Question about Whirlpool GU1200XTLS Stainless Steel Dishwasher
My ge gsd3200g00ww dishwasher has a puddle of water
At the end of the cycle, when I open the door, there is water in the bottom. During the other parts of the cycle, water does get cleared out of it into the disposal fine. I can see it and hear it. But between the rinse cycle and the finish, it fills up and never empties out. When I open the door, the water is filled up in the bottom.
won't drain and water leaks out onto floor. Only drains when you cancel the cycle
jsrock516
  • 5911 Answers
SOURCE: water isnt draining
Check your drain line and/or drain pump. The drain line should have a high loop at the point prior to where it connects to your drainage system in order to prevent drain water from the kitchen sink from back flowing into the dishwasher. In addition, most drain pumps have a small check valve that prevents this water from backing up as well. However, if you have something lodged in the drain pump (i.e., a toothpick) it can prevent the check valve from closing properly. This can cause water to back up into the dishwasher. You mentioned that the water will not drain. Is the drain pumping runnings at all? Please post back and let me know.
Posted on Apr 30, 2008
  • 833 Answers
SOURCE: Whirlpool Quiet Partner 2
More likely: the solenoid which directs the water to either the drain or the spray arm is clogged/jammed. Located underneath near the drain line.
Posted on Jun 17, 2008
  • 93 Answers
SOURCE: ran on normal cycle when done 2 inches of water on bottom
Test by restarting the cycle and see if water drains if it does not then there is either a blockege in the pipe ,pump,or in the machine where the water passes out normally through a filter if you have checked and cleaned out filter and drain pipe and there is still no draining then listen to the pump if you can hear a humming niose then there is something in the pump itself and you need to take it out and inspect the impelar houseing remove what ever is there put back and enjoy if there is no noise and pump is clean then it is proberly fualty and nedd replaceing.
Posted on Jan 23, 2009
QueenJLyn
  • 3 Answers
SOURCE: Maytag dishwasher not draining fully
Try cleaning out the air gap.  The air gap is not part of the machine, and is located on your sink. If this becomes clogged, it may cause the machine to not drain properly.  Also, I know you said you checked the drain hose and cleaned as far as the filter and chopper blade, but have you checked the lower filter?  There is a filter located underneath the machine that should periodically be cleaned.  To check this, you need to access the machine from underneath by removing the bottom vanity cover. Hope that one of these helps!
Posted on Aug 01, 2009
  • 5603 Answers
SOURCE: water fills in bottom of washer when off
The fill valve has failed. You can get a rebuild kit for the valve.
Also clean the tiny straainer in the valve.
Posted on Dec 30, 2009
When is a dishwsher supposd to drain? Is pump working correctly?
normal to fill pan during wash and rinse fix door seal if it leaks
Jun 15, 2015 | KitchenAid KUDE40FXSS Builtin Dishwasher
Door leaks at the bottom of my ge profile dishwasher
1 has the machine been pushed into the cupboard hole,this will push the door away from the front of the machine,does it hit the trim around the opening before the closeing?pull out check under are the legs still straight,some you can remove the lower front panel to look under
Dec 02, 2009 | GE Profile PDW8400J Built-in Dishwasher
Leaking from the lower right hand side during rinse cycle.
I had the problem with dribbles of water from the right side lower edge of the door, causing puddles across the floor.
Found there was a RECALL on MDB6000AWW models. The door inside panel was replaced by the dealer for free. No more puddles.
Aug 27, 2009 | Maytag MDB6000 Dishwasher
At the end of each cycle there is a puddle of water at the bottom, it doesnt sound like its pumping properly
Solve at the end of each cycle there is a puddle of water at the bottom, it doesnt sound like its pumping... (More)
Aug 19, 2009 | Zanussi 24 in. DE6544 Built-in Dishwasher
Rinse cycle continues after the door is open
There is a door interlock within the door assembly. I believe it's mechanically stuck rather than needing replacing.
Turn off & unplug. You should be able to get to the internals of the door via screws around the edge. The interlock will be very close to the handle catch. Check operation by inserting a dummy catch to lock onto it.
If it is stuck solid - order a replacement.
Aug 04, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Water comes out the bottom of the door. not
With very few exceptions, when a dishwasher leaks as you describe, the door gasket needs to be replaced. You have not posted the manufacturer and model number, so it is hard to help much more. Please post back here with further questions.
Good Luck!
May 04, 2009 | Kenmore Dishwashers
Dishwasher will not start
Go to your electrical panel and turn off the circuit that feeds your dishwasher. It will also turn off the clean light. Wait three minutes and then turn the circuit back on. That should reset your machine.
Apr 07, 2009 | Electrolux Frigidaire Professional Series...
No water coming into dishwasher Model# GSD3200G00WW
I have the same model and had this issue twice in four years. What causes this is a water level switch inside the dishwasher, left at the bottom, almost touching the door. The switch has a cover that looks like a cup upside down. Remove that cover and give a perfect, thorough cleaning in and around the switch (including inside the cover) to make it look new again. The switch should start working freely again. You don't need to buy new parts to replace anything.
Dec 17, 2008 | GE GSD3200J Dishwasher
Leaks while running
The water at the bottom is normal if you open it during the cycle. Leak means you need to replace the L-shaped black, molded gasket that is in the lower left or right of your door opening. Replacement is easy - requires no tools. Part can be purchased for about $10 each at Sears parts department.
Sep 07, 2008 | GE Nautilus 24" Built-in Dishwasher
GE Triton XL
Try placing a packet in the bottom of the DW and then start a wash cycle ( use the energy efficient cycle that does not use the heater to dry the dishes..).. if it is not disolved at the end of the cycle then your water temp may not be hot enough..Hope that helps..
Aug 28, 2008 | GE Tritonr XL GSD6260JCC Dishwasher
Whirlpool GU1200XTLS Stainless Steel Dishwasher Logo
142 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
