot order cdrom to boot first save changes. boot from windows xp cd do a repair. form command type sfc /scannow checks all system files.if any are bad should repair them.
Apr 17, 2017 | Computers & Internet
Diskette drive 0 seek failure appears after I changed my cmos battery
Changing the CMOS battery, while necessary, has reset your BIOS to the factory set up. Which means, from your description, that your PC is looking for the operating system on your CD or Floppy drive.
When booting, you should see, at the bottom of the screen, Press F2 for setup or F10 for boot options. They may be different F numbers, but the options should be the same.
Choosing "Setup" means that you'll be permanently changing the BIOS, "Boot Options" will be limited and temporary. You can choose the boot options, get you used to the idea of editing the BIOS, but you will need to update it if you don't want to go through this procedure every time you want access to your PC.
For my part, select the "Setup" option.
Look at the right hand side of the screen, it tells you how to edit the BIOS.
Tab across to "Boot Options" and from the list shown, arrow up/down to "boot device order" or an options with a similar wording.
You now have to set the boot device order, this tells you where your PC is to look for an operating system and there's usually about 4 options.
set to :-
1st boot device - CD drive.
2nd boot device - HDD 0
3rd boot device - external
after this really doesn't matter too much.
This means when booting your pc will look for a CD with operating system first, then your hard drive, finally an external boot system ie usb connected device.
Once your device order is set, hit exit or F10, you will be asked if you want to save the new setting to the BIOS, if you're happy hit Y if not N.
Once complete, your PC should boot normally.
You may want to go back to your BIOS and set up other options, just remember, on exit on select Y to save if you're absolutely sure you got it set correctly.
Nov 11, 2011 | Computers & Internet
I got a message that reads Non-System disc or disc error replace and strike any key when ready. What do I do?
Here the reason why youre getting the error message
Remove the non-system disk from your boot device. For example, remove the non-system disk from the floppy drive or the CD-ROM drive.
Change your computer's boot sequence in you Bios. Make sure that you select a device that has boot files (or operating system files) installed.
If you start your computer from a hard disk drive, install a bootable operating system (such as Windows XP, Vista or Windows 7) on the drive.
Thanks for using Fixya
Jan 24, 2011 | Compaq Evo N620c Notebook
Open Questions:
6 Ways Cloud Computing Helps Businesses Save Time and Money You must be using cloud computing now even if you do not realize it. For doing a simple task like sending an email, uploading a video online, downloading work related files it is nothing but cloud computing that is making it all possible behind the arena. Cloud computing is a big switch from the orthodox way businesses think about IT resources. Many Online Cloud Backup services advertise a lot of features, such as fast upload and download and unlimited backup, but often in real life usage these commitments fall short. As the old saying goes you get what you pay for stands true. For extremely basic file storage or sharing, you may look for a low cost, simpler product. However, if you are looking to get the best for your business, you'll need to consider better solutions like DataAlign. We all have masses of unstructured data scattered across laptops, desktops, and mobile devices and this is an ever-growing pain not only for a business but also for a home user. With time scarcity and insufficient security measures to protect these valuable data assets, we decided to create a competent Online Computer Data Backup Solutions that can not only assist you to organise your data, but secure it with military-grade encryption. Unlike other business online backup services that does not give optimum functionality, DataAlign provide application and operating system backup, 24-hour support, advanced file versioning, compliance-level security, server and NAS backup and infrastructure-as-a-service IaaS features. Of course, these offerings are simple to use and self-explanatory. With our ever growing and latest technology, Data Align Online Business Server Data Backup Solutions makes data backup, disaster recovery and business continuity uncomplicated and less extravagant as the is mirrored at multiple redundant sites on our network. DataAlign has been designed with you in mind. You wouldn't require any technical skill or IT degree to use it. Simply, upload your data and the technology will do the rest, enabling you to focus on what really matters; your business. Our dedicated support is readily available to answer any questions that you may have.
Jul 23, 2018 | Best Computers & Internet
See all Compaq Armada 7770DMT Notebook Questions
Compaq Armada 7770DMT Notebook Logo
566 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
