Bingo machine series 111 multi
Hi
I have recently inherited a series 111 multi random number selector, it has been working fine, but now only stays on with all numbers lit. I cannot get it to work in normal mode, can you please help, or suggest where I can obtain an instruction manual.
Thanks Paul
  • backtraxs Feb 09, 2008
    It is a mains powered bingo machine
Did you get a cct digram or get yours fixed?
Posted on Aug 06, 2011
    Problem Solver:
  • 13 Answers
Take batteries out
Posted on Feb 08, 2008
Hello, I have a Maytag legacy series washing machine and recently it stopped working properly, first it tripped the breaker, then in regular washing mode it washes normally but skips spinning and water...
Sounds like a bad relay array, or timer module. The little motor that makes the selector move (and then trip the function switches inside the timer module) could have trouble moving the selector past a certain point. When the machine stops, press your ear up against the timer module. Do you hear the little timer motor running? Yes? then it's probably the timer module itself, not the timer motor. I say this because you can manually move the selector to activate the modes.
Jan 03, 2014 | Maytag Legacy Series Top Load Washer
I recently inherited a Necchi sewing machine. The #U129951 is on it. I would like to get a manual for it. Linda
Hi. Without knowing the model number, it's difficult to say what manual you need (U129951 is the serial number, not the model number). But all is not lost--go to http://www.tias.com/stores/relics/ and click on "Machines name begins with Necchi", then scroll down until you find the picture of your machine.
Good luck,
Robbie
Aug 10, 2010 | Necchi Sewing Machines
Whirlpool type 111 model LSQ9200LQ3 washer not
I have a whirpool model:lsq9200lq3, and recently it has stopped working. when ever you turn it on, its fine and the water fills up normally and right before it gets to the spinning cycle the machine makes a grinding noise like if something is stopping the motor from spinning, and it dosent spin inside the washer. if anybody has any suggestion It would be great thank you.
Jan 30, 2010 | Whirlpool Washing Machines
Falcon au 111 auto fort coolant light flashing, speedo going up and down at constant speed, km indicator rapidly 'flashing, drives ok idles good, coolant level ok (no sensor ) help please
Problem solved
Pulled out instrument cluster, un pluged, connected back and reinstalled. Bingo! everything works fine. Faulty connection maybee???
Oct 21, 2009 | Ford Fairmont Cars & Trucks
Need an FF! X3 portafilter - anyone have one?
If you want to make espresso with loose coffee (as opposed to pods), You will need both a portafilter plus the special tamper. Believe it or not, the tamper comes apart and part of it stays in the portafilter! Sounds strange I know, but it works well. The tamper is bakelite with a metal screen. You will probably have to call Empire Fulfillement 877.854.4141 or ffservice@illyusa.net
Sep 03, 2009 | FrancisFrancis! X1 - Stainless Steel...
Hi. I Recently inherited a Zebra 140 XiII(2) and I cannot set the print speed as the option doesn't show on the LCD menu or when I print out the printer config settings. Any help would be appreciated.
Print speeds on the Zebra xiII series printers are set via software. There is no printer menu speed setting on the xiII series. Zebra didn't allow speed adjusts thru the front panel menu until they made the xiIII series printers... The ZPL code command for print speed is "^PR"
Jul 16, 2009 | Zebra 140Xi II Thermal Printer
Kenmore Washer won't Agitate
gearbox internal fault, major repair, not really a do it yourself job.
Dec 25, 2007 | Washing Machines
235 people viewed this question
jasbo
jasbo
