Question about Gigabyte GA-965QM-DS2 (rev. 2.0) Motherboard
Only fans are starting - nothing else
I've got now the second GA 965QM-DS2 motherboard from my distributor and the initial problem persists:
I want to use the board for a custom server setup and therefore bought a CORE 2 DUO E4600 2.4GHZ CPU and Corsair xms2 DDRII800 memory (2x1GB). In addition to that some SATA drives...
When all was assembled, both boards behave in the same way. They start up without any beep signal. All fans (CPU and system) start. And nothing else happens.
No screen from the build in VGA port. No LED on the keyboard. The only thing under control is, to switch the machine on and off (holding the power button some seconds).
Until now I tried many thing to exclude that other parts than the mainboard forcing the problem: RAM is ok, tested in another machine; CPU is ok, tested in another machine. SATA drives are not necessary to display a start screen from BIOS. Tried the board with another PSU, but no change.
I have no idea. Any comment will be welcome, solving this problem.
Cheers,
Thomas
  • 2 more comments
  • ToFuVox Feb 08, 2008
    Hi Lemmor,
    thank you. Already tried something similiar:
    1) Tested it with only screen, keyboard, cpu and 1 RAM in each of the four slots or with two on lot 1-2 or 3-4 or 1-3 or 2-4. No change. Tested it with PC6400 (the Corsair) and PC 5300 (Samsung DDRII). Each has 1GB per item.
    2) CPU was tested on a different 775 board and comes up nicely.
    Did not work on theCMOS/BIOS Battery yet. But the board is brand new. In whcih manner should that affect the behaviour of the mainboard? But will give it a try.
    Thanks so far,
    Thomas
    did some tests after replacing/inserting the battery and after short circuit the CMOS pins on the board. But unfortunately... no change at all. (tested with one and two ram in different slots).
    Cheers,
    Thomas
  • thinkjb Mar 22, 2008
    I have the same problem, fans come on but that is it. Post test no beep 00 It is a Gigabyte GA-81k1100 (replaced power, memory, cpu) I have another GA-81K1100 with the same problem
  • Mollie_5 Feb 05, 2009
    I hav e same problem. Also the IDE drives seem to lockup. If I unplug them from the mother board I can get the CD rom's to open and the Harddrives to spin.
  • 749 Answers
Have you checked the CMOS/BIOS Battery? How about reseting the BIOS jumpers?
Test the system using Motherboard with processor and 1 RAM, just connect power and screen only, switch it on. It it fails try another memory... Whether the memory, board of processor is the problem.
Fixya me when done....
Post me back if it doesn't work...
Posted on Feb 08, 2008
I need vga driver for h81m-ds2 for xp
XP is at end of life, no support for it anymore
Jun 17, 2014 | Gigabyte GA-H81M-DS2 Desktop Motherboard -...
How to fix loud whine from gigabyte ga-f2a55m motherboard
This particular main board doesn't have the video integrated into the mobo, so it's got a video card. Often the video card has a fan. The fan could be causing the noise. Have you tried briefly unplugging the processor fan to see if the noise stops?
Apr 23, 2014 | Gigabyte GA-F2A55M-DS2 Micro ATX AMD...
Showing nothing but black screen when start up no bios screen no windows screen not even brand image when start up gigabit GA H61M DS2
Are there no beeps you hear when starting? Some error code or so?
try to reset it by pulling the battery on the motherboard, leave it out for 30 seconds and put it back in, sometimes there is also a reset pin you have to place the jumper on for a few seconds, but i don't see that in the pictures for the motherboard you have.
If that doesn't work, try a different videocard.
If that doesn't work, check the memory, if you have multiple sticks, try with only one.
If that doesn't work, maybe try a different powersupply
If that still doesn't work, perhaps CPU module and otherwise you might be SOL
Apr 19, 2014 | Computers & Internet
Its beeping and beeping and beeping
- Stop Overclocking your CPU.
- Make sure your Heat Sink is placed properly above the processor.
- Clean the Processor fan, Heat Sink and other peripherals.
- Use High Speed fans.
- Use CPU Heat Sink Paste in the processor.
- Fix OS registry with reliable program like I always use Reginout.
- Shut down your computer atleast two hour a day.
Aug 04, 2013 | Gigabyte GA-H61M-DS2 Motherboard
Computer was shut down abnormally following a power failure in a thunder storm. No apparent physical damage to machine but will not reboot. Machine gives single long beeps at 6 second intervals. BIOS is...
take out the processor chip and clock battery along with the ram while it is disconnected from the wall outlet and wait about 5 mins. after you put it back together, if the problem persists the processor might need to be replaced or the entire motherboard its self.
Jun 28, 2011 | Gigabyte GA-7N400 Pro2 Motherboard
PATA boot problem
Did you set the boot options to boot from the PATA drive? Did you set the port mode to legacy IDE? Did you try to let the BIOS determine the type of drive?
Jul 02, 2009 | Gigabyte GA-965QM-DS2 (rev. 2.0)...
GA-7VRX Motherboard won't boot
Hi sebaswis, am I correct that this Gigabyte GA-7VRX is a replacement MB? (I read your other posted questions). http://www.fixya.com/support/t1399506-computer_boot_when_power You mentioned you put your old system back together & it worked fine. If mother board is shorted to the system case you will see the CPU fan spin for a second. Most motherboards use a green led which represents there is stand-by power running to the board.(This is normal). I am unsure why your led is orange. (Its not mentioned in your manual & manual does not show the led?s location). Was the other GA-7VRX MB led always orange or was it also green? Suggest you disassemble the heat-sink from the CPU. You mentioned you installed a new XP 2500+ CPU. If a pin on the CPU was bent during installation of CPU into the socket or if no thermal grease was applied or too little to the top of CPU, either would give you: CPU fan spins for a second & nothing else seems to run. Look over the link provided below. It is a guide to how to install a motherboard. (You may not need this but Its worth going over all the steps). http://www.hardwaresecrets.com/article/145 As far as the power supply. If the MB's are the same (GA-7VRX) & the old system ran with 220W, the newer one should also function. Clarify these questions for me sebaswis. Mike
Dec 18, 2008 | Gigabyte GA-7VRX Motherboard
Gigabyte GA-965QM-DS2 (rev. 2.0) Motherboard Logo
220 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
