Multi Region code
Please can you help. I need a multi region code for my DVD Home Cinema unit. It is a LG HT902TB.
Thank you
Lori Dent
  • 5 more comments
  • Bookaddict Feb 08, 2008
    Please help I have had 3 replies to my problem but none of them worked. I need a multi region code for my DVD Home Cinema unit - it is a LG HT902TB.
    Thank you
    Bookaddict
    Thank you for trying but nothing worked.
    Bookaddict
    Thank you for trying but it did not work.
    Bookaddict
    Thank you for trying but none of these worked.
    Bookaddict
    Soory but I only tried the solution on the remote control. All that I got was a little hand in the right hand corner. As for doing the disc perhaps it would work but I'm such an idiot I don't know how to do this - sorry. Thank you for trying.
    Bookaddict
    Thank you for trying all that came up was a little hand in the right hand corner of the screen.
    Bookaddict
    I'm still trying to resolve this problem. Multi region code for a LG HT902TB. One of the experts said that there is not a code for this model and to buy another machine. Please don't let this be the case.
    Bookaddict
  • 2,326 Answers
Check this site below and follow all the instructions from it, even you may have to update the firmware on your system for the region free to work.
http://www.lgregionfree.mfbiz.com/#/instructions/4525089618
Good Luck.
Posted on Feb 08, 2008
    Genius:
  • 1,665 Answers
Hi! try this:
1. Turn on the dvd player.
2. Press eject
3. Type in 0000 on remote
4. A menu called region edit should appear.
5. Press 0 again for all regions.
6. Switch off dvd player and switch back on.
    President:
  • 1,944 Answers
All the free hacks for you player have been listed already (and they don't work) which means you might wanna pursue a paid solution. You can either get a chipped remote or a service disc to unlock your player. This site has one of the most comprehensive list of players I have ever seen and also relatively cheap. Just email them with your model and there is a good chance they will provide the solution.
http://www.dvdunlocks4u.com/
Regarding chipped remotes, I seem to have misplaced the address of the site. I will post it as soon as I find it.
  • Damen Wong
    Damen Wong Feb 08, 2008
    Also...you really should try what sweet_rascal posted. I will be happy to assist you through every step if you decide to attempt this.
    1) Download http://aiwaownersnetwork.tripod.com/page...
    2) Burn the folder 'RMTM0000' to a CD-R making sure that the directories stay in order. Use Nero Burning ROM or similar software, no multisession, finalize disk. DO NOT USE WINDOWS OR MAC OS INTERNAL CD BURNING UTILITY - IT WILL NOT WORK.
    3) Insert the disk to your player, disk will be ejected shortly and menu will appear.
    4) Select 0 for all regions and press PAUSE and then ENTER on remote to confirm.
    5) You have multiregion theater. Enjoy.
    Master:
    Sergeant:
  • 440 Answers
1st off they dont have it this model not muti region u need to go buy a muti region free dvd payer this not made for what u wann do ok thx nick
  • 407 Answers
To make your system multi-region, you need the handset hack code. Here it is
1. Turn Player on with no disc inside
2. Press pause on the remote control
3. Then key in 3 1 4 1 5 9 [CODE -- will then be displayed on the player display]
4. Key in desired Region number [0 for Auto Multi Region, or manually select 1 to 6]
5. Then Press Pause again
6. Turn off player and wait 5 seconds, then back on again.
best of luck..................
    Genius:
  • 3,422 Answers
HI,
Follow thsse steps and your problem will be solved:
2. Press eject
6. Press enter
7. It goes to another region code menu
8. Press 0 again and then enter
Goodluck,
Please don't forget to rate me as fixya..
  • 1 more comment
  • Priya darshan Feb 08, 2008
    These are 2 more if you need and they work 100%
    To Make your LG HT902TB Multi Region Please follow these steps.
    Option 1
    1. Open door tray
    - Press "Open" key on RCU
    or
    - Insert an alternate Region DVD disc
    2. Press "Zero (0)" key on Remote control 7 times (0-0-0-0-0-0-0)
    Option 2
    1. Press "Set Up" key on Remote Control
    2. Move cursor to "Lock" icon using down arrow on Remote Control
    3. Press "Zero(0)" key on Remote Control 7 times (0-0-0-0-0-0-0)
    Goodluck once again and please don't forget to rate me as fixya for my work..
    Your welcome the tricks which i gave works 100% so please do rate me as fixya for my efforts..
    If you have any other problems please ask me..
    I have already told you about this all my tricks which i gave you work 100%
  • 790 Answers
HELLO!!
2. Press eject
    Guru:
  • 1,894 Answers
Please wait sir
  • 8 more comments
  • dewan nafees ahmed Feb 08, 2008
    2. Press eject
    if this does not work
    NOTE: This file is not firmware modification, it is just an utility that changes region of your DVD player, so theoretically nothing bad can happen.
    else
    2. Press eject
    6. Press enter
    also i found a sure shot solution
    Option 1
    1. Open door tray
    or
    Option 2
    1. Download this File
    2. EXTRACT the files that are inside the .ZIP file
    3. Use your CD Creating Software to Create a CD (Nero, Toast etc..)
    4. Name the CD CODEFREE
    5. The CD must be laid out with the following Folder and File Structure
    RMTM0000
    SCARLET
    KPJC19_1.DVD
    6. Create the CD
    7. Insert the CD into the DVD Recorder
    8. Select "0" as Region Free
    9. RESTART the Player to complete the procedure
    did u try my last two comments?
    they have worked for many people around the world.
    so it must work for you surely.
    dont forget to rate fixya if it is solved
    i dont know what is wrong with your player..
    many many people around the world are able to use that code and work it out.. why is it not working for u??
    i would also like to somethng??
    did u try everything listed out here??
    how did you try all those so soon??
    try the comments with option 1 and option 2.. also the next comment to it.. they are the sure shot solutiions.. jsut three options. and you will get solved surely..
    rate solution as fixya if u accept it.
    that s great you found it.. happy to know..
    cheers..
    let me make you clear ur doubts..
    see the last post of this forum... link..
    then go to this link of the site which that user mentioned
    link..
    so dont worry.. it will work out.. please try with patiance
  • dewan nafees ahmed Feb 09, 2008
    am very much disappointed by the rating you gave me..
    i gave you all those solutins that have worked for many people around the world..
    how is that your alone are not getting it correct..?
    anyhow. have a second look at them..
    thank you..
  • dewan nafees ahmed Feb 16, 2008
    what is happening in this thread?? wil it be closed or not?
Is my mitsubishi dd 6030 a multi region player
Mitsubishi DD-6030 DVD Player Multi region hack ... - Fixya
www.fixya.com > ... > Mitsubishi > Mitsubishi DD-6030 DVD Player
Mitsubishi DD-6030 DVD Player, multi region hack related issues. Get free help ...Can you help? I need the multi region code for my Toshiba DVD SD370E. Ad.
Mitsubishi DD-6030 DVD Player Multi region hack code ...
Mitsubishi DD-6030 DVD Player, multi region hack code related issues. Get free help ... I need the multi region code for my Toshiba DVD SD370E. Ad. Question ...
Mitsubishi DD-6030 DVD Player Real free - Questions -Q&A
www.dqrkc.com/search/p153978-mitsubishi_dd_6030...player/real_free
I use them on all my disk players and they work real well. If you have any comments please feel free to leave them here. Hope this helps and thank you for using ...
Planet DVD Discussion Forum - planetdvd.net
www.planetdvd.net/discussion/wwwboard2.htm
Jan 20, 2016 | Mitsubishi DD-6030 DVD Player
Dvd codes lg
Hi Elizabeth. Not all DVD players are able to be made "multi region". The model numbers of DVD players that are multi region have the same model number as a "home" region player. There is no difference in the appearance of the unit. If it was sold to you by a retailer on the understanding that it could be made a multi region, then I suggest you call them ask ask for the code. Quite often, there is a procedure to follow when converting a DVD player to multi region - along the lines of - place the non region disk in the tray and press buttons X, X and X. I know this doesn't answer your question but I hope it gives you an explanation!
Aug 21, 2014 | Audio Players & Recorders
Region free code for LG BH7520
With your set on and without disc in the tray:
1. Press PLAY from your remote control
2. Press the following button sequence: 1590 2379 390
3. Press PLAY again
This will release the region verification in your home theater (region free). However, some DVDs (multiregion in particular) will not play, since they require region detection from the player unit.
Jun 10, 2012 | LG Televison & Video
Apparently they are locked to region 4 and I have bought region 1 DVDs so they won't play
In most models the unit cannot converted to multi-regions.So it will play only in the specified region in which it is applicable to.But in some unit models there is a procedure to turn the unit to multi region so it can play all region dvd.On all models the procedure to convert the unit to multi region is different.As you have not mentioned the exact model number of your unit.t will not be easy to give exact details.If in case there is a procedure to convert your unit to multi region.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Sep 14, 2010 | LG Audio Players & Recorders
Hi there, need help in setting for multi region code
Hella Bella,
Here is a Link you may find usefull.
www.dvd365.net
Click on 'CODES' at the top of there home page then click the LG option.
Have a look through and see if you can find your model number on there. If not try one that is close enough it may just help you out.
Hope this helps you out. If so then please leave a thumbs up
Cheers Little Dish Fitter.
Oct 17, 2009 | LG RC897T DVD Recorder/VCR Combo
Region code error for my LG RC388 DVD/VCR player & recorder
1) Power on player with no disc in tray
2) Press PAUSE
3) Key in 314159
5) For multi-region, select 0
6) Press PAUSE again
7) Power off player
8) Wait a minute turn it on.
Please rate our Free help to keep the service online ++++
Aug 30, 2009 | Televison & Video
I need to change my DVD players Region code to play all regions.
1.Switch on unit 2.Press- Setup on the remote
3.Select the Lock option from the on screen setup menu
4.Press Lock on the remote unit ( under slide cover)
5.Press 0 7 times on the remote keypad
6.A message appears stating the unit is now Code free on the screen
7.Press Enter on the remote.
8.Close Setup menu and switch unit off.
9.Switch on and enjoy Multi-region DVD playing
please donot forget to rate this solution.
Thanks for using FixYa.
Jan 28, 2009 | LG RC199H DVD Recorder/VCR
How can i unlock my samsung home cinema to multi region dvd so that it can play any dvd,vcd e.t.c
dvd region free codes site
http://www.dvdhacks.co.uk/
check out the link bychance it helps you.as many region codes r listed in it.
Dec 15, 2008 | Televison & Video
Is it multi region already?
not u would have to set the code to 0 all sum do sum dont usally need a unversal region free player out of box to do it
Feb 03, 2008 | Sony DVP-NS305 DVD Player
701 people viewed this question
 Grubhead
Grubhead
