Question about Logitech X-540 Computer Speakers
X-540 Speakers I had a Boston Acoustics BA7800 5 -piece speaker system. I have a Gateway 700xl system with a Soundblaster Audigy Audio sound card. I purchased a Logitech X-540 speaker system, installed it following instructions, I can't get any sound out of the speakers. What am I doing wrong. The cables are color coded,I hooked them up to the colors on the PC.Can someone help. !!!! Thanks- Rudy
  • Anonymous Jun 17, 2008
    no sound form the front speakers
  • 46 Answers
Go into sound device on control panel. make sure digital is unchecked.
Posted on Feb 14, 2008
I have Boston Acoustics BA7500G surround speakers that will not work with Win7 64bit. I have used them since owning a Gateway PC (Win XP) with a Soundblaster card. I've used them through three...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
Realtek HD audio driver package. The package includes: driver setup program, drivers for Windows Vista / 7 64-bit
hope this helps
Jun 11, 2011 | Boston Acoustics BA7500 Computer Speakers
Can i use my boston 5.1 speakers with a powered sub with my new computer used soundblaster software?
The speakers themselves don't care what you have them connected to. They just take an audio input from the computer, which is a function of the computer's sound card and drivers. As long as the computer hardware is working properly, the speakers will too.
There is one possible problem, though. If these speakers came with your computer as part of a Gateway system package several years ago, they may be a digital-input version only. Gateway supplied these speakers and a Creative Soundblaster card that had a digital output was installed in the computer. The way to tell on your speakers is to look at the plug on the end of the cable. Which of the two below looks like yours?
If it's the one on the left, you can use the speakers with any analog sound source (computer, iPod, etc.). But if looks like the one on the right (a mono plug), you have the digital speakers. Unless the sound card in your new computer has digital output available, the speakers won't work. In the past, I was able to put the original sound card and drivers into someone's new computer and it worked, but the original software is not compatible with Vista or Windows 7.
Hope this helps you get it figured out. Thanks for using Fixya!
Dec 02, 2010 | Boston Acoustics BA7500 Computer Speakers
How can i get the boston digital ba735 to work on my computer?
if now your computer not support this speakers,you must buy new soundcard support this speaker then build in to your computer hardware.good luck
Apr 28, 2010 | Boston Acoustics BA735 Computer Speakers
No sound from rear speakers Boston Acoustics BA 7800
check whether the wire is connected properly on both the ends
Aug 08, 2009 | Boston Acoustics (BA7800) Computer...
Trouble with rear speakers
This may be a software issue. If you only had two speakers before, the software will not use the rear speakers.
Go to Control Panel. Click on "Sound and Audio Devices". Under the Volume Tab, at the bottom, you will see a picture roughly representing the type of speakers.
Click on the Advanced button.
Click on the arrow in the pick box, and choose Surround Speakrs or the 5.1 Speakers.
Click Okay. Try the speakers again.
Apr 06, 2009 | Boston Acoustics (BA7800) Computer...
Gateway Computer Speakers are crackling/popping
yes it could be going out on you, if you have empty slot on mainboard or another computer you can try it on,then you can confirm if it is broke or not. hope this helps, glen
Nov 26, 2008 | Gateway /Creative SoundBlaster Sound Card
No sound. Sound card or speaker failure??
These speakers only accept digital input in form of 3.5mm mini-din digital out from your source.
Nov 09, 2017 | Boston Acoustics BA735 Computer Speakers
Boston Acoustics Computer Speakers no sound
This speaker system requires a digital audio input, which most older systems don't have. The sound card that was built into your Gateway can put out either a digital or analog signal depending on how you have it set. Chances are your new sound card might be able to output in digital mode as well, but you may have to turn it on manually. Try double-clicking your volume icon in your system tray, then click the "advanced" button at the bottom left. This should bring up a window that lets you adjust the treble and bass, but it should also give you an "other options" area that lets you turn on digital output. If your new card supports digital output, the option should be there. If the card does not support it, you will have to use a different card. I hope this helps.
Oct 25, 2006 | Boston Acoustics BA7500 Computer Speakers
Logitech X-540 Computer Speakers Logo
198 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
