Question about Disney DT1350-P 13" TV
Parental controls I don't know the password for my parental controls, how do I reset it so it won't be a problem? I am locked out of tv shows that I try to watch.
  • loulaabell Feb 29, 2008
    I have had this tv since i was 13 i am currently 20 and the password that was set was forotten how do i unblock the v-chip so that i can watch my normal shows in my room?
  • Anonymous Mar 13, 2009
    get only channels 3 and 4 do not have remote or manual
It says in the owners guide to press the volume button on the main unit and o on the remote simultaneusly. I have tried it and it's not working for me but maybe you will have some luck.
Posted on Nov 15, 2008
My akai tv is locked,don't know the code
Most TVs have a parental control lock that can be set to prevent children from watching specific television shows. In order to activate or deactivate the controls, you need to know the four digit security code or parental lock control password. If you forget the number you chose or if the lock gets set accidentally, it is still possible to unlock the TV.
Instructions
Turn on the TV and grab the remote. In most cases, you will need the original remote to unlock the TV if you aren't sure of the unlock code. If you don't have the original remote, you will need to purchase one.
Look at the screen. If you see a blank screen with a red key on the bottom of the screen, press 'Function' and 'Mute' at the same time. This should unlock the channel. This is an option for people who want the TV to stay locked but, want to be able to bypass the lock to watch a certain show or channel. All other channels will remain locked and the TV will fully lock when it is turned off.
Unlock all of the channels on the TV by entering the factory reset code. There are three main reset codes that TV manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will reset the TV to original factory settings. When you do this, you will loose any information that you have stored in the TV, such as favorite channels, automatic timers and the clock. You will have to go through the full initial set up.
Call the technical support service number in your owner's manual if none of those codes work. A technician can help you troubleshoot the television because the problem may not be the locking control. When you call, make sure that you have the model number and serial number of the TV.
Take your television to a TV repair shop. In some cases, a professional who access to wiring diagrams for your television set may have to rewire certain components in order for the television to unlock. This is usually the case when the TV locks by itself while it is on.
Sep 13, 2012 | Jensen Q2749J 27" TV
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Jun 28, 2008 | Sansui DTV2760 27" TV
Television question
That means The child lock has been activated.
I'll let you know if there is any solution for that.
Apr 09, 2008 | Haier HTF27R11 27" TV
Hi i have a samsung tv n im with bell but i forgot my password for parental control... help??!!
The child lock on a TV can be a wonderful thing. A parent sometimes cannot be present for the duration of a kids' show, so the child lock ensures they can't watch programs that are off limits. The lock can, however, cause unwanted trouble--if it gets accidentally turned on and you don't know the code, you can find yourself unable to fully enjoy the full range of available television stations. Follow a few easy steps you'll be back to watching regular TV in no time. Instructions Locate the manual for your television. Though slightly embarrassing, accidentally turning on the child lock to a TV is a common problem. The section In the manual about how to set the child lock feature will also explain how to unlock it. Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A common code is "0000." Unplug your television for a few minutes. The internal battery of the TV is what helps remember what your code. If the TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code.
Aug 31, 2012 | Samsung UA60D6600 60in. LED TV
I need to know what do if my jensen tv screen goes blue and a red lock has appaired in the top right corner
With my APEX Television, this means that the parental settings have been changed so that the TV will not let me watch certain Television show or movie ratings. Just go into the Tv's menu and look for parental controls. This should require a password to change. I would either suggest passwords 0000 or 1234
(My parental settings were my father's birthday year, so try something like that)
Jun 20, 2011 | Jensen Q2749J 27" TV
I have a 32" Dynex
Need the model number to look up the parental control steps. you will need to access the control settings in the Menu, the channels option. the TV will prompt you for a password, if you don't know it, there is always a default you can use listed in the manual. You can turn off Parental controls in here.
May 11, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
Parental lock
Child Lock
Combos
OR TRY THIS..
CTC169AU
CTC185's
CTC203's
TX808 Chassis
Mar 26, 2008 | RCA TruFlat 27F520T 27" TV
I dont know the parental code and my color is messed up how do i fix it.
OR TRY THIS..
Bill
Jan 30, 2008 | RCA TruFlat 27F520T 27" TV
Bought a TV and has a password i want to remove
When there is a parental code, you have to ring up your tv service provider for the code.
Sep 12, 2007 | Televison & Video
Disney DT1350-P 13" TV Logo
145 people viewed this question
Top Disney Televison & Video Experts
Jaime Hernandez
Demonic-2011
Demonic-2011
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
