Question about Eureka 6831A Bagged Canister Vacuum
Power head motor is good,runs great from test cord switch seems to work. brush roll cleaned but power head motor will not run
  • 126 Answers
If you have checked the power delivery down to the powerhead and you have current running to the powerhead, then you likely have a burned fuse. There is a fuse built into the powerhead motor and is usually located on the field winding. This is not easy for a novice to replace and even most professional repair shops will replace the motor. It is possible to replace the fuse if you know what you're doing, but if the fuse blew, there may be a more serious problem, after all, the fuse is there if the motor starts to experience distress and the fuse will blow to avoid any electrical issues. The fuse can blow if something is jammed into the roller and causes the motor to labor heavily. If this is the case, then the fuse can be replaced safely. If the motor is burning out, then a new fuse will just blow immediately after replacement. What I do is take the fuse out and run the motor without it to see if the motor is still viable and replace the fuse if the motor proves to be o.k.
Posted on Feb 08, 2008
Beater bar turns but not when the vacuum head is against the floor.
1) test the power cord for open
2) see inside fuse or reset button and reset if there are
3) power switch defective or some wire loose fix it
4) connector inside loose tight
5) c.breaker from your home tripped, reset.
6) if not work, the motor is defective, brush, winding repair.
God bless you
Jun 21, 2012 | Dyson DC25 Vacuum
Now that I just fixed my Lux Legacy canister vacuum, I need help on my other Electrolux Regency Series upright! The vacuum works fine but the rotating brush does not work and the brush motor does not turn...
There are a couple rectangular holes on the bottom of the power nozzle, beside the wheels. These have tabs in them that need released with a standard screwdriver.
rogerpotts_10.jpg Once they release, turn the vacuum over and lift cover of power nozzle at the back. This pulls the front of the cover out of the lip on the "bumper".
Once this is done, you'll need to unscrew the screw at each end of the brush. Lift the brush out and thoroughly clean it, including the ends.
Check the wiring to make sure they're connected to the terminals of the motor. Also, check the belt for wear and tear. These belts can last for five years or more, but if it looks bad a good time to replace it is while you have the power head apart.
When reassembling the vacuum, ensure the belt is fitted properly around the motor shaft and brush.
Insert the front of the cover first, ensuring the edge fits neatly beneath the lip on the bumper all the way around. It takes a little manipulating to press the back into place. Make sure both tabs click into the locked position. Turn the vacuum over and reinstall screws. Try to rotate brush by hand a few times.
At this point, plug the vacuum in and turn it on. If the power head doesn't run, press the reset button. If the power head motor still doesn't run, it could be due to loose or disconnected wires that lead to the reset switch, a bad reset switch, or even a bad motor. The vacuum needs to be taken to the nearest Aerus Electrolux store for further diagnosis and repair.
http://www.aerushome.com/storelocator/
Jan 09, 2011 | Vacuums
My sebo does not seem to be picking up stuff off carpet, what can i do. When I use the hose apart from the vacum it does having sucking power.
Unlike most vacuum cleaners, the Sebo Felix has two separate motors - one for the suction and one to drive the brush roll - so there are several things to check. You say the hose has suction, so the problem is in the lower part of the machine. First, check that there's no blockage in the base of the machine, then check that the brush roll is actually rotating when the machine's switched on. If there's no blockage and the brush roll is rotating, then the problem is simply that the brush bristles are worn and you need a new brush roll. If the brush roll is not rotating, listen to hear if the motor is running - if it is, then you need a new drive belt. If the motor is not running, there's an electrical problem and you may need professional help. If you need more advice, post a response here and I'll do what I can to help. Good luck!
Jan 31, 2010 | Sebo Felix Classic Bagged Upright Vacuum
Kirby will not turn on
For the kirby to run all the switches need to be in contact. First check the brush head and make sure its attached properly, then check the plastic piece on the bottom of the bag (called the mini emptor) it should be all the way against the body of the vacuum. if all that is good check the cord where it runs up the handle and connects to the swiveling strain relief at the top... usually those cords go bad right there. If the cord is good, you probably need a new switch but before you spend the money on that expensive genuine kirby switch check the motor carbon brushes and the commotator on the armature where the brushes make contact.
Jan 02, 2010 | Kirby Generation 3 Bagged Upright Vacuum
My repairman moved so I need to service on my own
Excellent question, however a D3 is basically a problem free vac. All you need to do to maintain it is keep a stock of fresh 4 ply bags and periodically remove the lid from the head and clean out any dust and dirt building up around the motor or brush roll. There are 5 philips screws recessed in the lower housing , accessible from underneath the head , Once removed the lid will lift of and you can vacuum any dust away from the motor and brush roll. There are two hex nuts holding the power head motor in place and if loosened they will change the tension on the brush roll and belt so check the tension before tampering with them.
NOTE On this vac a properly installed brush roll will stop the motor and kick out the breaker/reset on the vac if the brush roll is gripped firmly against the brush opening with a hand securely gripping it.
I mean grab it VERY tight or you will have it slip and blister your fingers. If the belt / motor position is too loose or if the belt has a broken tooth, it will rattle like a machine gun , because it is slipping.
If too tight it will kick out the motor rest continually.You can periodically remove the belt, turn it inside out for inspection and examine for cracking or loose teeth by rolling through your fingers and pull the brush up and slightly forward from its housing to inspect for hair and thread at the end of the brush roll. There are recessed ball bearings inside the wood on the brush roll and they need to be kept clear of buildup on the outside.
Spray any wheel squeaks with wd 40, with the straw in place, justy a quick burst and you can also do this on the very end at the centre of the Power head motor , however DO NOT spray the carbon brush copper surface area as WD will burn. If you are very methodical you can actually remove the carbon brushes which are offset and clean them with a dry cloth and inspect for chipping and wear. Pay attention to their position and do only 1 at a time. That's all. Electrolx 101.
Post back with how you make out.
PS parts come from an AERUS Electrolux source but a good pro vac shop can give you great service too as this same vac is now sold under several labels.
Oct 31, 2009 | Vacuums
How to install a new power cord on a tristar vaccume
You must flip the Tri Star upside down to reveal hidden body screws. Generally 2 at back near the wheels and one at front below the cord retainer.
Once removed the body will separate at the bumper. Before removing the motor , note the position of the carbon brushes relative to the body housing. They will be offset allowing the housing to close without striking the motor.
This is a metal vac body, your connects must be clean and should be taped after using twist terminals as a precaution. Your cord will go first to the switch, then power runs from the switch to one side each of the power head and motor, then from the opposite power head and motor lead back to the switch.
You should secure a knot inside the body of the vac as a strain relief so the cord cannot slip out after connecting
Sep 09, 2009 | Vacuums
Losing power on a carpet attachment
Does the motor stop or the brush roll? If it is the brush roll, then replace the belt. If the motor is stopping, then it could be the motor or the cord for the opwer head.
Mar 15, 2008 | Vacuums
No power to head of Kenmore Progressive canister vac
The extension wands are defective and have trouble with their plug connectors on each end. The power head has a reset button on top right but no lights mean no power which means the wand isn't connecting the power to anything.
Sears has a new replacement -- too bad it isn't recalled so you could get it for free ($106.59 + tax + shipping). 2nd sweeper -- same problem.
1st sweeper: I just took needlenose pliers and pulled connectors out a little further (Too bad I can't seem to make the 2nd sweeper work with this easily. It might be one of the connectors or the wiring harness inbetween with a break.) Can't buy the wiring harness for this or connectors, just the wand.
If anyone has a working wand you want to sell me email me at hiwhatsnew@hotmail.com. Thanks!
Mar 05, 2008 | Kenmore 22812 Bagged Canister Vacuum
Beater bar brush stopped working...
Does the power head motor stop, or does the brush roll stop. If it is the brush roll stopping, replace the belt and/or the brush roll. If it is the motor, you may need to clean out around the motor, it may not be getting enough air to cool causing it to overheat and stopping. That the brush roll plate off, take out the screw, and the top will come off, then you can check to see if cleaning is the answer, if not, the motor may be bad.
Jan 12, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Eureka 6831A Bagged Canister Vacuum Logo
501 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
