Question about Candy CPCA240FFK Bottom Freezer Refrigerator
Orange flashing "Super" light
We found the fridge compartment iced up and it had frozen some goods (fruit & vegetables). The "super" light was flashing. We left it turned off to defrost and since turning back on the light still flashes and it is freezing up again.
Is there anything we can do or does it need an engineer to call? What would the likely cost be? Is it worth reparing as it is just 4 years old?
  • 1 more comment
  • stevie mc Feb 17, 2008
    candy fridge freezer orange super light is flashing, what is the cause of this?
  • Cold_candy Feb 19, 2008
    Fridge temperature is freezing everything and orange light is flashing.
  • jojo33 Mar 05, 2008
    Me too - exactly the same. Initially the Candy service dept told me to switch it off for 10 mins & then on again. The super red light stopped flashing but over time the ice is building up at the back of the fridge.
    Genius:
  • 1,122 Answers
FORGET THE LIGHT FOR NOW,REMOVE FREEZER BACK PANEL,MAKE SURE FAN IS WORKING,FIND THE DEFROST TIMER BOTTOM FRONT,OR ON BACK,OR INSIDE FRIG.TURN CLOCKWISE SLOWLY TILL YOU HEAR CLICK,THEM GO BACK TO FREEZER SEE IF THE DEFROST HEATER KICK ON YOU SHOULD SEE THE ICE MELTING OFF,IF NOT YOU HAVE A BAD HEATER,YOU SHOULD REPLACE TERMANATOR TO ITS A LITTLE ROUND CLIPON ON OFF SWITCH FOR HEATER,NOW WAIT ABOUT 20-30 MINUTES TO SEE IF FRIG. COME OUT OF DEFROST IF IT DOES YOUR DEFROST TIMER IS GOOD,YOU CAN ALSO CHECK HEAT WITH OMES METER IF YOU KNOW HOW,LET ME KNOW WHAT YOU KIND,THANKS-MIKE
Posted on May 30, 2008
Ff187e
Why kept your Vegetables in Freezer? Keep them in the Refrigerator Compartment. If the problem persists, refer to User Manual. Then contact Customer Care / Authorized Service Center or Dealer.
Apr 24, 2014 | Refrigerators
I have a frost free refrigerator (MODEL #: FGTD 20V4GW2 and SERIAL #: ba00230071) yet the ice/frost builds up of the door, top and front of the freezer. Also the bottom compartment where the milks,...
if ice is on the door and ceiling and frozen water dropleats on the food packages the door was left open and the air ducts are frozen.when you open the freezer door do you hear the fan blowing,if not it could be bad or iced up,if the ice is on the inside back wall of the freezer you have a defrost problem,get back to me and tell me if the ice or like snow is just on the back wall or if the door was left open ice will be on ceiling ,door and shelves and food packages,also that's not a good model number if the freezer is on top look at the left wall up near the ceiling in the fridge section,you should see a tag there with the model number.
Sep 25, 2011 | Frigidaire 14.7 Cu. Ft. Top-Mount...
Ice on back of fridge
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 19, 2010 | Hoover HCA454FK Bottom Freezer...
Meat and vegetables placed in the produce drawers turn to ice. fridge temp set at 39. freezer set at 0. as you face the fridge, the drawer on your left is the worst. fruit is okay in right drawer.
check the damper door vent assembly located between the freezer and refrige compartments and make sure its not frozen open so as to let cold air in all the time,adjust the temp in the refrige and the door should open and close with adjustments,if not then damper door motor assy or the electronic control board is defective that supplies power to this door
May 13, 2010 | GE PDS22MCR Bottom Freezer Refrigerator
21' bottom freezer kenmore refrigerator-no ice maker-the fridge is super cold and freezes all my vegetables and fruit. We have cleaned the coils, cleaned the fridge, and it just keeps freezing. Fridge is...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 02, 2009 | Kenmore 21.0 cu. ft. Bottom Freezer...
Both Lights flashing and fridge not getting cold
I turned the fridge and freezer off using the circular dials, I then turned the unit off at the mains. Left it for a few minutes and then turned the power back on. I then turned the circular dials to "max" and then depressed the super cool and super freeze buttons to turn this facility on. This time they came on normally (not flashing) and no alarm sounded. The fridge and freezer then started to get cold. Once the unit had been running for several hours I then turned the dials to the 3/4 mark and depressed the super cool and super freeze buttons again to turn them off. Over night the fridge and the freezer appear to be working properly so I hope that my problem is solved. Maybe the unit just needed to "settle" before being switched on?
Sep 03, 2009 | Freezers
Water laying underneath the fruit & vegetable storage drawers
Hi Matt, Hi Dar(lene)?
Super easy fix. Your defrost drain is blocked by what we in the biz affectionately refer to as "Bio-Gookus", so every time the fridge goes into defrost, the newly melted water has no place to go other than the bottom of your fridge. Gravity is what gravity is, ya know?
My bet is that it's clogged up at the drain funnel located in the refrigerator/beer compartment. If I'm remembering right, it should be just to the left of the thermostat/control panel in the back. You should see a plastic cover there, remove it. See the "Bio-Gookus? Kinda gross, huh? All of that has to be cleaned out. Not only in the funnel but the tubing behind it as well.
After cleaning it (and putting the pieces back) your fridge will be happy again.
Hope this helps!
SG
Mar 23, 2009 | GE Refrigerators
Hotpoint Fridge Freezer FF187e - 3 lights flashing
i have just fixed my fridge freezer by following the instruction from KarenBa and GWoman i have also managed to stop the lights (super cool and super freeze) from flashing by turning the temperature to zero on both fridge and freezer so they turn off then holding both super buttons down for about 15 seconds then turning the temperature back up. hope this helps
Oct 19, 2008 | Hotpoint FFS70 Bottom Freezer Refrigerator
CPCA240FFK orange (super) light keeps flashing
If you have the owners manual it should say what that means but I'll see if I can find an operation manual or tech manual online and get back to you.
Dec 27, 2006 | Candy CPCA240FFK Bottom Freezer...
Candy CPCA240FFK Bottom Freezer Refrigerator Logo
403 people viewed this question
Top Candy Refrigerators Experts
Charles T Nevin
Charles T Nevin
Cesar Quant
Cesar Quant
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
