Question about Xerox WorkCentre XD100 All-In-One Laser Printer
Xerox XD 130 L4 code
Can you tell me what the code L4 stands for? Thanks
  • parttimetech Mar 19, 2008
    My XL2140DF, has the same problem with the motor drive plastic gear being split. Did you find a new gear to replace it? If so, please let me know where. Thanks.
  • wahab2008 Apr 04, 2008
    code error j2
    President:
  • 2,072 Answers
That is an issue with the main drive motor.
There is a small plastic gear on the shaft of that motor that cracks and even though the motor spins, it does not drive anything.
Often you have a whirring sound when you power on the machine.
L4:The Main PWB sensed a Main Drive Motor MOT1 problem.
Posted on Feb 11, 2008
Card not initialized?
The error can be caused by:
1. The xD-Picture Card or internal memory is not formatted.
2. The xD-Picture Card contact area is soiled.
3. a camera fault
for 1.:
Format the xD-Picture Card or internal memory on the camera (p.130)
To format the internal memory or xD card goto format in the setup menu and chose the correct memory.
for 2.:
Wipe the contact area on the xD-Picture Card with a soft, dry cloth. It may be necessary to format the xD-Picture Card
(p.130).
If the message still appears, replace the xD-Picture Card
for 3.: You won't like this one:
Contact your FUJIFILM dealer.
Oct 30, 2013 | Fuji FinePix S6500 Digital Camera
Tip
Xerox XC and XD series copier H3 or H4 error code reset procedure
To reset the H3 or H4 condition on just about any Xerox XC or XD series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
This procedure will work on all Xerox XD and XC models.
on Mar 20, 2010 | Office Equipment & Supplies
I have a Xerox XD 100 work centre showing a H-4 code what is the problem?.
The H4 code on these machines is almost always a false code. Especially if you have had any power fluctuations or failures.
Here is the text from my tip to solving this problem here on Fixya:
Sep 03, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
Ok want to see if i can fix this before i call in the big guns. xerox XD series have a code of flashing 00 then H then 4 powered system down and still the same what is it and what can i do to fix it?
You can fix this. Usually this is a false fuser code. I have a tip posted on this site to reset the code. Just look at the tips and search for Sharp AL series H4 code reset. Your Xerox XD series copier is made by Sharp and was a Sharp AL series copier. The reset procedure is the same.
If the reset fixes the problem please leave feedback for me.
Thanks
Jan 08, 2010 | Office Equipment & Supplies
J2 error on xerox xd 100 copier
hello there:
here is a link that will be able to help you out
  1. XD100 Style: Trouble Shooting Xerox brand models: XD100/102/103/104/105, XD120/122/125/130/155, XL-2120/2130 ... Next month, we'll hit the J1 & J2 codes as well as the L codes...www.enxmag.com/OLD SITE/bhorvat2304.html - Cached
Sep 14, 2009 | Office Equipment & Supplies
L4 code on workcentre xd 155 df
TABLE 1
Summary: 'L4' Product: * Copiers & Multi-Function Copiers
  • XD Series
  • Description: XD100 Family
    - Main motor problem.
    - The main PWB sensed a main drive motor problem. Solution: document.write(ParseIncidentLinks("01 - Switch off the power and wait for 5 seconds.\n 02 - Switch on the power. If the status code persists, Please .", 'Hold down Shift while clicking to open this link in a new window', '(Click here)', 0)); 01 - Switch off the power and wait for 5 seconds.
    If the status code persists, Please see Table 2, below.
    TABLE 2
    Summary: Service Call Product: - Communication Technologies
  • Telecommunications
  • Description: A service call is required when the solution requires a Xerox engineer to rectify.
    Service will be provided in the form of an onsite engineer, repair or replacement of the machine depending on the warranty held for your specific product. Solution: document.write(ParseIncidentLinks("Please contact your local Xerox Help Line arrange a service or further assistance over the phone. You can also e-mail us a question.\r\n\r\nTo find your Xerox Support line locate the contact button at the bottom right of the Screen.", 'Hold down Shift while clicking to open this link in a new window', '(Click here)', 0)); Please contact your local Xerox Help Line arrange a service or further assistance over the phone. You can also e-mail us a question.
    Jan 08, 2009 | Xerox WorkCentre M20i All-In-One Laser...
    XEROX WORKCENTRE XL 2120 ERROR CODE L4
    L4 can be 3 things. If your lucky, look and see if the lamp is moving properly. Something may just be catching it.
    If not, then either the laser or the main board have failed.
    Remove the glass first and see if you can slide the lamp carriage without binding or hitching.
    Jul 09, 2008 | Xerox Office Equipment & Supplies
    FLASHING ERROR 6 L
    L6:The Main PWB sensed a Polygon motor lock signal error. 5-L6 only: Check the connector CN23 on the Main PWB and the wires and connectors on the Laser Module. If connector and wires are not damaged, replace laser module. What that normally means is the laser mirror motor has failed. That normal price for that item is normally over $300. Here is a parts dealer to contact to see if they have it in stock. https://www.partsdrop.com/store/
    May 15, 2008 | Xerox WorkCentre XD120F Laser Printer
    Xerox Workcentre XD130df error
    Not familiar with XD 130 but A1 in most Xerox machines refers to a jam in the document feeder, open everything you can and look for torn pieces of paper on a sensor
    Jan 23, 2008 | Office Equipment & Supplies
    Xerox WorkCentre XD100 All-In-One Laser Printer Logo
    625 people viewed this question
    Top Xerox Office Equipment & Supplies Experts
    Michel
    Xeroxrep
    Level 1 Expert
    Philip Hughes
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
