Question about Ovens
No fire below
Got gas on top and burners ignite but no gas no heat on bottom, could this be the ignitor? if so can you give me a step by step to fix problem? thanx
    Scholar:
  • 163 Answers
If Its a ceramic ignitor you can check with DVM for low resistance but I'd say thats the trouble. (Not with power applied)..Generally need to pull the bottom tray out of the oven to access as its Close to the Gas tube at the rear on most. Simple 2 wire hookup.. Manufacturer site should have a Breakdown if the paperwork isnt in the back panel.
Posted on Feb 08, 2008
Frigidaire gas oven not heating. The broiler and burners work but the lower burner will not ignite. I replaced the igniter however that did not fix the problem. In fact, the new igniter does not glow. I...
Check for volts to the new ignitor. The ignitor draws current which opens the gas valve. If it is not glowing it is not drawing power. Test the ignitor,disconnected, with an ohm meter, it should be under 200 ohms.
Dec 28, 2013 | Ovens
Have a maytag genesis double oven. bottom oven will not fire up. checked igniter that works but gas will not come on. top oven works fine
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Feb 26, 2011 | Ovens
Oven "bake" burner wont ignite on a gas oven.
Oven not Working or Oven not Heating
heatman101
Dec 27, 2010 | Whirlpool Ovens
MY GAS OVEN WILL NOT HEAT AT THE BOTTOM,NO GAS SEEN TO BE COMING THROUGH THE LINE . BUT BURNERS WORK`S FINE.
heatman101
Nov 03, 2010 | GE Ovens
Ignitor lights up bright, but no ignition,no flame and I don't hear the gas turn on like I normally do. Top burners work fine.
Hello, welcome to fixya ! Based on your description I suspect you have a faulty bake ignitor. This may surprise you, or it may not. I think at first it surprises people when the hot surface ignitor glows but the oven won't lite. Since the ignitor "glows" one figures it would appear to be working, that would be wrong. These ignitor's serve 2 functions, 1) need to maintain a set value to open/activate the gas valve, typically around 3.5amps... & 2) ignite the fuel once said gas valve is open. A poor/faulty ignitor may glow & and even ignite the burner intermittently for moments at a time ( thus giving off some heat but never the set amount or not lite at all ) but yet not reach the needed value to open the gas valve/safety valve consistently nor adequately, hence the need to replace the ignitor. Try this and I'm certain you'll be up & running and as they say " cookin' with gas" ! I'd suggest you should refer to your specific model when ordering the part locally or on-line. The most common hot surface ignitor part is #12400035 and it will work in your Whirlpool too. Try places like repairclinic.com, searspartsdirect.com, APwagner.com etc. Thank's for visiting "fixya" for your stove inquiries. Please take a moment while here to rate the solution provided or let me know if you require further assistance and good luck. macmarkus :)
May 23, 2010 | Whirlpool AKZ159IX Oven
I replaced what I thought was a bad igniter.But still had no glow from new igniter. Must be something else.Where do I go from here?
Hello there: The oven bake burner and ignition components are located beneath the oven cavity. In most cases the oven bottom panel can be removed for access (check your owner's manual) but on some models the oven burner has to be accessed from below in the warming or broiler drawer area. If accessing from the top, a 'flame spreader' (flat metal plate) above the burner may also need to be removed to see the burner itself.Many ovens use a single oven burner in which case they only have a single gas valve and ignitor. The same burner is used for both bake and broil functions, the broil usually being in the drawer area below the oven. Higher-end models may have a separate bake and broil burner. On such a system there will be two ignitors, one for each burner. They may also employ a 'dual' gas valve (see illustration above) instead of using a separate valve for each burner.Some range models may have an additional broil burner located at the top of the oven cavity which may be referred to as a 'waist high' broil. If not, broiling usually takes place in the drawer area below the oven, which uses the same bake burner for the broil function. Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system.
Making Observations
The oven burner's operation will usually need to be directly observed while in operation as the first step to troubleshooting problems.Ignition System Type Links
Ignition System Types:
  • Pilot Ignition
  • Electronic Ignition with Constant Pilot (rare)
  • Electronic Ignition with Glow Ignitor (most common)
  • Spark Ignition System
  • Is there continuity between the oven gas valve's terminals?
    Hot Surface ('Glow Bar') Ignition System (most common)
    This is the most popular system currently used for ovens and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve.
    What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame.
    It should usually only take in the area of 30-90 seconds for the oven ignitor to reach the proper resistance to allow the proper amperage to reach the gas valve to open it and for the ignitor to ignite the gas at the oven burner.
    Dec 30, 2009 | GE Ovens
    The oven burner will not ignite.
    Because the glowbar is glowing does not necessarily make it good.
    Turn off the gas to the stove. Remove the oven racks. Remove the bottom oven pan. Remove the flame spreader. This gives you access to the glow bar and gas valve.
    Put a clamp on amp meter around one wire of the glowbar. Turn the oven control on to BAKE.
    If the glowbar reads 3 amps or less,replace the glowbar ignitor.
    If the glowbar reads good,check the burner tube for a white ash buildup. It can be cleaned with a wire brush. Look closely near the glowbar section of the burner.
    Check all the wire connections for the gas valve.
    If the glowbar is good and the ash deposits are gone and the oven still will not ignite,the next step is to replace the gas safety valve.
    Dec 01, 2009 | Amana Ovens
    Gas oven not working. burners work. not
    The holes may be plugged with residue. With the oven off! Try taking a paper clip and unplugging the whole. Make sure the ignitor next to the burner tube is secured and is not broken. These are under the bottom oven plate. Most models.
    Sep 04, 2009 | Maytag Ovens
    KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
    Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
    Apr 25, 2009 | Ovens
    Jenn-Air part RI302 4 pt gas re-igniter with flame rectification tytronics #Z21-20 and 7431 PO38-60
    We had the same problem on a Thermador cooktop with the same RI-302 ignitor. Turns out it was one of the switches that sits on top of the gas valves. These switches cause the ignotor to fire when the valve is turned. In our case, one of the switches had malfunctioned and was "always on" causing the ignitor to continuously fire.
    Oct 29, 2007 | Jenn-Air JJW8530C Expressions Collection...
    Ovens Logo
    42 people viewed this question
    Top Ovens Experts
    Marvin
    Marvin
    Sal De
    Craig Butler
    Craig Butler
    Are you an Oven Expert? Answer questions, earn points and help others
