Question about Hitachi 51F510 51" Rear Projection HDTV-Ready Television
How to hook up surround sound
I just bought a surround sound unit and when i tried to hook it up it didn't work. I hooked up plenty in the past and always have hooked them up the same way. I just go from the audio out on the back of tv to the audio in reciever.. There is only one uotput on the back of this tv and that is what i used, but got no sound. am i doing something wrong?????
  • 2,326 Answers
Check in the TV audio menu adjustments to activate the audio going out to the external speakers.
Hope it works.
Posted on Feb 08, 2008
Hi, I just bought a blu ray home theatre system and hooked it up, the surround sound sounds great but it only works when my watching a movie with the blu ray player... I hooked the blu ray player to my tv...
If you want everything to have surroud sound, it all has to run through your system and you select which function to use. Yes it sounds like improper connections.
Sep 03, 2011 | RCA Audio Players & Recorders
Unable to listen to tv through the surround system
Your BEST TV-related audio would be brought in directly from each external source you watch, NOT the TV itself (if TV's were hi-fi we wouldn't need audip equipment), so, yes, digital audio is the ONLY way to go. Having plenty of connections on the TV is NOT going to give you HI-FI multichannel audio from all of them.
Jul 08, 2010 | Panasonic SCBT230 Theater System
PlasmaSync 42MP3 42 in. Television: i bought a anec hooked up speakers i cant get audi...
I dont' have the fix but I do have a work around. You can hook your source directly up to a surround sound unit if you have one using red and white audio cables to the aux input on the surround sound system.
May 07, 2010 | NEC PlasmaSync 42MP3 42 in. Television
I bought the sony bdv e500w surround sound and hooked up a optical audio to my tv and that is a sony bravia but it will not work with the surround sound when i hook it up using regular audio cords it works...
im having the same problem, except im connected via audio components and hdmi...cant get sound through the speakers when the TV is on, it doesnt make any sense.
Feb 14, 2010 | Sony Audio Players & Recorders
No surround sound on normal tv just dvds
Do you have a cable box or satellite box? If you do, try hooking up your TV sound through the box. Look for audio out in the back of box (white/red RCA Jacks). Hook RCA cable from cable box to surround amp. Even if the audio out jacks are being used already, you can use Y connectors to hook up the surround amp to the box.
Hope this works for you!
Jul 23, 2009 | RCA Audio Players & Recorders
No surround sound like the movies
HOOK IT UP FROM A DVD PLAYER OR BLU RAY,,, WITH EITHER COMPONENT OR A OPTICAL CABLE ,,MAKE SURE YOU HAVE ALL OF IT TURNED ON ON THE RECIER SETUP
May 14, 2009 | Pioneer SX-315
Hooking up surround sound
do you need a reciever to get ceiling mounted speakers to work surround sound
Jul 11, 2008 | Audio Players & Recorders
Hooking up video
I am assuming that you are using a surround sound system?If so on the back of the satellite receiver you will have RCA cables labled yellow ,red,white uuse an rca cable to run from the output on the back of the sat box to an rca input on the surround sound unit.the inputs should be labled on the back of the surround sound unit.once you have the sat box plugged in look for the output on the surround sound (rca cables) run one set of rca cables to the rca cable input of the Tv.on the original tv remote select the tv input that is the cable from the surround sound is plugged in to . make sure the surround sound unit input is selected to the input that the sat box is plugged into.this will give you surround sound from your satellite receiver,repeat with your DVD player plugging the DVD rca cable output to another empty input on the surround sound.to switch between the sat box (satellite TV) to DvD select another input on the surround sound unit.Try to correspond the units you are plugging into the surround sound to the correct name of the component on the back of the surround sound unit to avoid confussion.any questions,Im here to help.If this works rate me FIXYA! if it helps.GOOD LUCK!
Nov 18, 2007 | Panasonic SC-HT40 System
Hitachi 51F510 51" Rear Projection HDTV-Ready Television Logo
195 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
