Question about Nintendo Wii Console
Cracked main (number one) remote
The remote labeled 1 is broken and I cannot control anything. Is there a way to make one of the other 3 remotes become the number one and just buy a new one. I just got this for Christmas. Thanks.
  • 51 Answers
Yes there is.
while the wii is off, reset the controlers
then turn the 1st wii mote on and vouila
Fixed
hope this helps
Maxicube
Posted on Feb 10, 2008
How to remove code set 3 for the remote control panasonic bd-45
It seems the best way to "remove code set" is to overwrite it with a different code set.
(From the Owner's manual for the Panasonic DMP-BD45)
STEP 6 :
Reprogramming the remote control
Change "Remote Control Code" (-> 28) on the main unit and
the remote control (the two must match) if you place other
Panasonic products close together and it responds to this
remote control.
You can operate the TV or amplifier/receiver using the unit's
remote control.
1 For televisions
Input the code (-> 37) with the numbered
buttons while pressing [? TV POWER].
For amplifiers/receivers
Input the code (->37) with the numbered
[RECEIVER j VOL].
e.g., 0001: [0] -> [0] ->[0] -> [1]
2 Test by turning on the television or
adjusting the volume of the amplifier/
receiver.
Feb 20, 2016 | Panasonic Televison & Video
I have a Vizio Model XVT3D554SV TV that uses a bluetooth technology remote. I have been unable to get the MX 500 to learn from the TV remote and cannot find the code for the TV. I would like to use the MX...
2. Auto Scan With Three-Digit Number
You can also program your remote control by sending out a
series of Power Off commands for different brands stored
in the library by using the following steps. This is similar
to the first method, except it is easier to move through all
of the device codes for your device and make note of each
one that turns your device OFF.
1. Manually turn on the device you plan to operate.
2. Go to the SETUP mode by pressing both the MAIN and
ENT buttons simultaneously for three seconds.
3. Press the P-PRO button next to the LCD screen.
16
17
4. Programming the MX-500TMto Control Your Components
4. The remote will be flashing "SELECT BUTTON".
Press the device you wish to program. (For example, to
program TV, press the TV button.)
5. The remote will be flashing "FROM TABLE". Select the
device from which the scanned code will be selected.
(Important: If you have already relabeled your device
keys, your LCD screen will not look like the illustration
above. Select the appropriate LCD button for the "FROM
TABLE" using the labels as shown in the illustration on
page 11 of this manual. For example, if you have relabeled
AUX as LIGHTS, you would still push the bottom-left
button to access the AUX Code Table.
6. Point the remote control toward the component and
alternately press the UP (or DOWN ) button on the LCD
and the Power button. If the right code number is sent, the
component will turn off right after the code number is
transmitted.
(Please press the UP (or DOWN ) button within 20 seconds
of beginning programming, otherwise the remote will
revert to the SETUP menu, and then after a period of time,
it will go back to the MAIN device page.)
18
7. Confirm that it is the right code by pressing the Power
button. After you have confirmed that the right code is
entered, save the code by pressing the SAVE button on the
LCD.
8. Confirm that you entered the right code number that
matches your component by pressing other functional
buttons. If any of the buttons do not operate, as they
should, please repeat from Step 1.
9. Continue to program other components by repeating
from step 1 above.
10. You can press EXIT at any time if you do not wish to
proceed.
11. Exit from Preprogrammed mode by pressing the MAIN
button and then exit from the SETUP mode by pressing the
MAIN button once again.
Sep 14, 2011 | Universal Remote Control MX-500 LCD Remote...
Do i need to program my remote to change channels on the dish network
Hey knapshak, Tommy Faust with DISH Network here. It would need to be programmed to the receiver in order to change programming. You can do that by following the steps below.
1. Access System Information screen from your main TV.
2. Note the number on the bottom of screen next to Remote Address.
3. Hold SAT until all buttons on top light up then release.
4. While SAT is blinking enter a number between 1-15 and press # (Different from number listed)
5. Press record 3 times and the number should change, try the remote and see if you can change channels.
You can also check out this link for more information:
http://www.dishnetwork.com/SupportSection/remote-setup
Tommy Faust
DISH Network
Mar 19, 2011 | DISH Network IR Remote Control
I GET SET 1 EVERYTIME I PRESS BUTTON ON CONTROLLER
Set remote to 1 by pressing 1 holding Ok/Enter for 3-5 seconds.
Jan 30, 2011 | Panasonic DMPBD45 BluRay Player
I replace the tv to the bed room 2 remote and it doesnt work I cant watch cable and the remote is responding to the tv
Hey brandonericm, sounds like the remote may need to be readdressed to the receiver. I can definitely help with that. Here are some steps to help you:
1. Access System Information from main TV.
2. Note the number on the bottom by Primary/Secondary Remote Address.
3. Hold SAT on TV2 remote until all lights on top come on.
4. Let go and while SAT is blinking enter a number between 1-15 and press #.
5. Press record 3 times and the number should change to the one you chose.
Tommy Faust
DISH Network
Sep 08, 2010 | DISH Network IR Remote Control
Remote lights up as if it is going to work however it won't do anything batteries are new, so that is not an issue almost seems like it needs to be re programmed or something my 2 year old could have...
Without knowing the exact issue I can only provide general information. Since it seems like it may be a satellite address problem, I can definitely help with readdressing the remote.
To program remote to Receiver:
1. Access System Information from main receiver.
2. Note the number on the bottom by Primary Remote Address/Secondary Remote Address.
3. Hold SAT until all lights turn on on top of the remote.
4. Enter a number between 1-15 and press #.
5. Press record 3 times after it finishes blinking and the number by remote address should change.
Tommy Faust
DISH Network
Aug 31, 2010 | DISH Network IR Remote Control
WHERE DO I FIND THE MODEL NUMBER ON MEDION TV
Tips for identifying Manufacturer:
When adding devices to your Harmony account, it is important to correctly identify your components so that your Harmony Remote can control them as efficiently as possible. Below are some tips to help with figuring out how to add your devices correctly:
Tips for identifying the Device Type for your devices:
A general category description:
Examples: Television, VCR, CD Player, DVD Player, Stereo Receiver, Amplifier, Game Console, etc.
1. Also referred to as “make” or “brand name”
2. Typically on the front of the component
3. Sometimes on the label with the Model Number
examples: Sony®, Phillips®, Denon®, DirecTV®, TiVo®, etc.
Tips for identifying Model Number:
Note: also “Model” or “M/N”
1. usually on a label on the front, back or bottom of the component
2. the model number may be different than model name
3. also found in the component’s user manual
4. Not the model number on the old remote control
5. Not the serial number (SN) which is usually much longer
examples: RC-QN3BK, CT-36XF36C, Explorer 3100, L32 HDTV 10A, etc.
Jan 25, 2010 | Televison & Video
V chip password
Parental Guide On (Activate V-Chip)
Selecting this option lets you activate and deactivate parental control settings.
1. Press MENU on the remote control (the Main menu appears).
2. Press the button until the Parental Control icon is highlighted.
3. Press the button until the bottom PASSWORD is highlighted.
4. Enter your password using the numbers buttons on the remote (the PARENTAL GUIDE menu appears).
5. Press the button to highlight PARENTAL GUIDE OFF, then press the button to turn it on. It must be
on for rating limits to take effect.
If you do not activate V-Chip, none of the settings for V-Chip will take effect.
If you forget your password, you can reset it. Enter 5898 as the password and then change it to a new one.
Child Lock
Selecting this option lets you lock (disable) or unlock (enable) the TV’s front panel. The remote still tunes to
any channel. When using this as a Parental Control method, remove access to any remote that is capable of
operating the television.
5. Press the button to highlight CHILD LOCK, then press the button to turn it on.
Change Password
Selecting this option lets you simply create a new password at any time. Once you enter a new password
from CHANGE PASSWORD in the PARENTAL CONTROL menu, it is the password you use until you change it
again.
5. Press the button to highlight CHANGE PASSWORD, then press the button to select it.
6. Press the button to highlight NEW PASSWORD, and use the number buttons on the remote to enter
the new password. Enter it again in the confirm field to confirm the new password.
Mar 20, 2008 | RCA 20F510TD 20 in. TV/DVD Combo
Remote malfunction - panasonic dvd stereo system
The remote control and main unit are factory-set to “REMOTE 1”
mode.
If your remote control affects other equipment during operation, you
can switch to operate in “REMOTE 2” mode.
To switch to “REMOTE 2” mode
1 While pressing and holding [AUX] on the main unit
Press and hold [2] until “REMOTE 2” appears on the
main unit display.
2 Press and hold [ENTER] and [2] for at least 2
seconds.
The main unit and remote control are now set to operate in
“REMOTE 2” mode.
To return to “REMOTE 1” mode
Do steps 1 and 2 above but use [1] instead of [2] for both steps.
(“REMOTE 1” appears on the main unit during step 1.)
The remote control cannot work with the main unit if their
modes are different.
“REMOTE 1” or “REMOTE 2” appears on the main unit display when
you operate the remote control.
If “REMOTE 1” appears (The main unit is in “REMOTE 1” mode.)
Press and hold [ENTER] and [1] on the remote control for at least
2 seconds.
If “REMOTE 2” appears (The main unit is in “REMOTE 2” mode.)
Press and hold [ENTER] and [2] on the remote control for at least
2 seconds.
Feb 21, 2008 | Audio Players & Recorders
Cable ez 2.4ghz wireless catv sender
I have a Cable EZ remote with the instructions o the back. See if this will help you (I wrote it below exactly as written on the remote):
Remote Control Description
How to set up the remote controller:
For first time to set RF controller ID Code
1. Press [SET] + [FUNCTION] together
2. Key in your personal code (3 digits 000-253)
3. Press [SET] again to finish
For CATV sender learning the remote controller ID
1. Plug the adapter into the CATV SENDER and wall outlet and the sender will power on automatically
2. Press [SET] + [POWER] in 10 seconds to set CATV SENDER ID code. It will show your personal code on the screen.
The remote has a label with the model number AWV351RC and an FCC ID of NGVAWV35XRC. Made in Taiwan.
Hope this helps. I am missing the operating manual that came with the unit, so if anyone has a copy you can scan and post, it would be appreciated.
Feb 08, 2008 | Televison & Video
Nintendo Wii Console Logo
23 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
